KP 32 EDF Unit
Has anyone tried the KP 32mm EDF unit in one of these?
Any thoughts on whether it will work/fit? Link to a UK supplier's site (see about 2/3 of the way down on this page): http://www.samsmodels.com/acatalog/S...ric.html#a2399 I've just ordered one! Jacques |
Joined Nov 2007
Every A-10 I've flown responds very well to "spoilerons". it will slow it up and pitch the nose up a bit if that's what you were looking to do. not sure if your radio/rx allows for it. but makes them floaty float.
Australia, QLD, Toowoomba
Joined Mar 2011
well, i got out and flew my duct-modified 35mm T-45 on the weekend - just a few circuts, using a 360mah 20c 2s, and after the frustration of countless failed launches, this time, it flew. - i was amazed - and predictably, it flew just like it's bigger brother t-45's.
OrangeRx R415
Anyone have any luck with these Hobby King receivers?
I built my F86 today and tried 2 of the RX's with terrible results. Got em to bind and then they would lose signal. I would have to rebind every time I disconnect the battery. Using a DX6i. Anyone have any ideas? After I would get them bound to the Tx, remove the bind plug, and then try to get them inside the fuselage, they brown out. I tried everything I know except for putting them in another model. Maybe a bad plug on the esc? Thanks for any ideas. |
Joined Mar 2011
I'm sticking with the 6 channel caseless Tx as I plan to move my tiny brite lights warbird lights to the A-10. The 6 strobing gun lights will then be activated by the radio. I have not figured out which channel to plug in to. on the parkzone UMX, it responded to the 3 way flaps switch on the DX8 - All Lights Off, Nav Lights on, Nav Lights with Gun Lights. I hope to have both the lights and the spoilerons working. |
I like the saying "good parts aren't cheap and cheap parts aren't good". I'm used to spektrum rx's...bind once and no problemo. |
I have the receiver back facing up or side ways, so the bare part of it isn't touching any metal. |
Just a thought. If you bind the RX do not unplug and re-plug in components, especially the ESC. The original Spectrum DSM2 RX's lost bind if th ESC was unplugged. You did mention that you did the binding outside the plane, and then installed the RX, so just checking, do you leave everything plugged in after binding? The HK RX may do the same thing. I've been using several orange RX's and they have been working great (DX7).
Now I need to figure out the elevons w/ the DX6i for the F16 . Ive got everything running good, except pull back on the right stick and I get down elevons?? I tried to reverse the servos, no luck. Maybe they mismarked the wires??? |
New Zealand
Joined Aug 2006
Just bought 3 of these. F86, BAe Hawk and F18. Got a bunch of 3s 370 mAh and the orangeRx's. No trouble binding against my DX7i. Haven't range tested yet as I've been busy replacing the speed controllers with the Turnigy 10 Amp plush for each. Only the F18 didn't need any mods to fit the batteries and so far everything has balanced out well. F86 is the tightest fit, hoping the foam holds up...
Can't wait to fly these things! |
| Thread Tools | |
| Discussion Mini Mig-15 EDF from Hobby King | Dreamcatcher | Foamy EDFs | 6 | Jan 16, 2012 09:58 AM |
| New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan | Mikemynameis | Micro EDF Jets and Power Systems | 557 | Aug 18, 2011 05:01 PM |
| Build Log Hobby King Micro A-6 & F-86 Jets | tallflyer | Foamy EDFs | 4 | Jun 04, 2011 02:05 PM |
| New Product J-Power 30mm EDF Jets (F-86 & Mig-15) | xplaneguy | Foamy EDFs | 1 | Jan 16, 2011 05:59 AM |
| Park/indoor EDF F-86 and MiG-15 production news! | Thomas B | Parkflyers | 8 | Feb 06, 2002 06:30 PM |
