Old Jun 14, 2011, 11:48 PM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Good news on the parts. More good news is from my crude static thrust testing, in which I simply hold a models exhaust 6" over the middle of a digital scale and throttle it up. The number recorded by the scale is noted by me as a crude static thust measurement.
In this case, the little MiG-15 put out a peak of 69g and a sustained average of 65g static thrust using a NanoTech 370mAh 2s battery. I think that sounds reasonable considering the flying weight of around 100g.
Other news regards the 3s thrust test, in which I hooked up a Rhino 610mAh 3s lipo and gradually throttled up using my thrust test procedure. It peaked at 80g of static thrust at around half throttle before the fan started to slip on the shaft.
I throttled down and inspected... no damage other than the fan loosening. It looks like this little bird might be a better stock flyer than people are thinking at the moment.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Jun 14, 2011, 11:55 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Is there no horizontal stabilizer/elevator listed in the spare parts? I don't see one for either.
g
giuseppi is offline Find More Posts by giuseppi
Old Jun 15, 2011, 12:14 AM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
MiG-15 tail vertical and horizontal are there, as well as the F-86 parts. Search '35mm EDF' on the side bar and they just pop up in a list underneath if you wait a second or two.
I believe the horizontal tail pieces are shared between the models, as only the MiG-15 horizontals are available.
Cheers - boingk
Old Jun 15, 2011, 12:32 AM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
I was thinking they may be shared but they are not. They are different however you could probably modify them for use on the F-86.
The Mig-15 canopy is also currently absent though I'm sure these bits will turn up.
Slaanesh is offline Find More Posts by Slaanesh
Old Jun 15, 2011, 12:52 AM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
Originally Posted by NitroCharged View Post
22 bucks to get the parts inc shipping!
you've gotta be happy with that
gazza2003au is offline Find More Posts by gazza2003au
Old Jun 15, 2011, 02:14 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
yes, got all the parts (minus the canopy) ordered already. I want to make an indoorsie one.
Mig 15 35mm EDF Micro Jet Vertical Tail
Mig 15 35mm EDF Micro Jet Fuselage
Mig 15 35mm EDF Micro Jet Wing set
Mig 15 35mm EDF Micro Jet Horizontal Tail Set
I'm sure the canopy will get listed the moment my order ships.....
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 15, 2011, 02:49 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
I guess in small parts shipping should be also less ... I may think about ... as soon as I will see all parts available ...
Thanks for the links
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Jun 15, 2011, 05:45 AM
Sydney, Australia
Joined Jul 2003
comeplete RTF just showed up guys what a bargain http://www.hobbyking.com/hobbyking/s...dProduct=17300
Old Jun 15, 2011, 05:50 AM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
Going to try again are you gazza?
ozzi supercub is offline Find More Posts by ozzi supercub
Old Jun 15, 2011, 05:54 AM
Sydney, Australia
Joined Jul 2003
haha i should but... im going to wait see if anyone else can get these flying and depending on how they perform i may get the mig kit version ive had 3 sabres dont know what made me pick the last one over the mig but again i still couldnt get it flying lol
Old Jun 15, 2011, 07:38 AM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Hmm... thinking heavily about ordering another MiG to make into a speedster... must... resist!
- boingk
Last edited by boingk; Jun 15, 2011 at 08:01 AM. Reason: Confounding variables made me indeterminate.
Old Jun 15, 2011, 07:49 AM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Blah! I'm really weary about cheapy transmitters!
I got one with my P-51 about a year ago - and wanted to use it as a take anywhere plane - but the transmitter was awful compared to a good quality set of controls!
I'm hoping I get my F-86 by the weekend so I can give it a go.
Old Jun 15, 2011, 09:30 AM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
PZ Brick Mig
heres my gear, mixed and ready to be installed - super lite PZ Mig. simple setup. Hows that for weight savings. Come on good weather... using a smaller gauge wire for tail controls, already redoing hinges so no biggie, bigger ailerons want this thing to turn on its side and roll without tooo much loss in elevation probably dreaming but we'll see
elvill is offline Find More Posts by elvill
Old Jun 15, 2011, 05:24 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
15-Jun-2011 Australia Arrived and is being processed.
15-Jun-2011 Australia Pending customs inspection.
15-Jun-2011 Australia In transit.
Crikey! Still not here.... I guess tomorrow if I am lucky.
Old Jun 15, 2011, 05:36 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Got mine today. F-86 came assembled, Mig did not. Both look straight. Took a fan out and apart, looks well designed and well built.
Hmmm, motor hole in the shroud is 10mm, I think it wants a Blowdart motor.
mcross is offline Find More Posts by mcross
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
