Old Jun 07, 2011, 02:05 PM
theleetbeagle is offline
Find More Posts by theleetbeagle
Flying Shoe
theleetbeagle's Avatar
Ohio
Joined Nov 2010
How Do I Simulate Single Engine Failure On Two Engine Plane?
I have plans to build a two engine plane similar to...well...anything. Like the Dynam Grand Cruiser.
I would like to simulate a single engine failure with the flip of a switch on my TX. How might I do that? Are there any devices made that can open/close a circuit at will like that? Made especially for RC?
Thanks.
theleetbeagle is offline Find More Posts by theleetbeagle
Old Jun 07, 2011, 02:10 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Might be able to accomplish it with some kind of mixing... It might be really dangerous to do it by actually cutting the power to the ESC/motor, but a servo-controlled switch could do that. You'd have to get the ESC armed to get power back to the motor, which may not work too well...
But maybe if you have one ESC connected to the flap or retract channel with a 100% mix, you could kill it be hitting the switch. Heck, you could even do BOTH if you had one on retracts and one on flaps, with both mixed straight to throttle
Piece is online now Find More Posts by Piece
Old Jun 07, 2011, 02:13 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
OH WAIT....
I actually had a throttle-cut switch programmed on one of my planes as an experiment. It was exactly what I just described, a -100% throttle/flap mix (or something close; I don't remember exactly what I used). It worked perfectly, but the switch HAD to be set right before powering up the ESC or it would do all kinds of weird stuff.
Hmmm... so THAT'S where that idea came from in my last post
Old Jun 07, 2011, 04:12 PM
Flying Shoe
Ohio
Joined Nov 2010
Hrm. If I understand correctly, you had the throttle of one motor on a separate channel, but mixed into the normal throttle channel (ie, ch3), which of course controlled the OTHER motor. So under normal circumstances ch3 controlled one throttle plus the mixed-in other throttle. THEN, you had the non-ch3 throttle on an on/off switch.
I think I've got it. Even if that's NOT what you did, I think it will work in my situation.
Thanks!
Old Jun 07, 2011, 07:15 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
I was only running one motor, but the mixing could be set up so that the "flap" channel is also controlling an ESC, but it's mixed linearly with throttle. So yes, you're absolutely correct (assuming we both know what we're talking about, which in my case is very unlikely... ).
Also, for the love of Pete, test these things with the props removed I ate a big hole through my mom's tablecloth while setting up that kill switch
Old Jun 07, 2011, 07:45 PM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
Put a switch (rated at the proper current limit) in the middle of one of the ESC to battery wires and attached to a servo on an auxillary channel.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Jun 07, 2011, 07:49 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
When it's time to turn the motor back on, though, he'd have to re-arm the ESC. Depending on the unit itself, that might require some kind of arming sequence with the throttle stick. Keep in mind that the other motor would be functioning normally, so that motor would be responding if, for example, he had to cycle the throttle stick. Even if it was just a zero-throttle delay period like the HobbyKing SS ESCs, that still means the plane would have to glide for however long it takes for the ESC to be ready to go.
The extra servo and the switch would also add weight...
Old Jun 07, 2011, 08:13 PM
AMA 537620
Joined Oct 2008
What good is simulating an engine out with the ability to turn it back on.
Old Jun 07, 2011, 09:11 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
What good is a simulation if it puts you in exactly the same situation as the real problem?
Old Jun 08, 2011, 11:57 AM
Sniperp is offline
Find More Posts by Sniperp
FPV addict
Joined Mar 2011
you could just use a simulator and practice a single engine flying so you dont smash your plane
Sniperp is offline Find More Posts by Sniperp
Old Jun 08, 2011, 12:01 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
Where's the fun in that? Besides, learning happens much quicker in the real world when you CAN smash the plane
Old Jun 08, 2011, 12:13 PM
AMA 537620
Joined Oct 2008
It's a good realistic one, that's what it is.
Old Jun 08, 2011, 04:37 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Assemble a GWS ME-262 with two 2028 3900K GWS motors snd two T-Bird 36 speed controls, won't happen right away but it will happen!
E-Challenged is offline Find More Posts by E-Challenged
Old Jun 09, 2011, 04:14 AM
Coenraad is offline
Find More Posts by Coenraad
Coenraad's Avatar
Norway, Akershus, Frogner
Joined Jun 2010
Get one angry farmer with a shotgun try to shoot at one of your engines?
In a serious note: Are you sure ... really sure you want to do this? RC planes have allot of power for their size. Wich would mean that if you turn off an engine at over lets say 20% throttle you run a high risk to pull the plane straight into a spin you can't just throttle yourself out of. Especialy since the blades won't feather and would increase drag even more.
Other then that i think you might want to try to set up a system that prevents the motor/ESC from losing power. As the ESC will need time to boot and count the cells. Also you need to keep 0 throttle when connecting the battery / re establish the power.
The easyest thing i think would be to put a switch between the engine and ESC with a servo. Thatw ay you keep power to the ESC but just take out the motor, that should work.
Coenraad is offline Find More Posts by Coenraad
Old Jun 09, 2011, 07:05 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Mixing can do it; similar to using mixing to get yaw from motors via rudder stick.
Use different chanel for on/off.
jrb is offline Find More Posts by jrb
Discussion How to reduce engine noise on electric RC plane? SamJolly Electric Plane Talk 38 Jun 02, 2011 02:39 PM
Question How do you reinforce your two piece foam wing? PilotKeeg FPV Talk 6 May 15, 2011 01:50 AM
Question How do you fly: thumb or with two fingers? Cyrus_ Radios 23 Apr 23, 2011 09:37 PM
Discussion How do I cover a balsa sheeted plane u2builder Scale Fuel Planes 5 Mar 14, 2011 04:01 PM
Two Or Four Brushless Motors On A Plane Do Need Two Or Four Brushless Esc's agapornis Power Systems 1 Jul 17, 2005 06:17 PM
