Old Mar 25, 2012, 02:37 PM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
I'd suggest at least flying the F-15 with the stock elevon configuration as a baseline, as it is a known, tested setup with no modifications required. Then do you your mods for comparison.
Originally Posted by Kevin Greene View Post
I guess that I'll just have to get one to show how well I can get it to fly...I'm running a 3.7g servo vs a 2g elevator in my MiG 15...The MiG doesn't even know the difference!!..The MiG 15 has three servos and is a single engine plane...The F-15 has two servos but twice the power...I know it's a larger model but I'll do several mods to lighten the plane up where possible...+, it looks like a Nip/Tuck is in order!!!
For me---The combination of mechanically mixing the ailerons and elevators spoils the true flight characteristics of the plane...I'll go conventional...If anything I have some 2g servos I could stuff in the wings for the ailerons...Elevators will get 3.7g servos...12amp postage stamp ESC's weigh next to nothing...Increased power consumption is a moot point with servos as small as these...
Kevin
fredmdbud is online now Find More Posts by fredmdbud
Old Mar 25, 2012, 03:20 PM
android78 is offline
Find More Posts by android78
Australia
Joined Mar 2010
F-15 looks to be FANTASTIC!!!...BUT, I really hate the hokey combining ailerons with the elevators thing...If I get one (which is more likely than not!!!) I'm thinking 3.7g servos for the ailerons and running separate 3.7g servos for the elevators..Since I'm a die-hard 4S guy with these birds I'm thinking that this model won't even flinch at the few extra grams of a couple of tiny servos on 4S!!!...
Can't wait!!!
Kevin
The extra weight of servos probably won't make much difference on 4s, but I wonder if it could be even better to replace the servos centrally and use nylon flexible pushrods setup with standard aileron/elevator setup using two servos?
It seems to look nicer then the original picture, but quite toy(ish) with the over sized engines.
android78 is offline Find More Posts by android78
Old Mar 26, 2012, 03:18 PM
FedericoA is offline
Find More Posts by FedericoA
Italy, Sicily, Palermo
Joined Sep 2006
For the A 10 wich is the best 3s lipo to fit to get good balance speed and power with 10amps x2 esc ?
500 -600-800 3s.......20 30 40 c ?
FedericoA is offline Find More Posts by FedericoA
Old Mar 26, 2012, 04:38 PM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
For 3S, I would recommend ESC's with a rating of at least 12 amps.
I placed a Castle Creations Phoenix 10 (10 amp rating) in my F-18 and the overcurrent cutoff kicks in on a freshly charged battery.
Personal wattmeter tests showed an initial 12 amp pull from a fully charged 3S lipo with the 5 bladed fan rotor.
At my own risk, I disabled the over current protection.
I cannot speak to the best battery suited for your airframe. In my opinion the best way for you to go about it is:
1. Build the plane and determine what amount of weight can be used in the battery compartment to acheive balance.
2. Research your preffered lipo source for packs that will sustain your required full output (24 amps continuous in this case).
3. Determine if the lipo's dimensions will fit.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Mar 26, 2012, 09:19 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
It's amazing to think that the little 35mm fan pulls the same amps as a well balanced stock 50mm EDF on 3S!
Slaanesh is offline Find More Posts by Slaanesh
Old Mar 27, 2012, 07:03 AM
Joined Sep 2006
I heard that many people use with success 2x 10 amps ESC and a 3s 500-600 30c 0n 5 blade edf stock.....maybe a 3 blade is better ?
Old Mar 28, 2012, 09:20 PM
www.hobbyb.com is offline
Find More Posts by www.hobbyb.com
www.hobbyb.com's Avatar
Canada, BC, Vancouver
Joined Feb 2012
Hi there.
The F15 are available here. Will ship within 2 business days. Please check it out.
http://www.hobbyb.com/all-new-skyang...html?cPath=114
www.hobbyb.com
www.hobbyb.com is offline Find More Posts by www.hobbyb.com
Site Sponsor
Old Mar 29, 2012, 11:22 AM
tnt1106 is offline
Find More Posts by tnt1106
tnt1106's Avatar
Joined Dec 2011
Does anyone else flying the Mig 29 feel like it is woefully under powered? Mine also seems a bit loud fan wise, yet does not vibrate any more than my other J-power models. (2s pack 500mah) AUW of 158g. It flies fast enough just seems to have 0 thrust if you slow down to get back up to speed.
tnt1106 is offline Find More Posts by tnt1106
Old Mar 29, 2012, 02:46 PM
Joined Sep 2006
Can anyone tell me how does it fly the 35 mm F 16 ON 3S......I have nano tech 370 25-40 c...and 10 esc.....
Old Mar 30, 2012, 01:05 AM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Originally Posted by www.hobbyb.com View Post
Hi there.
www.hobbyb.com
ordered one, just couldn't wait!
Never seen hobbyb.com b4 hopefully they're in Canada
queadlunnrau is offline Find More Posts by queadlunnrau
Old Mar 30, 2012, 08:00 PM
Joined Feb 2012
Got your order. Thank you so much for your business. We will ship the F15 today.
www.hobbyb.com
Site Sponsor
Old Mar 31, 2012, 05:50 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
No "contact info", "shipping info", or "terms" on their website that I could find. I did some poking around, and it looks like their site is hosted in Hong Kong. Nothing wrong with that. I did some more searching and it seems that they are a new shop. No reviews or confirmation from other people to go on. Hope you guys that order from them receive it.
MegaTesla is offline Find More Posts by MegaTesla
Old Mar 31, 2012, 09:53 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
The stock status indicates they are new too. Still nothing wrong with that. I do hope they carry more and more supplies, not just airframes. We need good hobby sources. The RCG local says Canada, and I hope that doesn't hurt shipping to USA.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Mar 31, 2012, 02:08 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
I sent them an email yesterday requesting information about their location and length of time they have been in business.
When/if I hear from them I'll post it here.
g
giuseppi is offline Find More Posts by giuseppi
Old Mar 31, 2012, 02:28 PM
Luck is my skill
Joined Jun 2009
I'm the guinea pig!
I'm normally really cautious on who I order from, research new company reviews and such, but I just have to have the F-15 that bad. I love the Eagle, but only want EPO frames.
I ordered it from Hobby B, so far things look good, but still don't know if his shop is in Canada or China (Doesn't really matter, but from Vancouver Canada to Seattle is quick)
I'll report a review once the jet arrives, if it doesn't I'm not too worried, I've lost more than $109 at the Casino's.
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 10:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 06:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 03:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 06:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 07:30 PM
