Old Jun 07, 2011, 09:53 PM
mattyhawk is offline
Find More Posts by mattyhawk
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Turnigy T600 880kv Delta to Wye help
So I did a bit of a search, but wasn't finding adequate answers to my question in previous posts.
I have a Turnigy T600 880kv. It has 12 Tooth and 8 Mags, 8 Turns with a measured 900kv actual.
I was planning to rewind it to 500kv, but in my motor winding infancy, I realized it is a delta wind, so I could change it to a wye termination and get to about 550kv. This would work for me.
I took the motor apart tonight and came across something I'm stuck on. Hopefully I can explain myself adequately. I assume there is some directionality that the winds need to be oriented for wye terminate. It is easy enough to find out which leads are the start and finish of each wind, but how do I determine which end of the wind to use? Does it even matter? Do I just trial and error test it in various connections 'til I get it right?
Thanks for the help!
Some pics for your viewing pleasure:
mattyhawk is offline Find More Posts by mattyhawk
Old Jun 08, 2011, 01:02 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
I take it you are an EE of some kind?
edit June 09: oops, this is star -> delta, not delta -> star
The former Star-point connections are the Starts, the former battery-connectors are the Ends:
E1 connects to S2
E2 connects to S3
E3 connects to S1
You can play a bit with Delta/Wye using the winding diagram calculator, graphical output and you'll see the changes:
http://www.rcgroups.com/forums/showt...ght=calculator
Otherwise trial and error with an oscilloscope until you get 120degrees phase difference.
Vriendelijke groeten Ron
diy motor groupRC flight club
Drive Calculatordiy motor tips
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jun 08, 2011, 03:17 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Haha, nope, does a Biologist count?
E1 connects to S2
E2 connects to S3
E3 connects to S1
Excellent. Thanks!
Old Jun 08, 2011, 04:40 PM
Joined Feb 2001
Let's not open that can of worms, shall we? I can hardly handle having a resident geologist in this subforum.
... Excellent. ...
Alas, no I described changing from wye to delta, whilst you want to change from delta to wye. But I think you get the gist, even though you're not an EE, just reverse my instructions.
Old Jun 08, 2011, 05:50 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Let's not open that can of worms, shall we? :mrgreen: I can hardly handle having a geologist in this subforum.
LOL, does Kiwi know how you feel? ROTFL
I swear, EE's first class in college is "Intro to Life Science and why they aren't really scientists". My father in law is a retired US Navy R&D EE, and I get the same jokes from him. He like to joke with me how biologists are biologists because they are only good at memorization. Engineering is a thinkin' man's profession. So I tell him without me, he wouldn't know what genus and species of bird his widget just killed. Haha, good times.
Fortunately for me, he helps me quite a bit in the area of circuits.
Yeah, I saw that, but it still gave me what I needed to get started (in reverse).
I gotta borrow an oscilloscope from the lab downstairs and get on that. It helps I work with a bunch of engineers, but they are mostly structural, chemical and environmental. I'll say one thing about engineers, they have the best toys!
Old Jun 08, 2011, 05:59 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
You have six bundle ends on the 12 arm stator so it is a DLRK wind.
The six ends are gathered and joined as three pairs. And, of course, there is no Wye bundle.
Delta System (what you have now)
Point 1: Solder S1 and E3 together
Point 2: Solder S2 and E1 together
Point 3: Solder S3 and E2 together
Note: Point 1, Point 2 and Point 3 are connected to Electronic Speed Control (ESC)
To change that to the star or Wye system:
Star (Wye) System
Solder E1, E2, E3 together
Note: S1, S2 and S3 are connected to ESC.
Just to make sure we are reading from the same sheet of music, you can look at this kit motor assemblhy instruction manual:
http://www.micronradiocontrol.co.uk/.../KH-257D-1.pdf
And see exactly how the phases were wound and how they are terminated. The stator arms are arbitrarily numbered 1 through 12 in the instructions and you can see the which arm number each phase starts on and ends on. So if you separate your three pairs into six separate ends and use an Ohm meter you can check to make sure where the starts and ends are.
The attached image shows how I think you will find the motor to be wound but, of course, it may be different and this might not work for your.
But if it is the same then it is just a case of joining the three "End" ends together to make the Wye bundle and putting the ESC connectors on the three remaining "Start" ends.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jun 08, 2011, 08:40 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
That is some good stuff there Jack. One thing though, the designer of that komodo motor shows it in a 10, 14, or 16 mag motor by design. Would this turnigy not be in an ABCABCABC wind with the 8 mags?
Old Jun 09, 2011, 07:16 AM
Jack
USA, ME, Ellsworth
Joined May 2008
I missed the magnet count in the photo. But you're right, it probably is an ABC wind.
That manual at the link shows the ABC wind in Appendix II and also has the Delta and Wye terminations for it. It says it is for the 16 magnet install but it works with 8 magnets too apparently. So I think you can still figure out the starts and ends with a meter.
I guess the DLRK wind can only be done on the 12 arm 14 magnet motors. I'm still getting older and smarter on motors...
Jack
Old Jun 09, 2011, 09:49 AM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Sweet. Makes sense the 16 mag would be similar, didn't think about that.
I guess I have what I need to make this happen. Let's see what comes of it, shall we?
Old Jun 09, 2011, 11:05 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Good luck with it! We'll be looking forward to the details.
Jack
Old Jun 09, 2011, 12:31 PM
Joined Feb 2001
... I swear, EE's first class in college is "Intro to Life Science and why they aren't really scientists". ...
OTOH, I chose 'Signal propagation in nerves' as one of my MSc classes. A very 'mathy' model that is.
... I gotta borrow an oscilloscope from the lab downstairs and get on that. ...
Drive motor with a power-drill and it will act as a generator and connect to the oscilloscope.
Originally Posted by jackerbes View Post
... I guess the DLRK wind can only be done on the 12 arm 14 magnet motors. ...
Only because it's so by name/definition. 'LRK' stands for Christian Lucas @RCG (huge e-motor design @www.magnet-motor.com), Ludwig Retzbach and Emile Kuhfuss. They did the original diy brushless motors articles in the German ElektroModell magazine in 2000. And those motors had 12statorpoles and 10/14 magnetpoles.
Original ElektroModell LRK articles, translated into English
http://www.aerodesign.de/peter/
-> LRK English
-> 4 EM 2000 articels at bottom of page
Old Jun 10, 2011, 10:36 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
That looks like a fun class!
Following picture is for my reference. Testing the motor out tonight. Looks like this is going to be a simple as it gets.
Old Jun 11, 2011, 06:31 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Good for you, looking forward to hearing how that goes.
If you look at the different winding schemes for a 12 arm motor here:
http://forumrc.alexba.eu/nutpol_e.htm
The colors on that chart rank the different winds by how well they work, the key is:
"..black- does not work, blue - good combination, white - it works, red - it works, but not very well..."
So you'll have the red "it works, but not very well" wind. If you want to mess with the motor more to make it even better, you'll still have the option of going to 16 or 14 magnets and getting to the better winds.
If you like the lower Kv motor better, you can even get more power out of it by going to 16 magnets later. That will be more work though...
Jack
Old Jun 11, 2011, 10:07 AM
Joined Feb 2001
In fact, winding diagram does not matter, only the Start and End of a phase wire. What 'happens' between Start and End is not relevant for star versus wye.
Jack, that table is also available on Ralp Okon's diy motor building site
translate...www.powercroco.de
-> Construction
-> Combination chart.
Prettig weekend Ron
Old Jun 11, 2011, 08:19 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Alright, conversion went relatively smooth. I decided to just chance my esc and guess at the correct combination. I was relatively simple as there really are only 2 ways to separate the wires. Problem though, maybe you guys can help me decipher the following information.
Unfortunately I do not have a solid state adjustable power supply. I will get one eventually, but my batteries will have to do for now.
I also replaced the bearings with semi ceramics.
I took two measurements of the new KV.
V= 11.43
Io= 1.68V
RPM= 5400
V= 15.16
Io= 1.8
RPM=7150
I am seeing about 472kv and relatively the same Io, which seems wrong to me. That means the difference in KV factor is 1.92, and I was expecting about 520kv. I would expect the bearing change to help rpms and lower Io. Did I screw something up? Is it possible this is an esc issue? Maybe wrong timing? Thoughts?
For Sale Turnigy T600-880KV motor helifrek Aircraft - Electric - Helis (FS/W) 2 May 20, 2011 09:29 PM
Sold *** Turnigy T600-1100Kv for Trex 600 *** Rudderman98 Aircraft - Electric - Helis (FS/W) 3 May 19, 2011 06:19 PM
Sold *** Turnigy T600-1100Kv for Trex 600 *** Rudderman98 Aircraft - Electric - Power Systems (FS/W) 4 May 19, 2011 06:14 PM
Sold Turnigy 600 4030 880KV Motor Kwincy Aircraft - Electric - Power Systems (FS/W) 3 Apr 15, 2011 11:36 AM
Cool tool for changing numbers of winding and diameters wye/delta - delta/wye powerditto Power Systems 1 Nov 05, 2005 12:17 PM
