Old Dec 03, 2011, 11:58 AM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
KP32mm EDF Unit
This is what's going next in my Mig-15. Specs as folllows:
Bore diam: 32mm
Outside diam: 33.5mm
Length 47.5mm (71.2mm with bellmouth intake, which is removable)
Weight incl motor: 26.5g.
It has a Feigao 7350KV motor. Can looks to be 30mm long.
Manufacturers tests:
2S 350mAh: 6.73V 4.1A 68g thrust
3S 400mAh: 9.91V 7.8A 130g thrust
Those tests are probably on older Lipos, as there looks to be some voltage sag. my readings should be higher on modern packs (using 325mAh 65C TP).
Has anyone weighed the the stock unit? Interested to know how it compares.
Will update once tested.
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Dec 03, 2011, 12:04 PM
fly time is offline
Find More Posts by fly time
Electric flyer
fly time's Avatar
Renton, WA, US
Joined Oct 2007
Originally Posted by miketre View Post
I programmed spoilerons on it, but the landings were still pretty hot.
Spoilerons will decrease lift and require that you fly faster to stay in the air. You should try flaperons. They will be just as effective at increasing drag, and will lower the stall speed a little. Watch for tip stall though!
fly time is offline Find More Posts by fly time
Old Dec 03, 2011, 01:42 PM
Angelo is offline
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Where did you get these? How much?
Angelo is offline Find More Posts by Angelo
Old Dec 03, 2011, 01:52 PM
toxaq is offline
Find More Posts by toxaq
New Zealand
Joined Aug 2006
Flew my F86 again yesterday, second time, still as much of a rush. The first flight bender from 30m doesn't seem to have affected it. Found a nice new field which gives me a much better angle for landing the plane on and so got in some nice landings. Saved the flare right until just on the grass, sweet. Got a loop and some rolls in so feeling comfortable with the speed and size. Flying around 50% throttle mostly, will wait for a wind free day to try WOT passes...
@angelo I think I get what you're saying and we're just using different terminology/syntax. The flight yesterday was perfect for me, I wasn't thinking about dialling in any rudder at all, so it was just technique I think.
@miketre Damn! That A-10 gets off the ground quick!! I notice with your spoilerons it seems to sit nose up, surely if you went flaperons you could do that classic A-10 tank killer, nose down, cannons blazing low pass? Like this...
@nitroChared Double-dare? Physical challenge!
toxaq is offline Find More Posts by toxaq
Old Dec 03, 2011, 02:31 PM
Joined Oct 2007
30, here in the UK, available from Sams Models:
http://www.samsmodels.com/site/electric.html
(See about 2/3 down the web page)
Jacques
Old Dec 03, 2011, 03:39 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Spoilerons decrease lift at the same AOA, but can allow for a higher AOA without tip stall, thus increasing lift & drag and allowing for a slower, stable flight speed.
You only have to "fly faster" if you maintain the same AOA... so you increase the AOA to compensate.
UNGN is offline Find More Posts by UNGN
Old Dec 03, 2011, 05:41 PM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
not sure if I mentioned this - I could not get airborne from the runway on 2S. The fixed gear does not track straight the plane will hit the grass on the left of the runway.
@fly time - It felt exactly how UNGN described - higher AOA for slower flight.
You've got to get that Mig on 3s, a Mig 29 slower than an A-10? That just ain't right!
Lol! I know! The Mig29 flies beautifully slow, while the A-10 will tip stall before it reaches that speed. So i thought I'd leave the slower setup as it is. However, I may do a temporary swap of ESCs and grab some videos just to see how it is like.
miketre is offline Find More Posts by miketre
Old Dec 03, 2011, 06:32 PM
PositivelyJoe is offline
Find More Posts by PositivelyJoe
add lightness
PositivelyJoe's Avatar
Big time Minneapolis, Good Ol' St Paul
Joined Oct 2007
wow that A-10 is darn fast. need spoilerons, flaps, add a full load of scale missiles, bombs, landing gear legs, etc. need to weigh that sucker down. maybe it needs retracts. anyone make 35mm edf re-tracts yet?
Can the A-10 and MiG-29 do rolls? loops? hows the vertical climb out power?
and when does the MiG-29 get thrust vectoring?
PositivelyJoe is offline Find More Posts by PositivelyJoe
Old Dec 03, 2011, 06:39 PM
toxaq is offline
New Zealand
Joined Aug 2006
Dunno but I'm keen! Saw some cool little ones made out of lite-ply, I assume for indoor models, so it's possible. Would love retracts!
Old Dec 03, 2011, 06:50 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Originally Posted by gionir View Post
Dave, you are mean! What is this fan you just finished? A 40mm clipped? Something different and new?
I need to know more!!
Yes, the rotor I have on the stock fan right now is a clipped GWS 40mm with 3 blades removed. The larger outrunner has all 6 blades.
Originally Posted by ozzi supercub View Post
I dares ya!
I double dares ya!!
Check 1...
Originally Posted by Strike3 View Post
You don't need to be dared.... it will happen, just like it did with the Mig15
FAIL!...
Originally Posted by giuseppi View Post
Nitro,
I double dawg dare ya'
g
Check 2...
Has anyone weighed the the stock unit? Interested to know how it compares...
Stock fan unit weighs 13g.
Check 3...
It's on...
NitroCharged is offline Find More Posts by NitroCharged
Old Dec 03, 2011, 07:17 PM
add lightness
Joined Oct 2007
will this 12a esc's work for 3s on the A-10 & MiG-29?
http://www.hobbypartz.com/60p-dye-1014-12a-esc.html
Old Dec 03, 2011, 07:49 PM
miketre is offline
miketre's Avatar
Joined Dec 2010
Rolls are no problem at all.
My mig29 on 2s can't do loops, it would stall going up.
Never tried a loop on the A10 on 2S. I think it should be able to.
A10 on 3S goes vertical and opens up the flight envelope. Immelmanns, split S - but the camera man lost the tiny plane on the viewfinder.
Old Dec 03, 2011, 08:24 PM
splitpilot is offline
Find More Posts by splitpilot
splitpilot's Avatar
trying to catch Mr. FrSky... It flyes
Joined Jan 2005
Ill practice filming with flyes @ home just before I get the A10,
splitpilot is offline Find More Posts by splitpilot
Old Dec 03, 2011, 08:26 PM
splitpilot's Avatar
Joined Jan 2005
BTW, Are you using the buffalo's??? And the amps!!!!
Old Dec 03, 2011, 11:48 PM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
A10
Sweet Jesus Mike! That A10 is fast (I just looked at the video!). Look what you have done! Me wants one now! BTW Where are you flying at in the video? My club field doesn't have any runway. I'm jealous! Marty
martys is offline Find More Posts by martys
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
