Old Sep 29, 2012, 08:33 PM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
I got a used Mig 15 at Apollo Xl field last weekend . It included everything but the Rx for $20, I hope all is well with it when I get the right Rx.
alpea 41 is offline Find More Posts by alpea 41
Old Sep 29, 2012, 08:43 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
That was a nice score. BTW, do not attempt to launch it with an upward arc. There is some up incidence built into the horizontal stabs, it takes a hard push straight forward and it climbs up on it's own. If you toss it upward, expect a stall and subsequent flat spin just like the larger version.
Joe 1320 is offline Find More Posts by Joe 1320
Old Sep 29, 2012, 08:51 PM
alpea 41 is offline
alpea 41's Avatar
Joined Oct 2007
Thanks for that Joe. Many hand launches under my belt , but the too great an angle of attack is still the OOPS that bites you in the A$$. It happened today on James's HET / WEmo powered mini Concept X. It did what looked like a controll line wing over into a nose splat. But was only minorly dinged.
Old Sep 30, 2012, 06:39 PM
jirish617 is offline
Find More Posts by jirish617
United States, IL, Chgo
Joined Sep 2012
hey guys, can someone please help me. I have a futaba 7c Tx, what rx could i use that will work this plane? sorry i am new and stil learning.
jirish617 is offline Find More Posts by jirish617
Old Sep 30, 2012, 06:50 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
This would work:
http://www.bphobbies.com/view.asp?id...4&pid=E1704723
Old Sep 30, 2012, 06:55 PM
Joined Sep 2012
Originally Posted by Joe 1320 View Post
i dont think so? my 7c is a 2.4ghz FASST
Old Sep 30, 2012, 07:00 PM
Joined Sep 2012
or would this fit in the f-86
http://www3.towerhobbies.com/cgi-bin...?&I=LXWHX6&P=3
Old Sep 30, 2012, 07:07 PM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
I have the F-86 and it's a nice little brother for my 60mm F-86.
I really like this little plane and everything was quality, but the aileron servo horn has too big of holes for those tiny connecting rods. Does anyone have a good fix for it? Some kind of grommet or something?
Sky_Captain is offline Find More Posts by Sky_Captain
Old Sep 30, 2012, 07:15 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Well, that does make a difference.
Old Sep 30, 2012, 07:20 PM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
Thick CA to fill the open space, then hit it with kicker. After it cures, manually rotate the servo arm while bracing the rods. The cured CA will pop loose and you're left with a bearing and greatly reduced slop.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Sep 30, 2012, 07:26 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Awesome idea, thanks
Old Sep 30, 2012, 10:13 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Just a heads up to all that the stock 35mm EDF fans outrunner is rated at 6600kV, not 9000kV as advertised.
NitroCharged is offline Find More Posts by NitroCharged
Old Oct 01, 2012, 12:47 AM
metalguy is offline
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Flew the Mig-29 again today, and filmed it onboard with a keychain cam. The footage is worthless, and I landed in a neighbor's bush. No damage. I then swapped batteries, and the red wire broke from the RX when I tossed it, removing all power to the plane. It stalled, and fell to the ground, no further damage. Pretty tough plane. I had thought the ESC had given out, but found the broken wire when I got home. A quick solder job, and it is ready again. -------Metalguy
metalguy is offline Find More Posts by metalguy
Old Oct 01, 2012, 07:01 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Tested or another vender's spec?
Old Oct 01, 2012, 07:52 AM
Flying is Freedom
Annandale, VA
Joined Jul 2007
That's good info. Thanks.
Nice avatar, I wish that plane was available as a PNP.
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
