Old Aug 17, 2012, 09:23 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Originally Posted by Kevin Greene View Post
Yes---Do you have the fan as well???...
Kevin
No fan pm sent
3d astronaut is offline Find More Posts by 3d astronaut
Old Aug 17, 2012, 10:09 PM
bps is offline
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Originally Posted by bps View Post
I just found out that trimming a rotor down from my 40mm AEO fan unit works great. It threads onto the small shaft of the motor out of the T45 and makes a great looking 35mm fan unit. More blades and they are a bit wider. Most likely pull a bit more amps but give more thrust. May be able to fly on the 450 2s. Report to follow.
Just flew this mod today in 8-10 mph winds. Very impressive but I am waiting to fly in near zero wind to see how this fan actually flys compared to the stock. I would use stock if I could get one. Trimming the AEO fan down it is difficult to keep all the blades equal and keep the fan balanced. Overall looks like this fan gives more thrust on the 450 2s. More later
bps is offline Find More Posts by bps
Old Aug 18, 2012, 06:46 PM
bps is offline
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Flew the nano T45 today again. Using a cut down AEO 45mm fan on this plane is the way to go. Nice speed and flew well out of a hand launch using a 450 2s battery.
Old Aug 19, 2012, 12:22 PM
warbird_one is offline
Find More Posts by warbird_one
warbird_one's Avatar
Germany, NRW, Heinsberg
Joined Dec 2011
3S and 3-blade is a blast with the t-45
Hi guys,
yesterday I had my maiden with my T-45 on 3S. I used Turnigy Plush 10A and 370mAh 3S Nanotechs in combination with the 3-blade fan. I did not think about using the 5-blade because I don't want to burn my esc.But if you say the 5-blade works maybe I will try this too.
But guys my actual setup is awesome!!!! The launch is still a little complicated but the jet is a rocket now! The 3-blade sounds amazing and the t-45 goes vertical. Big loops no problem and much more speed.
All in one I can recommend the upgrade to 3S and 3-blade fan. 2S was nice but 3S rocks
If the temperatures go down in germany (today 38 degree C) I will try the 5-blade. Today the esc is able to burn if its only laying in the sun
Another question where do you position your receiver in the t-45. I saw a small hole above the cockpit can I push it in there? At the moment it's beside the elevator servo...
Regards
warbird_one is offline Find More Posts by warbird_one
Old Aug 19, 2012, 01:44 PM
bps is offline
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I have my receiver located in the slot just behind the rear of the canopy and above the elevator servo. This let me get my 2s 450 stuffed into the area just under the elevator servo.
I also am considering ordering AEO 35mm 8 blade housing and fan. Maybe I can use the 2 cell battery and the stock T45 motor.
Old Aug 20, 2012, 01:01 AM
Joined Dec 2011
Cool,
I put the receiver in the slot you talked about. Then I cutted some foam away and pushed the lipo as far back as possible(beside the elev-servo, as you said). Now I do not need the extra weight at the end of my hawk to get the right CG! Tx for this idea...I don't know why I did not make this before....
Old Aug 20, 2012, 05:46 AM
bps is offline
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Glad that helped. The last thing this tiny jet needs is more weight. I am still working on a decent way to hand launch this jet. About half the time I fly it into the ground!
Old Aug 20, 2012, 06:31 AM
Joined Dec 2011
Me too It's better with 3S but still I'm going to start above high grass to absorb the possible crash...I tried the underhand launch as well but then the jet makes a roll to the right with a following nose dive...but it's very sturdy!
Old Aug 20, 2012, 08:08 AM
Joined Sep 2011
Here is how I have been launching these jets since day 3 or so. This video was actually my first attempt at the underhanded style and it worked perfectly and has worked perfectly ever since. Ive only had one bad launch after switching to underhand and that was after I had landed in some tall grass and broke a fan blade. So much for pre flight checks lol. On 2s, you need to toss it in an arching motion, let the nose come down a bit to pick up a little speed then gently pull back on the elevator and it will climb right out. On 3s, you can practically just drop the darn thing and its up and away. This video is VERY loud and VERY windy. Its the 2s f86 but it works the same for my t45 as well
Skyangel 35mm F86 Modified (2 min 40 sec)
Old Aug 21, 2012, 11:13 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Yes
I made my T-45 35mm to loop from level
I just replace the 360mAh 2S from Rhino ... for a new 300mAh 2S 35-70C Turnigy nono-tech ... wow ... I can loop till the end of the battery time
So ... no need to go 3S then for me
Tchuss
e_lm_70
ps: I did change my under-hand bowling style for a more conventional over-hand ... and I think it is more easy ... even if the previous bowling style was working to me ... but maybe I lost practice to it.
pps: I did fly 2 battery on my T-45 35mm .. and between flights I used my hacked-cheap RadJet 420 (3S but with 2000kv, so similar to PNF stock version) ... ups the T-45 is looking so slow ... also the RadJet is much more reacting ...
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 21, 2012, 05:41 PM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
I realised I have a AEO 35mm 8 blade rotor around somewhere, so I dug it out, pushed it onto a JPower 35mm fan motor, quickly balanced using Nitro's method (except I used blue tack). Very easy to fit, I think I had it fitted and balanced in about 10minutes. The press fit didnt even seem to slip at full throttle.
Here are the results, 70g thrust for 6.25A on 2s, not a worthwhile improvement over stock I think. From memory stock 5-blade produced 61g for 4.2A on 2s.
Maybe it would have produced more thrust with a bigger esc, I used a Thunderbird 6.
p.s. servo hole was taped over so no cheating
F86 35mm stock motor, 8-blade 35mm AEO rotor (0 min 54 sec)
green_flyer is offline Find More Posts by green_flyer
Old Aug 22, 2012, 12:35 AM
Joined Dec 2011
Oh really cool. It's a pitty that I did not try higher rated lipos. Because I lost some time to wait for the 3S setup...
But I think 3S is still more powerfull than the 2S setup. And it was not expensive. 10$ esc and 4$ one lipo...the jet goes unlimited vertical... But main thing is that we're both happy with our little red rocket
You're right.
I find out yesterday that the over-hand-launch does always work if you throw strong enough and a little upwards. My hawk is a bit nose heavy (I love it) and when it's thrown up in the sky, it falls down gets speed and ....away
Old Aug 22, 2012, 11:39 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Here are the prove of my loops with stock set up :
HobbyKing Red Arrows Hawk 35mm EDF Micro Jet EPO (PNF) with 2S 300mAh 35C (3 min 29 sec)
Anybody willing to doppler me for check my speed ... I made some low pass at around 2m40 second mark ...
Tchuss
e_lm_70
ps: This is one of my best video using my keycam #11 on my baseball cap ... that mainly means that the other that I did are quite bad ;-)
Old Aug 22, 2012, 01:39 PM
Joined Dec 2011
Impressive performance with stock setup!
Old Aug 22, 2012, 04:25 PM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
Tchuss,
That was a scary launch...even with a high C 2S. Remind me again if you're using 3 or 5 bladed fan?
I'm looking to retire my 50mm T-45 and this 35mm might be a good replacement. Does 3S make launching simple?
dude_109 is offline Find More Posts by dude_109
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
