Old Feb 05, 2012, 09:01 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Here's a video with my Mig on 2S 800mAh. A bit nose heavy perhaps - but I think I'll try to trim the ailerons up a bit more - I really don't think the elevators are effective at all.
Skyangel / Hobbyking Nano Mig-29 - Trying the C/G a Bit Further Forward (4 min 56 sec)
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Feb 05, 2012, 10:02 AM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Maidened my A10 (finally). Used a hyperion 2S 850mah 25c, all the way forward for the proper cg.
I used the landing gear. I had a little problem with the motors being out of sync. Had to re-set the esc throttle tx 2 times before it worked correctly.
1st flight she needed about 7 clicks of right aileron trim. Using high rates and 25%exp. Fun little flier. I am flying with the bombs, so prolly not as fast as she could be, but still very zippy.
My first landing tore off the radar and front cannon. I'm not even gonna bother to reattach.
I only flew for 3 minutes (new batteries) and came down with 3.93 in each cell left over.
I tried to use smaller batteries but she really needs (at least mine) the weight of the 850's all the way forward.
I also had 2 more flights w/ the F86. 2S 325mah 65c thunderpower. Fun, but I will probably go to 3S soon enough. It always seems on the edge of a stall during turns.
My Mig 29 was going to get flown too, but I broke a control horn during the pre-flight checks. I was glad it happened on the ground. Anyone have an idea where to get some micro-control horns and hardware????
wavekatcher is offline Find More Posts by wavekatcher
Old Feb 05, 2012, 10:40 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Wave that sounds good hopefully getting mine in a couple weeks. I have several 500 mah batteries so hopefully they balance out. Got some 850 3s batteries, has anyone tried 3s in the A-10?
IndyMatt is offline Find More Posts by IndyMatt
Old Feb 05, 2012, 10:55 AM
Joined Mar 2011
3s will work w/ the motors, but not the stock esc's. The escs will fry.
Old Feb 05, 2012, 11:04 AM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Originally Posted by Joe 1320 View Post
That's all good stuff, but the kiss method can't put a number on it. Oh well, sounds like it will hold.
The motor really is so cool that it really isn't worth the effort...For grins and giggles I'll break out the hand held IR thermometer and check it...Like all of the cheap IR thermometers it is permanently set for an emissivity setting of 98---Which is what human skin is...If I don't get any reflectivity then I may be able to get a somewhat accurate readying...I'm thinking of coloring the can with a stripe of black from a Sharpie...Since this is one of the cheapo IR thermometers just like almost everyone has (Isn't emissivity adjustable) the readings will be ballpark at best....(+ or minus 10 degrees is HUGE!!!) That's why I don't hold much faith in the readings posted here on RCG as it really takes training with one of these to get accurate readings...
I'll see what I can come up with...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Feb 05, 2012, 11:35 AM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Originally Posted by Azn_Ace View Post
Given this Art Tech "v2" has come out, how come no one is flying those instead?
Can you post a link?
g
giuseppi is offline Find More Posts by giuseppi
Old Feb 05, 2012, 09:24 PM
MNadMan is offline
Find More Posts by MNadMan
Add Lightness
MNadMan's Avatar
Joined Dec 2011
http://www.youtube.com/watch?v=xLi0ckKirUQ
Brian, nice video!
Floats pretty slow even with that 800mah in it. I just ordered a couple 500mah 2s for mine.
Will be interesting to see what more aileron throw will do.
I'm going to also want to play with mine and see what works best. also try full tailerons and for sure thrust vectoring.
MNadMan is offline Find More Posts by MNadMan
Old Feb 05, 2012, 09:39 PM
gionir is offline
Find More Posts by gionir
The stalling italian
gionir's Avatar
France, RA, Lyon
Joined Jan 2011
Guys, I finally received my hawk kit from HK.
As I don't have the manual, could someone please post the position of the CG?
Many thanks!
G
gionir is offline Find More Posts by gionir
Old Feb 06, 2012, 03:35 AM
weetsie is offline
Find More Posts by weetsie
>_>
England
Joined Oct 2008
hi, does anyone know if this ESC can handle the rpm of motor in the 35mm bae hawk on a 3s?
i bought an 18A esc as i can use it for another project and as its not much bigger and only a few grams heavier i thought it would be fine but it didnt cross my mind if the ESC could handle the crazy RPM of the "9000kv" (cant be right) motor on a 3s or not.
the plush 10A esc's which i read work well are available on ebay in my country so i will just buy one of those if anyone knows that the 18A esc isnt going to work.
weetsie is offline Find More Posts by weetsie
Old Feb 06, 2012, 03:50 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
yes, the 18A will work easily.
I have not heard of anyone actually having a 9000kv motor yet. Mine all measure around 7000kv.
NitroCharged is offline Find More Posts by NitroCharged
Old Feb 06, 2012, 01:15 PM
Azn_Ace is offline
Find More Posts by Azn_Ace
I feel the need...
Azn_Ace's Avatar
Orange County
Joined Feb 2011
g
http://www.bananahobby.com/2244.html
Azn_Ace is offline Find More Posts by Azn_Ace
Old Feb 06, 2012, 05:03 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
I kind of like the Art-Tech F-86 more than the Great Planes version. The biggest issue is that it's a porky 140g RTF vs 67g... DOUBLE the weight! Though to compensate to a degree the Art-tech model is somewhat bigger at 45cm wingspan vs 38cm.
Other advantages are having 2x servos for ailerons, 3S battery and removable wing.
Having said that that it could easily shed some weight as you could lose those 8 magnets for the wing, and uses 1.7g servos instead of those beefy 3.6g servos. I bet you could save 10-12g with lighter servos and removing those magnets and not fitting the fuel tanks or wheels.
It looks like a better design than the J-Power model with more space in the canopy area for battery and RX.as well as a neat tube to house the aileron servo wires.
If I didn't already have the J-Power F-86 I'd snaffle up the Art-tech one - assuming I could get it here in Australia without paying squillions on postage! Maybe HobbyKing will stock them?
Slaanesh is offline Find More Posts by Slaanesh
Old Feb 06, 2012, 05:52 PM
Azn_Ace is offline
I feel the need...
Azn_Ace's Avatar
Orange County
Joined Feb 2011
I think a main advantage of the Art Tech version is the EPO foam (which is why it is heavier). This makes the plane almost indestructible vs. the EPS foam of the HH UM's. It also means it can fly better in windy conditions.
The main reason I like UM's is the "pick up and fly after crash" characteristic. Otherwise I have plenty of other jets already in my stable...
Old Feb 06, 2012, 06:25 PM
Joined Mar 2007
I agree with your ideas for mods...Too bad we can get one as a "Kit Only" with only the fan and motor like the SkyAngel version.....The one thing that I don't like about it is the weight as it weighs about the same as my SA MiG...I won't fly that one in my back yard as the landing speeds are too great...I have the GP Sabre ordered as the lightness/less mass will allow me to enjoy this from my back yard, flying from my back porch/patio!!!......
Kevin
Old Feb 07, 2012, 03:21 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
I wish I have not seen your post. After seeing your post, I did a search on the Great Planes micro jet and I am poisoned! The indoor flying clip looks great!
Now I wished I haven't bought so many Jpower micro EDFs!
miketre is offline Find More Posts by miketre
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
