Old Oct 04, 2012, 11:56 AM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Watch out where the Huskies go, and don't you eat that yellow snow!
giuseppi is offline Find More Posts by giuseppi
Old Oct 04, 2012, 02:21 PM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
jirish617
Good question, I guess you would need one of their molex adaptors.
Angelo, I listened to them too.
Sky_Captain is offline Find More Posts by Sky_Captain
Old Oct 04, 2012, 06:38 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
DOH! My A-10 had a mishap, I am in need of a set of landing gear that comes on the Mig-29 and A-10 ARFs, If anyone is not using theirs due to it being a hand launched bird, can you part with the gear?
Joe 1320 is offline Find More Posts by Joe 1320
Old Oct 04, 2012, 07:26 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
I would if I had one of those. 90% of the time I hand launch and belly land
Old Oct 09, 2012, 12:44 AM
metalguy is offline
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I have the gear, but it is mounted on the Mig, and the CA wicked into it. I can't get it out! Been flying the snot out of the Mig-29 and the saber. I don't understand why, but they have fast become my go to planes when my others are having problems. I like 'em so much I just ordered a 50 mm Mig 15 and a kit 50 mm saber. The Mig I'll be picking up tomorrow from the local warehouse, and the saber will arrive in a few weeks from Hobby king in China. I am currently reading the thread on the larger skyangel planes....I will be out of $ in no time. ---------Metalguy
metalguy is offline Find More Posts by metalguy
Old Oct 09, 2012, 10:37 AM
XeCutor is offline
Find More Posts by XeCutor
Sweden, Stockholm
Joined Jul 2012
Can anyone suggest which ones of these little 35mm jets to go for as a beginner-edf, basically - which one flies best out-of-the box with no modifications. I'd be buying this as a little bonus (to myself) from the German hobbyking warehouse which I just realized has a very limited selection, so basically I have the F16 or Red Arrows Hawk to choose from.
XeCutor is offline Find More Posts by XeCutor
Old Oct 09, 2012, 10:44 AM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Honestly I think the F-15 is very forgiving for a 35mm edf (as long as you have some time on a 4ch), I havent had the F-16 nor the Hawk to compare it too tho. HobbyKing is awesome, but hobbyb.com is a GREAT place for the 35mm edf's.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Oct 09, 2012, 10:51 AM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
I only have experience with the F-16. It easily gets stuck in high alpha stalls under power and also pitches up noticeably on throttle increase. The high alpha stall is very easy to enter if you launch with too much throttle or too high of an angle.
It's other flying characteristics seem fine for a first EDF to me, but I can't recommend it.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
+1 The F-15 is probably best for a beginner to cut your teeth on EDFs. It will float at lower throttles and hauls on 3s (with upgraded ESCs) and there are no bad habits.
http://www.rcgroups.com/forums/showthread.php?t=1717610
Old Oct 09, 2012, 05:43 PM
Luck is my skill
Joined Jun 2009
The other cool thing about the F-15 is you can put a larger lipo in like a 3s 850 and CG is good like you did in your thread. if I had an 850 in my F-18's they would just fly into the ground.
Old Oct 09, 2012, 06:05 PM
Boofhead is offline
Find More Posts by Boofhead
That will simply buff out
Boofhead's Avatar
Australia, NSW, Kareela
Joined Jul 2001
I would have thought that the Red Arrows Hawk would be the easiest out of those 2 - the larger 50mm one is pretty stable
Agree that the F-15 is a nice selection - it is much more stable than the MIG-29
Boofhead is offline Find More Posts by Boofhead
Old Oct 09, 2012, 07:00 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Are you serious? You could put a 3s 850mah in the F-15. Isn't it a micro just like the rest of them?
Old Oct 09, 2012, 07:02 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Originally Posted by Boofhead View Post
I would have thought that the Red Arrows Hawk would be the easiest out of those 2 - if it is like the larger 50mm T-45 which I have it is quite
The micro T-45 from what I've heard, is not quite as benign as it's larger version. It takes some mods to work like the 50mm.
After fixing the thrust line issue on the Mig-29, I removed some foam in the lipo area and use the same 3s 800 mAh packs as in the F-15. The fixed Mig flys more like the F-15 now. They both rip along pretty good on 3s.
Fits perfect in that spot. In the Mig-29, the lipo gets moved forward about a half inch to clear the rear of the canopy. You can use smaller lipos by just placing them more forward in the battery compartment. They really did a good job on these twins.
Old Oct 09, 2012, 08:04 PM
bps is offline
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I have the Nano T45 in the 35mm fand size. Not a beginners jet. On two cells it is an animal. I have not tried 2 cells yet. I meant I have not tried 3 cells yet. All my flying has been on 2 cells plenty fast this way.
bps is offline Find More Posts by bps
Old Oct 10, 2012, 07:11 AM
nebuchadnezzar is offline
Find More Posts by nebuchadnezzar
gilford, new hampshire, usa
Joined Nov 2003
I just received the 35mm F16 kit from HobbyB. What is the best way to set it up? Flaperons? Spoilerons? Any pictures. (got the 50mm kit too)
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
