Old Oct 11, 2012, 09:27 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
Do you guys think the 3ch 35mm banana hobby mig 15 is easier to fly then the 4ch 30mm GP f86 sabre? I'm still having issues with my sabre. I'm hoping ill have better luck with the mig15 from banana hobby.
Mike20 is offline Find More Posts by Mike20
Old Oct 11, 2012, 09:47 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
what kind of issues are you having with the Sabre ? i have the 35mm F-86 from BH...it flies pretty good. only difference i see, is the 3 channel dosen't have a rudder. i actually never use the rudder on these smaller jets
KCinNC is offline Find More Posts by KCinNC
Old Oct 12, 2012, 12:48 AM
metalguy is online now
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I love my Saber when the motor works properly... My latest issue is the bearings are crap, and allow play at higher RPMs. Then cool stuff happens, like HEAT, and it melts the housing, allowing it to touch the fan, and shell it out. I need to order another motor now......*sigh* At least my MiG-29 works! Too bad I tried to put it through a chain-link fence. Being fixed as I type!!! -------Metalguy
metalguy is online now Find More Posts by metalguy
Old Oct 12, 2012, 12:49 AM
XeCutor is offline
Find More Posts by XeCutor
Sweden, Stockholm
Joined Jul 2012
Out of the batteries in hobbykings range, which ones would people with experience recommend to a stock F15, (i.e. 2S)?
XeCutor is offline Find More Posts by XeCutor
Old Oct 12, 2012, 05:48 AM
bps is offline
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I have the Hawk and use 450 2s 40c to get 3-4 minutes of flying time. Not as fast as 3s but stock ESC and fan with decent speed for a small jet. The difficult part is the launch. Either plenty of wind or a very strong throw to get it going.
I realize your asking for the F15 but the Hawk has a very small nose as well. Hope this helps. Good luck.
bps is offline Find More Posts by bps
Old Oct 12, 2012, 06:30 AM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
I dont know if my flying space is too small or it's lack of experience. but I can't keep the plane in flight long enough to trim out my control surfaces before it flips or nose dives into the ground. And I'm still having elevator issues so when I try to get the nose up it doesn't move fast enough before it hits the ground. I'm hoping I'll have better luck with these. My flying field is three football fields side by side.
Old Oct 12, 2012, 03:36 PM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Mike, it does usually take a little more space for trimming. Maybe you can go to a larger field just for trimming, or get someone to help. Just tell them what to trim while you are flying
Sky_Captain is offline Find More Posts by Sky_Captain
Old Oct 12, 2012, 11:05 PM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Xecutor, I use 850mAh nano tech batteries in my MiG-29 with good results. The airframe is similar to the f-15. -----Metalguy
Old Oct 15, 2012, 10:39 AM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Anyone change the bearings on one of these small motors? Its too bad we can't just get the whole edf with motor. At least, I have yet to see it offered. -------Metalguy
Old Oct 15, 2012, 10:41 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
You can get the motor and EDF as seperates from www.hobbyb.com. The fans come with motor screws as well. They are available in 3 blade or 5 blade fans.
http://www.hobbyb.com/skyangel-repla...?cPath=128_141
http://www.hobbyb.com/skyangel-rc-pl...html?cPath=122
Joe 1320 is offline Find More Posts by Joe 1320
Old Oct 15, 2012, 11:12 AM
jirish617 is offline
Find More Posts by jirish617
United States, IL, Chgo
Joined Sep 2012
hey guys, need a little help. So Ive been out of town and my f86 showed up. I have battiers, still waiting for my molex connectors for my Rx, but can someone pinpoint me to a charger to use. For some dumb reason, i was expecting these to use deans for the plane/batteries. I have no clue what to use to charge them now, some input would be appreciated, thanks!
jirish617 is offline Find More Posts by jirish617
Old Oct 15, 2012, 11:31 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
You could use something as simple as this:
http://www.horizonhobby.com/products...0-65a-EFLC3110
Ideally, an adjustable rate charger is best. Most lipos charge at a rate of 1C, meaning a 500 mAh lipo would charge at the rate of .5 amp, a 1000 mAh pack at the rate of 1A, etc.
personally, I use the Great Planes Polycharge 4
http://www3.towerhobbies.com/cgi-bin...?&I=LXKAU0&P=M
along with Great Planes ElectriFly Equinox LiPo Cell Balancers
http://www3.towerhobbies.com/cgi-bin...&I=LXMGS7&P=ML
That way, 4 lipos can be charged at the same time and all at different rates. I have two of the polycharge 4 chargers and 8 equinox balancers with a large A/C to D/C power supply. It's an overkill setup, but I have those kinds of needs.
Old Oct 15, 2012, 01:23 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Here are some other options.
http://www.hobbyking.com/hobbyking/s...dProduct=15166
I have one of these
http://www.hobbyking.com/hobbyking/s...k_Charger.html
and one of these
http://www.hobbypartz.com/98p-imars-charger-6s-50w.html
But remember, you will need a power supply with 90% of the chargers that are out there.
http://www.hobbyking.com/hobbyking/s...dProduct=19680
I bought my power supply right here on RCU from a guy that was selling some HP powersupplies. Had to do some soldering and made my own power distributor from a electronic project box from RadioShack.
Oh, the Accucel 6 in the picture next to my Turnigy 4x6s is also a good charger. I no longer have it because I left it on my rear bumber when I took off for the field so... it's gone I almost bought another one but I wanted to try out the slick Gens ace charger and I like it a lot.
Old Oct 15, 2012, 02:58 PM
Joined Sep 2012
I have one of these
and one of these
My apologies for not specifying, I do have a charger, from racing offroad buggies. I just run everything deans, then to bullet connects because of the hardcase pack I run have bullet connectors. I do not know the name of the connector that comes standard off the esc that the battery plugs into(same as the connector on these batteries). I guess I was wondering if any of you knew of a harness that goes from ultra deans to...(whatever the name of these connectors are) Sorry for the confusion, and once again, thank you for your help. I would just get that eflite charge for the ease of things, but it says output is .65a but I have to double check. I think the packs that came with the f86(whatever banana recommended) was only 450mAh
Old Oct 15, 2012, 03:25 PM
Joined Sep 2012
I came across this, the charger I use, uses bullet connectors. My balance board plugs in via bullet/banana connectors but has deans on the board itself. I could just use these correct? And just not use the balance board. I mean i lose the luxury of charging more than one battery at a time but this should work? only thing i am unsure if if the wire used in this would be rated high enough to handle the charging current .45A?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPHE0
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
