This thread is privately moderated by DoctorSpin, who may elect to delete unwanted replies.
Old Jun 08, 2011, 12:48 AM
DoctorSpin is offline
Find More Posts by DoctorSpin
cellulose laminate reinforced
Joined Mar 2011
mini quadrotor build
After perusing the fora,
I formed this amalgam of recommendations for a small quadrotor build
18-11 2000kv outrunners(10g)
6A Turnigy Plush ESC
4x2.5 props
3S 800mAh
There might be a problem with the BlueSeries ESC and the 1811/2000kv motors
I read of one user having rough motor starts with this setup
but they were very cheap (and in stock) so good for having a go
I will be checking the soldering
I thought the Plush were out of stock at the time I ordered but they were in stock when I looked later. Well I have ordered the BlueSeries now.
We will see.
3S 800mAh is great for me as almost everything runs on those around here
My order with HK all in stock as I write.
Herewith the buddy codes for your enjoyment.
3x2 Propeller (Counter Rotating) (5Pcs/Bag)
11311
2555FB17-8A23-433B-8A85-EC2EC652568C
3x2 Propellers (5Pcs/Bag)
11310
4ACAEB1C-5D1B-49E6-BD38-5C6A01F9FDD2
4x2.5R Propellers (Counter Rotating) (5Pcs/B
11312
8742CD24-6584-4440-9FAD-19C0189A4371
4x2.5 Propellers (5Pcs/Bag)
11312
E187EC19-97B0-47A5-9715-A803B4B3CE0D
18-11 2000kv Micro Brushless Outrunner (10g) x4
5358
7EDB0F8D-27B0-4520-9D4F-CF4047B93D12
HobbyKing 12A BlueSeries BL ESC+1A BEC x4
11429
E7FF683F-EA19-4EE3-A076-4BB91488A9B5
HobbyKing Programming card for BlueSeries ESC
13431
B59E7993-6169-45D6-AF0D-92790AEC5179
www.hobbyking.com/
hobbyking/store/uh_viewItem.asp?idProduct=
buddy.asp?code=
DoctorSpin is offline Find More Posts by DoctorSpin
Old Jun 27, 2011, 11:39 PM
Joined Mar 2011
HK Quad copter controller
so I got the HK quad controller ($30), back ordered it so I could get one when they came in again, duly shipped and all but arrived mis-assembled. The yaw gyro daughter board is flat face down off the edge of the mainboard
The funny thing is, the pins arent bent outwards towards the edge of the board as you would expect if it just got crushed in shipping (why you would ship a pcb assembly with a 90 degree stand-off daughterboard in a plain "padded" envelope and expect that to be ok I dont know).
Instead, the pins are bent *inwards* towards the centre of the board. The only way this could be like it is would be if it was assembled exactly as it is right now. This could have have happened if the 90 degreee pin row went in backwards and they bent the pins up to solder the other board to them.
Anyway, HK reckon I caused the damage so all I got was an invitation to return the goods at my own expense for them to look at. I have provided them with excellent photographs already so basically I give up and will just write it off. I will also try to repair the board. Not exactly disappointed in HK since any expectations I have are my own problem. Nevertheless, I see no reason revise their shabby reputation for qc/cs.
With that done and the hk board on the bench to have its 90 degree connector replaced, I saw that the KK 5.5d board is nearly ready but still open for pre-order so Ive jumped in and bought the package with the LCD and the XX-QuadX firmware (not the KR)
I like that the lcd is such a cheap option, I didnt hesitate.
I guess that will ship when its ready so in the meantime I hope to get the HK board working for some + mode fun
I chose X mode to get me started on the KK 5.5d not because I want it to be like the drone but because I think I prefer the x mode to the + mode aesthetically anyway. I will already be trying + mode with the HK board.
Im not afraid to reflash the firmware on these but may as well go with the supplied firmware to start with in the case of the HK board and start with the mode I want try first with KK 5.5d
Anyway, Im off to post in a public forum for the first time, heading over to the kk 5.5d thread to say gday
Discussion Mikrokopter / UAVP / quadrocopter / quadrotor build -- Part 2 Arthur P. Multirotor Talk 6375 Jan 01, 2016 01:26 AM
Build Log Brushless Mini Slinger Build+ bonus build rcspeedwings Flying Wings 0 Apr 11, 2011 11:02 PM
Discussion Mikrokopter / UAVP / quadrocopter / quadrotor build Arthur P. Multirotor Talk 16696 Nov 10, 2010 04:49 PM
Discussion Advice for a 30-40 cm size Quadrotor build RoyLB Multirotor Talk 11 Aug 01, 2010 02:20 PM
