Old Jul 01, 2012, 01:59 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Originally Posted by Joe 1320 View Post
The problem is the shape of the F-86 intake duct is not so good, the model suffers from low static thrust because of that intake. Adding a thrust tube and reducing the exit size would further reduce static thrust..... not so good in this case. After adding the cheater duct, reducing the exit size may be of some benefit, I haven't had the opportunity to test that part yet.
I also did the cheater hole mod that Joe posted. It really did make a difference. In the air, you cant even see it. I have flown it by with a few people on the side lines and we were trying to spot it but seriously, its not visible even at lower speed passes. With 3s and the cheater hole, its impressively fast for what it is.
3d astronaut is offline Find More Posts by 3d astronaut
Old Jul 01, 2012, 02:11 PM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Okay, this is what I've heard about cheater holes, yes, they improve static thrust, but don't add much when the plane is flying. I've even heard that they can reduce efficiency in the air. My F-86 launches fine, so static thrust isn't an issue. What has been everyone else's experience? I think I remember at least one person who said adding the cheater hole improved flying speed.
Angelo is online now Find More Posts by Angelo
Old Jul 01, 2012, 02:38 PM
Joined Sep 2011
The cheater hole mod made my plane on 2s a bit quicker, and it just flew better. I was able to loop pretty well where as before, it was nightmarish. Also removing the wing tanks made a huge difference as well. I have since then gone through 2 aileron servos since its pretty bare down there but its well worth it for the decrease in drag If you are worried about it just cut it cleanly into a rectangle and keep that piece of foam. If you dont like it put a dab of glue on and get a silver paint sharpie. Its almost an identical match. You will never know you cut it out!
Old Jul 01, 2012, 03:03 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
The whole reason I posted the cheater mod was that I felt the F-86 was a pig out of the box. Yes, it would fly.... but if the plane got off step or was flying downwind, one false move and down it went. A bad launch, and down it went. It was terrible on recovery. A look at the duct, I could see the way it necked down for the battery tray and right away knew that it was not flowing well. the panel was cut out and took a flight and have been happy ever since. the back edge was also beveled so that it was a more straight shot to the fan. Not one bad launch since, not one downwind dump, the plane flys like it should have in the first place. At some point I'll step up to 3s like a few others in the hanger, but at least it flys well enough now that I can at least wait until these lipos die. It's a little quicker, it's definately got more thrust, much more of a joy to fly.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jul 01, 2012, 03:06 PM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Guess I'll bite the bullet and try a cheater hole, like you say, I can always put it back. I never flew with the drop tanks, part of the reason mIne flies well, I believe. It does barely loop, that would be good to improve.
Old Jul 01, 2012, 03:07 PM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
P. S. - I always land on grass, so not having the drop tanks isn't an issue.
Old Jul 01, 2012, 03:14 PM
hanzie is offline
Find More Posts by hanzie
Fear me, I'm a space-duck.
hanzie's Avatar
Joined Nov 2011
I have never had any problems when flying 3s. I haven't changed anything about the ducting and it flies just great: Plenty of power, high speeds and I can let it go up vertically untill a complete stop (No throttle), after which it drops its nose and just flies off again.
I never fly with the droptanks, and I've never felt the need for a cheater hole.
On 2 cells; Meh... On 3 cells: Yay!
Hanzie
hanzie is offline Find More Posts by hanzie
Old Jul 01, 2012, 03:26 PM
UltraMicro is offline
Find More Posts by UltraMicro
UltraMicro's Avatar
United States, CA
Joined Jul 2011
I guess the cheater hole is for the people struggling on 2s but not wanting to up to 3s. I lean more towards scale than speed. I run on 3s so is so far fine.
UltraMicro is offline Find More Posts by UltraMicro
Old Jul 01, 2012, 06:54 PM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
You nailed it exactly, I'm already set on 2s, don't want the expense or hassle of swapping the ESC and getting new batteries. It's pretty close to where I want it on 2s, if a cheater hole gets me just a little more, great.
Old Jul 01, 2012, 07:18 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Took the drop tanks off the F-86 and went for a few flights. Ditching them made a noticeable difference. Lost the servo connecting rods on landing, but that's no big deal. Speed was a little faster, loops were nice. Still going to put the tanks back on for landings but it's nice to know performance picked up even more.
Old Jul 01, 2012, 08:45 PM
UltraMicro's Avatar
United States, CA
Joined Jul 2011
What batteries do you use? I use the Nano-Tech 370mah 11.1v 25c.
Old Jul 01, 2012, 08:48 PM
Joined Sep 2011
I am using the Turnigy Nano-Tech 460mah 3s 11.1v packs. love em
Old Jul 01, 2012, 10:12 PM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Put in the cheater hole, did two flights this evening. Doesn't seem any different, if anything, it's worse, it won't loop anymore. I think this is because the cheater hole is creating a low pressure area under the wing, once the plane starts slowing down on the up line, it doesn't have enough lift to push it over.
I'm bringing out the foam plug next time, and will do back to back flights with and without the cheater hole, but I get the feeling I'll be putting it back in.
Old Jul 01, 2012, 10:53 PM
Joined Sep 2011
Did you cut it as Joe instructed so it has the beveled edge in the back? Not sure why yours isnt showing much improvement. Maybe you should just jump to 3s?
Old Jul 02, 2012, 08:23 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Odd. Mine was a pig prior to the cheater duct. If you think about it, the cheater hole is behind the CG... so if there were a low pressure area, it would pull the tail under the centerline. In theory, it should aid in a loop. Hmmm..... oh well, there's always the exception so it's good that the panel can be put right back into place if it's not working for you.
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
