Old Aug 11, 2012, 07:25 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by verkair View Post
Anyone have any experience on flying the F18. Is it a good flyer and have good power on 3 cell? Thanks.
Oh yeah.... the F-18 rocks on 3s. Nearly unlimited vertical, great speed.
Joe 1320 is offline Find More Posts by Joe 1320
Old Aug 11, 2012, 10:08 AM
verkair is offline
Find More Posts by verkair
United States, TX, Dallas
Joined Apr 2012
Thanks, Joe.
I guess that answers that question.
verkair is offline Find More Posts by verkair
Old Aug 11, 2012, 10:12 AM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
+1
Had 3 of them, all gone now due to various reasons, stock servo failures into lake union, misc 100ft trees popping up in mid flight etc, almost gave up on the 35mm line due to my luck with these fast little buggers.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Aug 12, 2012, 07:43 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
I picked up a couple of the stock 35mm fans from HK, but don't have a motor. Do y'all think the 10mm Ammo from the GP F-86 is a suitable substitute, provided the 3 blade rotor is used? And how about the Turnigy 1015, as well?
g
giuseppi is offline Find More Posts by giuseppi
Old Aug 16, 2012, 06:23 AM
michi3 is offline
Find More Posts by michi3
Joined Jan 2009
Hi,
I want to step up to 3S.
IŽm a little confused about what rotor to use in this case, 5 or 3 blades. I couldnŽt find any exact information in the thread. All I found was just swap the speed controler and use th stock motor and fan.
So I guess this means using the 5-blade rotor on 3 S?
Thanks for any help on this.
Greetings
Michael
michi3 is offline Find More Posts by michi3
Old Aug 16, 2012, 06:29 AM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
I've flown on 3S with the stock motor and 5 blade fan with no problems (after swapping the ESC).
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Aug 16, 2012, 10:39 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Same here. I actually have never even ran the 3 blade as the 5 blade seemed to work so well. So just upgrade to a 10amp esc and you are ready to go. I know myself and a few others are running the turnigy plush escs that are like $8.50 a piece. Still waiting on replacement fan units I miss flying these little buggars!
3d astronaut is offline Find More Posts by 3d astronaut
Old Aug 16, 2012, 11:03 AM
bps is offline
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Me to, lost a blade in my Nano T45. Looks like it will be grounded for some time! I have considered using a fan unit from the 30mm Sabre. It flys that plane very well.
bps is offline Find More Posts by bps
Old Aug 16, 2012, 11:34 AM
Tom77 is offline
Find More Posts by Tom77
Joined Feb 2009
I'm converting my twin 35mm F15 to 3s. What battery connector are you guys using for this setup? Does the JST handle the amps of the two 35mm on 3S? Or did you go to something else?
I'll be using thje 5 blade rotor.
It was a lot of fun to fly on 2S but a little under powered. I think it will be great on 3S.
Tom77 is offline Find More Posts by Tom77
Old Aug 16, 2012, 11:40 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
I've actually had a manufacturer ship me a test model that had a 24A draw and used a JST connector. I didn't want to use it but tested it anyways before I switched it. It got so hot that the foam that was touching the connector started to melt. That's absurd! I tend use use a mini dean's once the amps go over around 8A, and tend to use a full size dean's at around 20A.
I would think a micro deans should be more than suffecient with a twin 35mm 3s combo. In fact, it does just fine in that 24A combo with the connector only getting slightly warm.
Old Aug 16, 2012, 12:03 PM
Luck is my skill
Joined Jun 2009
I'm running my F-15 with 370mAh 3s Nano-Tech supposed to be 9.25a constant with a burst of 14.8a and my JST's haven't felt hot.
I'll see if I can test the amps and watts on mine tonight.
But like Joe says, Mini/Micro Deans I've read nothing but good things about, so I will prolly switch to those in the near future.
Here was my maiden flight, which shows a little on how it flies on 3s
Micro F-15 Micro 35mm EDF Maiden Flight! (2 min 25 sec)
Here are some slow passes.
SkyAngel F-15 Twin 35mm EDF (3 min 2 sec)
Old Aug 16, 2012, 12:26 PM
bps is offline
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I just found out that trimming a rotor down from my 40mm AEO fan unit works great. It threads onto the small shaft of the motor out of the T45 and makes a great looking 35mm fan unit. More blades and they are a bit wider. Most likely pull a bit more amps but give more thrust. May be able to fly on the 450 2s. Report to follow.
Old Aug 16, 2012, 12:27 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
I can't wait for the report on this conversion.
Old Aug 16, 2012, 04:56 PM
michi3 is offline
Joined Jan 2009
Hi,
thanks a lot for all your answers concerning the number of blades to use. IŽll give it a try on 3S now with the 5-blade rotor.
Michael
Old Aug 16, 2012, 07:27 PM
Joined Sep 2011
I thought the f18 was the horrible model that everyone was dogging on? I think one guy even made it a pusher? Might have been the mig29.. Do you think the f18 is as good as the t45? I love my t45 and my sabre and would even like to add the f18 as I LOVE that plane, I just thought I read that was a bad one to deal with.
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
