Old Jun 07, 2011, 02:25 PM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Cool
PYRC Yak 55 34" - Free Plans - Pics, Vids, Build
PYRC Yak-55 34"
After many changes and versions, I now have the (hopefuly) final version of my Yak. This Yak-55 has a 34" wingspan and is made from 9mm EPP (or depron) foam and its great for beginners to experts and people who fly giant scale gassers or Super Cubs.
Features:
Better servo/link geometry
More crash-proof design
Reduced airframe twist
Ultra-Easy assembly
Tab-Slot conctruction
Perfect for RCers on a budget
Added 'floaty-ness'
Better wind handling
Lots of side area
Designed with beginners and experts in mind
Reduced coupling
Awesome harrier stability
Perfect for learning 3D or as a practace plane for experts
Good aileorn trainer **When setup correctly
Easily flown in a backyard or cul-de-sac
Setup:
This plane is perfect for the 24g 1500kv motor from HobbyKing on a stick-mount. I have tried many servos on it, and this plane does not really care. Below, I put the 9 gram servos for outdoor flying and the 5 gram ones for indoor use. A good ESC is listed below. The battery choice really depends on what you want to be doing. I have used batteries as small as a 500mAh 2-cell and as big as a 1000mAh 3-cell. I would start with a 800mAh 3-cell battery for outdoor and a 800mAh 2-cell for indoor flying, at least for your first flights. It still keeps the weight low but gives you lots of power. Due to the slightly larger size, it still feels really floaty at 8oz. The foam can be picked up at Grayson Hobby. I'm using the 9mm white EPP in the 24" by 36" Sheets. My all-time favorite control horns for foamies are the laser cut plywood ones from Grayson. The holes are perfectly sized for the Nylon Kwik-Links. The 3mm (1/8th in) carbon tubes can also be orderd from Grayson Hobby.
Links,
24 gram motor
http://www.hobbyking.com/hobbycity/s...trunner_1500kv
Outdoor Servos
http://www.hobbyking.com/hobbycity/s...?idProduct=662
Indoor Servos
http://www.hobbyking.com/hobbycity/s...?idProduct=663
ESC
http://www.hobbyking.com/hobbycity/s...idProduct=6456
EPP Foam
http://www.graysonhobby.com/catalog/...f3d8b8368e7814
Control Horns
Pushrod Stuff
http://www.graysonhobby.com/catalog/...ded-p-949.html
http://www.graysonhobby.com/catalog/...be-p-1094.html
Carbon Tubes
http://www.graysonhobby.com/catalog/...0mm-p-938.html
Looking over the 3D files
PYRC Yak-55 34" in Google Sketchup (2 min 50 sec)
Attached to this post are the 3D model of the plane, what the plans should look like and a PDF of the plans for 11 x 8.5" paper. It prints out in 15 sheets.
In the next few days I will have some more stuff up here. Expect videos, more pics, the plans in more formats, and a build guide. -- 6-7-2011
PinkYakRC is offline Find More Posts by PinkYakRC
Discussion Baby SR-71 Blackbird, pics, vids and free plans! Rusty-Gunn Foamies (Scratchbuilt) 163 Jul 18, 2016 05:04 AM
Discussion DW Foamies Yak-55 48" Review/Build/Pics/Video PinkYakRC 3D Foamies 10 Jun 05, 2011 09:58 PM
Build Log The "foamyak" My 1st Build finally documented. With Pics and vids and some night fpv! handyfella Foamies (Scratchbuilt) 2 Mar 15, 2011 02:44 PM
Build Log Got parts from Hobby Lobby Yak 55, lets build a full fuse Yak 55 Lampatex Foamies (Scratchbuilt) 16 Jun 13, 2007 10:50 AM
