Old Nov 15, 2011, 05:40 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Originally Posted by giuseppi View Post
For any of you who get the 35mm EDF Micro Jet Fighter Parts (Nano F-16) and want to dress it up in the Thunderbirds configuration.
Print the sheet for the vertical stab @140% on clear waterslide decal paper.
For the underbelly print it to "fit the page" on 8-1/2" X 11" page size. It comes out @ 144%.
I find it easier to use a PDF with my printer but I also included the jpg if those are better for you.
g
Thanks!
MegaTesla is offline Find More Posts by MegaTesla
Old Nov 15, 2011, 05:57 PM
m_ark is offline
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
Originally Posted by MegaTesla View Post
Yes, these little outrunners perform well!
2S 370mAh Turnigy Nano Tech:
Low/Med: 80g @ 33W, 4.3A
High timing: 86g @ 35.4, 4.6A
3S 325mAh Thunder Power '65c':
Low/Med: 140g @ 78W, 7.1A
High timing: 145g @ 80.8W, 7.5A
This explains why my T-45 flies like crap - i'm only getting 60 grams of thrust WOT on 2s 500's 5 blade - (turnigy plush 6 amp esc)
i wonder where i can get an extra 20 grams thrust?
m_ark is offline Find More Posts by m_ark
Old Nov 15, 2011, 06:11 PM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
How did you measure the thrust?
Old Nov 15, 2011, 06:33 PM
m_ark is offline
Gravity sucks.
Joined Mar 2011
wide open throttle airframe nose down on gram scale (zeroed).
i also did a test that produced the same results with the edf out of the airframe facing down on a mount (open intake/exhaust) the gram scale (zeroed).
multiple tests, different 2s batteries (360, 460, 500mah) all full charged... results were always 58-65 grams.
2 different ESC's - stock esc and plush 6amp ESC.
Old Nov 15, 2011, 06:54 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Can you measure amp draw? I wonder if the kV is wrong on the motor...?
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 15, 2011, 07:20 PM
m_ark is offline
Gravity sucks.
Joined Mar 2011
I"ll try doing that tonight.
it sounds well smooth enough at wide open, no nasty vibrations... although there's a couple spots over the travel of it.
Old Nov 15, 2011, 08:54 PM
m_ark is offline
Gravity sucks.
Joined Mar 2011
will first double check throttle range is set right on ESC and there's no wierd throttle curves/endpoints on TX
Old Nov 15, 2011, 09:48 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
A-10?
Wonder what the hold-up is on the A-10??
Sammy70 is offline Find More Posts by Sammy70
Old Nov 15, 2011, 10:09 PM
Bajora is offline
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
Sorry Sammy ... I need to get servos and then get them all installed. Hope to get her aloft this weekend BUT they are calling for rain on Friday and Saturday here. Grrrrr!
Bajora is offline Find More Posts by Bajora
Old Nov 15, 2011, 10:13 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
No, I didn't mean you/your A-10 Jon, I meant in general. But I am looking forward to what you think about yours once you get it in the air
I figured these would be available for purchase by now...
Old Nov 15, 2011, 10:29 PM
Bajora is offline
KA6KHM
Bajora's Avatar
Joined Sep 2004
I figured that was what you meant Sammy ... but I thought I would play along a little with you. I am sure they will be along soon.
Old Nov 16, 2011, 02:05 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
Hi Jon, after you have maiden the A-10, can you share your thoughts on how it compares with the 50mm version?
I'm considering the 2. The retracts and the steerable nose wheel on the bigger bird is very attractive to me.
But I am curious if the 35mm A10 flies better out of the box than the 50mm A10, and if it can handle the wind as good as the 35mm Mig 29.
Thanks a bunch.
miketre is offline Find More Posts by miketre
Old Nov 16, 2011, 02:26 AM
m_ark is offline
Gravity sucks.
Joined Mar 2011
unsurprising surprising results.
Throttle calibrated - no crazy throttle curves or endpoints (100%) set.
Amp draw 3s 460: 5 amps WOT 90 grams thrust
Amp draw 2s 500: 3.5 amps WOT 55 grams thrust...
Old Nov 16, 2011, 03:54 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I think your 2S lipo's might suck .. got any with a little kick in them (high C rating - not from HK)?
Old Nov 16, 2011, 05:02 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Yeah, definitely sounds like it could be a rating issue. Try with a larger pack and see how you go. I ran my MiG-15 with a Rhino 3s 600mAh pack and it was a hoot!
Cheers - boingk
boingk is offline Find More Posts by boingk
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
