Old Jun 13, 2011, 10:45 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Gazza, the tail is correct.
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 13, 2011, 10:50 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Originally Posted by gazza2003au View Post
my all up weight is 126grams i will do some amp and watt testing shortly the CofG was correct at 59mm back
The advertised "flying" weight in the description is 100g. What does it weigh w/o the battery?
g
giuseppi is offline Find More Posts by giuseppi
Old Jun 13, 2011, 11:14 PM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
Originally Posted by akwardflyer View Post
will these fly on the rhino 360 2s lipos? or do we not know yet?
They do. My bud's using those batts of mine. It's a bit of a squeeze in the F86. Too bad they are out of stock. I ordered the flightmax instead.
My package arrived yesterday. Strangely, the F86 kit was assembled (except for the control rods). Im not complaining as i so not enjoy assembling. The mig kit came unassembled.
Now I just need to fix my DX8 antenna. It won't bind to new receivers after the wife accidentally had an accident with it. One of those situations that you can't get mad at.
miketre is offline Find More Posts by miketre
Old Jun 13, 2011, 11:52 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Mine weighs 92g with the FlyDream Rx and Thunderpower 325mAh battery. Could shave a couple of grams off by removing the balance lead and plug which are a bit of a nuisance to cram in at this small size.
Some test results in a few minutes. I just put the whole thing on my Medusa test stand to get some "in plane" static measurements.
John
PS While gluing the wing back on I noticed mine has significant WASH IN on both tips. Looks cool but it must be an accident waiting to happen. Might be worth checking before you fly.
jj604 is online now Find More Posts by jj604
Old Jun 14, 2011, 12:20 AM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
its a ARF/PNF model god knows why mine wont fly i moved the ESC way back got the canopy on and it still wont fly ive had enough of it this is my second micro jet the first was the EPP F4 another dud i hope u guy can get your sabres flying im giving up on mine http://www.rcgroups.com/forums/showt...5#post18495136
gazza2003au is offline Find More Posts by gazza2003au
Old Jun 14, 2011, 12:37 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Static Thrust test
Here's the results of a test run on the Mig15 using a new ThunderPower 65C 325mAh 2S.
Full throttle throughout the test. Battery barely warm at the end.
You would get at least a 4 minute flight at full throttle. More in practice as the fan unloads and you would not be flying WOT all the time. I think 6 minute flights are easily possible.
This is about 13C load and these new ThunderPowers hold their voltage well.
At mid test (just over 2 minutes):
Voltage is 7.2V (3.6V/cell)
Current draw is 4.25A
Static thrust is 59g for a 92g aircraft.
I made up some 18g leads for this test so voltage drops will be almost the same as in the airborne setup.
I'm no expert on small EDF's but this looks like a reasonably thought out 30 Watt power train for a commercial ARF/RTF offering this size. Presumably Mega and Nitro will have it doing 200kmh soon.
John
Old Jun 14, 2011, 12:48 AM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
*Ahem*
I'll buy it from you
I thought these were supposed to be about 95g ready to fly?
I think this is the problem - you really want it to be as light as possible.
Weight is a big issue with little planes.
I would use 2.5g servos, 6g ESC, 4g RX and about 20g max of battery.
Slaanesh is offline Find More Posts by Slaanesh
Old Jun 14, 2011, 01:06 AM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
These little models can test your patience. If I didn't have Nitrocharged here to advise it's likely I'd be doing the same. It really is a specialised field these tiny little jets.
ozzi supercub is offline Find More Posts by ozzi supercub
Old Jun 14, 2011, 01:13 AM
Sydney, Australia
Joined Jul 2003
u all make a good point i did use 3.6g servos instead of 2.2g i did use a 30g battery instead of 20g the extra weight can add up but i just dont get it the CofG is spot on as per instructions yet it wont fly i say good luck to who ever ends up with it my loss is your gain and i hope it flies well i think im just going to give up on all small jets unless i get someone else to test fly them for me in the future LOL
Old Jun 14, 2011, 01:23 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Sounds like the weight might be the problem as the fellows above have said. My bare airframe weighs 55g and components going in weigh 50g, for an AUW of 105g. Obviously thats without control horns and glue, but that shouldn't bring it up to more than 110g.
I'm using HK 'MiniMan' 4.3g servos, DSM2-compatible receiver (cheapo dual antenna one), HK SS 8/10A ESC and Turnigy NanoTech 370mAh 2s (26g!). The servos have their mounting tabs cut off but are otherwise unmodified. The ESC has had its heatsink and heatshrink taken off to help cut down on weight. The receiver is light anyway, but I'm most likely going to cut off the extra pins I'm not using.
One last thing, the figures above are without the included droptanks which I can only see adding weight and drag.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Jun 14, 2011, 01:25 AM
Sydney, Australia
Joined Jul 2003
Cheers - boingk
u will need that heat sink on the motor thats why NitroCharged glued it on
Old Jun 14, 2011, 01:27 AM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
To be honest, it's not as high as I thought it would be.
I would have thought a 35mm fan would have been pushing 70g+ even on 2S.
The GWS 30mm EDF can do ~55g on 2S!
I just bought Gazza's F-86. I'll use some lighter stuff on it and see how it goes.
Old Jun 14, 2011, 01:31 AM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Ah righteo. Personally I reckon a 4.5A static draw for a 8A continuous ESC should be fine.
Meanwhile the static thrust from my little 35mm/2s seems to be pretty good. Anyone else tested on NanoTech 370's?
- boingk
EDIT: Damn you Slaanesh... beat me to it
Old Jun 14, 2011, 02:39 AM
WiggleWiggleWiggle
South Australia
Is that the shortest amount of time you've owned a model Gazza?
Old Jun 14, 2011, 03:04 AM
Sydney, Australia
Joined Jul 2003
i think it is LOL i guess i just woke up in a bad mood and it all went down hill from there i was getting frustrated building the model i should have known at that point by the time i stopped flying it i was ready to pull my hair out i also went to the field twice today to fly the thing and my neighbour drove down there to watch the second time lol
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
