Old Dec 12, 2011, 01:10 PM
MNadMan is offline
Find More Posts by MNadMan
Add Lightness
MNadMan's Avatar
Joined Dec 2011
ordered mine the same day. got the shipping notice last night. +1 for you
MNadMan is offline Find More Posts by MNadMan
Old Dec 12, 2011, 01:44 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Saw a guy in the 50mm forums turned his f-18 into a pusher and flies well.
Well i'm a bit tired/upset with my second F-18 as it's hit or miss on flying well, I think I'll turn it to a pusher, I'm new to EDF's and never had a pusher, so this will be a good experiment for me.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Dec 12, 2011, 03:48 PM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
once again I learn the hard way that you dont get something for nothing. I can confirm that the little C05M from the 27mm AEO fan is overloaded by the stock JPower 5-blade fan. It was a rushed test with a 2s down to 7.75v but still I could only acheive a wheezy 44g thurst (5.8A). Swapping to a JPower fan & motor with same battery I got 60g thrust.
I guess I'll put it back into a 27mm fan and use it in a Mig 29 when those become available.
There's a good reason the JPower motors are bigger and heavier to turn that 5 blade fan, just took me a lot of testing to accept that.
green_flyer is offline Find More Posts by green_flyer
Old Dec 12, 2011, 07:59 PM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Originally Posted by miketre View Post
here you go
I'm relatively new to this hobby and don't have much knowledge on these things. Is a negative tail incidence one where the leading edge of the elevator stab is lower than the trailing edge? My Mig29 looks like this.
Is this supposed to point the nose up (not enough tail incidence?) ?
Wow! that is a lot of expo! Was it too nose heavy with the battery all the way to the front? Was it as floaty?
And how did you get 6 min? I feel the dip in power when it is near the 3 min mark and land immediately. I fly over 60% throttle most of the time.
Thanks Mike! I appreciate the help.
wavekatcher is offline Find More Posts by wavekatcher
Old Dec 12, 2011, 11:51 PM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
After the maiden nose dives,I actually tried a tail heavy CG where if I point the nose up by a bit, it goes into an unrecoverable stall. No down elevator is going to point the nose back down again. I moved the CG slowly forward, tried, failed and repeat till I arrive at the current CG.
I'm not going to fix it. I really like how it handles now. If anything, I want to know what is causing it so that I can replicate it on the A-10!
Hey Mike
Sorry if you've already posted it; but where did your COG end up for the Mig-29?
Cheers
Dave
Goody63 is offline Find More Posts by Goody63
Old Dec 13, 2011, 12:23 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
Originally Posted by Goody63 View Post
Hey Mike
Cheers
Dave
It's just 1mm - 2mm forward of the recommended CG in the manual.
I didn't measure it exactly. What I did was mark the recommended CG on the plane with a pen and remember where my eventual CG is relative to that mark.
miketre is offline Find More Posts by miketre
Old Dec 13, 2011, 04:22 AM
London, UK
Joined Nov 2008
anyone want to sell me a JPower 3-blade prop they dont need?
Old Dec 13, 2011, 02:42 PM
Joined Mar 2011
PM me you address and I'll send you one or 2?? Wavekatcher
Old Dec 13, 2011, 02:52 PM
Joined Mar 2011
F16 maiden
Real cold this morning,(for California) but got a couple flights in on the Nano F16. All stock pnp version from HK.
Using a HK R415 rx and Hyperion 2S 450mah 25c batteries. Cg per the manual.
Full throttle and a powerful overhand launch and she was off. No trim required at all. I have elevons setup w/ my DX6i, (Thanks Miketre for the elevon throw bug fix link) Rolls are crazy fast on high rates. Loops...eh not really.
Pretty easy to land w/ no damage. Overall, I am impressed. Most likely will want to do the 3S upgrades for this airframe eventually. Thanks to everyone for the help
Old Dec 13, 2011, 04:25 PM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
The Mig-29 is here!! I also got a slip in the mail today saying that the box withmy orange/compatible Rx is waiting for me at the PO.
The Mig looks great. Some warping but not nearly as bad as the Mig-15.
MRGTX is offline Find More Posts by MRGTX
Old Dec 13, 2011, 06:03 PM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Originally Posted by wavekatcher View Post
... got a couple flights in on the Nano F16...Rolls are crazy fast on high rates. Loops...eh not really.
I had an Icarus SU-27 with the same dual aileron/elevator set up, and it responded the same way. I disconnected the ailerons and just used tailerons. Rolls were slower, but still good, and it would then loop. I'm thinking that just using tailerons on the F-16, with a lot of throw and expo, might work better than the stock set up.
Angelo is online now Find More Posts by Angelo
Old Dec 14, 2011, 01:16 AM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
If it was me I'd change the ESC's straight away. Put the Rx underneath between the nacelles then you will have the whole battery tray free for a decent 3S lipo.
Let us know how you get on
ozzi supercub is offline Find More Posts by ozzi supercub
Old Dec 14, 2011, 03:07 AM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
Originally Posted by NitroCharged View Post
All you have to do is ask and I'll do it. I welcome any suggestions on any item that may help the Micro EDF scene.
http://www.shapeways.com/model/39618...tor_mount.html
I recently ordered 3 units and got a message today saying they have gone into production. Was wondering if anyone else has received theirs and can comment on how they turned out?
NitroCharged - presumably you got some production samples to check the manufacturing process/service, etc? Have you installed a motor motor/fan? Any photos to show?
Jacques
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Dec 14, 2011, 08:39 AM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Mine came in last night, havent had time to mess around with it yet, but overall looks good! A bit of warping on the vertical stabs, but not too bad.
Ive got a full extra kit that will get a custom paint scheme. Boy these brushless motors are small!
JGuilty13 is offline Find More Posts by JGuilty13
Old Dec 14, 2011, 09:10 AM
MNadMan is offline
Add Lightness
MNadMan's Avatar
Joined Dec 2011
jguilty13 ooooh verrry nice photos!
I like seeing the gear on too! I think it'd be much nicer to maiden it with gear on than hand toss.
I'm thinking about a 6ch Ar6110 as it is only 1.5g more (3.5g vs 2.0g) since I didn't get a hobbyking 4ch 415rx ordered. thinking about removing any weight from it and direct soldering the wires = no connectors. just three sets of wires on this little birdy I believe. that's 9 wires to soldier.
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
