Old Oct 31, 2012, 10:04 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by e_lm_70 View Post
In my opinon .. the best is a small-medium side EPP wing .. like the windrider mini-Bee ... it is still small ... but is a better bird for aerial.
+1. A 24"-36" wingspan wing is a great FPV platform.
Joe 1320 is offline Find More Posts by Joe 1320
Old Oct 31, 2012, 10:05 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by miketre View Post
Me and my flying buddies are using Spektrum. We had glitches with both the orange receivers and the AR6200. I never had a prob with my AR8000, but then it's because I do not have a lot of flights with my AR8000 equipped planes there.
I'm slowly moving over to FrSky now.
Never ever got a glitch on my RC birds
Mainly using FM 40Mhz ... or 2.4Ghz FrSky gears ...
Got maybe 2 km far by accident with 40Mhz gears ... my 1.4m wing was like a little point in the sky ... I was on a top of a little hill in the middle of a flat land ... so that give better view for fly more far away ... I manage to make it come back to me ... luckily no glitch at all.
Same happen .. but much less distance ... with my Micro T-45 EDF ... was a point in the sky ... but luckily the micro FrSky got a stable signal ... and I manage to make it to come back to me
e_lm_70 is offline Find More Posts by e_lm_70
Old Oct 31, 2012, 08:43 PM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Wow, that must be some pretty strong interference.
Sky_Captain is offline Find More Posts by Sky_Captain
Old Nov 01, 2012, 09:37 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
I converted my Mig-29 to a pusher
What gear did you use?
Gene K
speedy01 is offline Find More Posts by speedy01
Old Nov 02, 2012, 01:28 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
I used the stock ESC and a 18-11 2000kv Micro Brushless Outrunner (10g)
http://www.hobbyking.com/hobbyking/s...idProduct=5358
Battery is a Rhino 3S 360mah. I totally forgot that i'll be running on 3S when I put the plane together. Otherwise, I would have opted for the Plush 10A.
The stock ESC seems to be holding up after 6 flights.
miketre is offline Find More Posts by miketre
Old Nov 02, 2012, 02:45 AM
e_lm_70 is offline
Austria
Joined Jan 2004
You like to put on the edge these little motors
It is stated as 2s and 5.5amp max .. so it may have a short life
Which prop you use? 5x3?
Old Nov 02, 2012, 02:52 AM
miketre is offline
miketre's Avatar
Joined Dec 2010
on my Mig-29, I use either a 5x3 or 4x4. Can't remember which one.
The motor suggested Prop is 7x5. That's big! it is the prop size of my F-27Q stryker.
Are you interested to convert too?
Old Nov 02, 2012, 03:04 AM
e_lm_70 is offline
Austria
Joined Jan 2004
No ...
Just checking the possible life of your motor
Anyhow 5x3 2000kv 3s ... should not go above 6amp ... so ... it should last many flights
Old Nov 05, 2012, 02:14 PM
nebuchadnezzar is offline
Find More Posts by nebuchadnezzar
gilford, new hampshire, usa
Joined Nov 2003
My 35 mm parts arrived. 3 and 5 blade fans and the Hobby B motor. Assembled and tested last night -- the 3 blade impeller shed it's blades on test run up!! The 5 blade was then assembled and runs fine. 10A esc and 3cell 500mah batt. Won't run on 2s for more than a half second. I guess I will run the 5 blade on 3S and use careful throttle management. I suppose I could order another 3 blade impeller or 2. I wish they could be shipped cheaper somehow.
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old Nov 07, 2012, 08:28 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
that don't sound good ! i have a couple of 35mm fans for a few jet builds i just got from hobbyb. are you using the jpower esc ? curious why the 2s won't run
KCinNC is offline Find More Posts by KCinNC
Old Nov 07, 2012, 08:45 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Is there any chance the ESC cell count needs to programmed manually? If it's programmed for 3 cells, a 2 cell lipo will LVC.
What brand of ESC are you using, neb?
g
giuseppi is offline Find More Posts by giuseppi
Old Nov 08, 2012, 10:15 AM
miketre is offline
miketre's Avatar
Joined Dec 2010
some slow flight footage of my Mig-29 with 3 axis gyro.
Mig-29 test flight with gyro and FPV gear (1 min 24 sec)
Old Nov 08, 2012, 02:53 PM
dude_109 is online now
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
...Won't run on 2s for more than a half second.
Not all ESC are the same quality. Some brands use so much voltage to operate that it doesn't leave much for the motor, thus a 2S will see low voltage very quickly and thinks its out of juice.
I've got a batch of ESC that was new and was slightly less expensive than a brand I had been using so I gave them a try and learned the hard way. Even on 3S, it will run with less power since not all of the voltage is delivered to the motor. Lesson learned for me...find a good brand and stick to it. Only HobbyWing/Turnigy/Volcano brand for me from here on out.
dude_109 is online now Find More Posts by dude_109
Old Nov 29, 2012, 04:26 PM
lomce-what is offline
Find More Posts by lomce-what
lomce-what's Avatar
United States, TX, Amarillo
Joined Oct 2007
I ordered the 35mm A-10 almost 2 weeks ago. Enjoyed flying it on 2S (pretty quick). Recently upgraded to two 10a plush esc's and 11.1v 500mah turnigy nano battery (for now the 5 blade fan). Its a screamer now. Motor's don't get hot but battery does even with a little venting... thinking about switching to 3 blade fans. Fun plane if anyone is thinking of getting it.
lomce-what is offline Find More Posts by lomce-what
Old Nov 29, 2012, 05:12 PM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
http://www.youtube.com/watch?v=5dViG1xynQE
Very interesting. It doesn't seem that much worse without the Gyro - at least on video. How was it on the flying end, on & off?
Angelo is online now Find More Posts by Angelo
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
