Old Jun 17, 2011, 08:55 AM
CitizenKane is offline
Find More Posts by CitizenKane
United States, NH, Manchester
Joined Sep 2004
Complete Systems Have New Orange Rx
The complete systems have the new Orange Rx with the micro plugs instead of the Futaba pins:
http://www.hobbyking.com/unitedhobbi...dProduct=17300
The new Orange Rx by itself has not been released yet I don't think.
CK
CitizenKane is offline Find More Posts by CitizenKane
Old Jun 17, 2011, 09:06 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Sorry to nit pick, but it's not entirely certain the Rx supplied with the RTF sets is "the new Orange Rx with the micro plugs". The Rx shown on the HK site is the same one shown in the SkyAngel manual. There's nothing Orange about it I can see. It is possible there is a new Orange Rx with mini Futaba plugs which is different. It would be a natural product for HK to develop (or maybe rebadge this one) to go with their 2.2g servos.
So it is just possible there are two micro Rx going to be available. Either way it is good news.
CK
jj604 is online now Find More Posts by jj604
Old Jun 17, 2011, 09:31 AM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
does anyone know if a AR6400 (3.9g) with built in servos would fit in the F86? I was thinking running steel wires to the ailerons like the um P51.
Failing that I'm going for the orange rx http://www.hobbyking.com/hobbyking/s...dProduct=11972
but its 2.9g plus 2x1.5g linear servos = 5.9g so thats 2g more than the AR6400.
forgot to ask, does the hobby king orange rx run on the usual 6v unlike the ar6400?
green_flyer is offline Find More Posts by green_flyer
Old Jun 17, 2011, 10:40 AM
hooligan russ is offline
Find More Posts by hooligan russ
me, right now.
hooligan russ's Avatar
United States, NC, Clayton
Joined Nov 2009
Hey Green,
I'm Pretty sure it does run on 6v, just like the other orange Rx
Originally Posted by jj604 View Post
1) It won't. That Rx has standard "Futaba/JR" connectors.
2) There's a full static test run with voltage, current watts and thrust on 2S in my post #141. Haven't seen any good data for 3S yet. That's waiting for the experts who are anxiously waiting on their planes to arrive.
Thanks for the info John, I saw your 2s run up a few pages back resulting in 4.25amps. Looking forward to your 3s numbers to see just what kind of fire hazard I may be flying.
I guess the safe bet for the rx is to get the orange 4ch with some extra leads and plan on cutting the stock mini/micro-jst connectors off the aircraft and soldering on new ones.
hooligan russ is offline Find More Posts by hooligan russ
Old Jun 17, 2011, 12:41 PM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
Finally I had the time to maiden the F86. This was the kit version with Hobbyking servos. The links were at the innermost hole for the most throws.
My Jpower 35mm micro F-86 EDF maiden flight (2 min 51 sec)
miketre is offline Find More Posts by miketre
Old Jun 17, 2011, 12:52 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
http://www.youtube.com/watch?v=aD91ULez0FM
video is private
mcross is offline Find More Posts by mcross
Old Jun 17, 2011, 01:03 PM
miketre is offline
miketre's Avatar
Joined Dec 2010
oops. sorry.
Thanks for that. It is fixed now.
Old Jun 17, 2011, 01:47 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Gets around pretty well. What esc and battery are you using?
Old Jun 17, 2011, 05:01 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
Finally I had the time to maiden the F86...
nice video quick little f86!
Mine is done - Parkzone gear - flight report tonight
Ultra Micro Mig15 Parkzone Gear (0 min 19 sec)
just playing with the mixes
elvill is offline Find More Posts by elvill
Old Jun 17, 2011, 05:07 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
awsome work! i bet that puppy is LIGHT
corsair nut is offline Find More Posts by corsair nut
Old Jun 17, 2011, 06:50 PM
deadduck is online now
Find More Posts by deadduck
Manila Ninoy Intl, Philippines
Joined Nov 2001
Originally Posted by UNGN View Post
I will probably go with a an AR6300 in my PNP plane, too.
For anyone using the AR6300, you can order JST Servo plugs and some Heat shrink from Deal Extreme to swap plugs, being careful to ensure wire order is maintained (wire colors may or may not be correct).
I just fitted an AR 6300 to a Mig (ARF version with battery). The stock plugs on the servos are wired wrong, and the stock plugs don't fit into the 6300. Which saved me from blowing something up.
I released the pins and fitted them into Spektrum micro plugs, with the wires in the correct order for the 6300 (ground is in the middle).
All working, with no magic smoke released.
deadduck is online now Find More Posts by deadduck
Old Jun 17, 2011, 07:22 PM
Joined Nov 2001
Stock Battery Info ( the one that comes with the RTF and ARF versions).
2S - Red JST plug
350mah 15C (official factory specs)
Size. 40mm x 25mm x 15mm
And it's a TIGHT fit into the batt compartment.
Weight. 26g
The nanotech 370 2S ( 63x32x9mm) probably will not fit, too wide at 32mm vs 25mm
Better choice would be the Rhino 360 2S at 43x15x21mm - should drop in if the dimensions on the HK website are correct.
Old Jun 17, 2011, 07:25 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Noticed the ARF version of the MIG back in stock this afternoon. Pulled the trigger and added the Turnigy and Rhino batteries. Also picked up the air frame parts for the MIG (still no canopy) and the F86. Buying everything (except the horz. stab for the F86) via the "combo" links saves a few bucks. A $32 ARF turns into a $100 order. Keeping these things close enough to see is gonna be a problem
Tim Wolff is online now Find More Posts by Tim Wolff
Old Jun 17, 2011, 09:59 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
It does. It fits easily.
But the cockpit area is undercut with a couple of grooves. You can get a wider battery in.
Old Jun 17, 2011, 11:23 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
success but at what price - CG?!
alright, alright just came back from the park, 4 packs through my Mig, in great shape considering how many times I stalled out trying to roll and loop. Trimmed up, she flies true tracks easy, super twichy though need to dial down ailerons or to outer holes. elevon function doesn't really work, nice elevator is strong. Good control decent power but not exciting and very small flight envelope = high throttle, low run time, too slow you stall easy, only big loopy circles
CG is forward of battery bay!!! only way I got it trimmed up was with lipo taped to front. hatch no attached. will try to remedy but with all the weight savings cg is far forward of original going to try to fix it without cutting. maybe bombs will help
For how well this mig flies there is no aerobatics... Overall I think the gear is overdoing it and the foam is too heavy. Using this 35mmEDF+ar6400L+6Aesc+2s360Rhino (No As2000l's) combo - One could build a smaller MUCH lighter (less detailed) EDF delta elevons on the wings that would easily be aerobatic!
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
