Old Jun 07, 2011, 09:11 AM
MaladroitFL is offline
Find More Posts by MaladroitFL
Flyin' low & slow T-28s!
MaladroitFL's Avatar
United States, FL, Vero Beach
Joined Feb 2011
Question
How to switch Rudder to Aileron Stick: DX6i
I just scratch-built an 16" wingspan, 3Ch bipe using an AR6400 Spektrum with a broken aileron port.
I just have the rudder and elevator on it, but would like to have the rudder work on the right-hand, aileron stick as it would work on any 3-ch like the Champ for example.
I have looked through the manual and also searched on YouTube, but found nothing.
Could anyone give me a quick, step-by-step that'll explain how to get the left hand rudder stick to also work on the RH stick, so it'll feel more natural to fly?
I am heavy-handed, (I.e. a klutz) so if I leave the rudder on the left stick I'll always be bumping the throttle up n' down.
Many thanks in advance!
Mac
MaladroitFL is offline Find More Posts by MaladroitFL
Old Jun 07, 2011, 09:25 AM
Tim B is offline
Find More Posts by Tim B
Pro Bro ozzy
Tim B's Avatar
United States, WY, Cheyenne
Joined Aug 2004
I hate to say it, but if your receiver is not working correctly or has a broken port; that's all you know of. I wouldn't fly it. I'd get it fix or replace it. Your receiver is an accident waiting to happen.
Tim
Tim B is offline Find More Posts by Tim B
Old Jun 07, 2011, 10:45 AM
Joined Feb 2011
That's not the issue at all, Tim.
I broke the plug off the brick that runs to the aileron servo in my UM T-28, so I am utting a new brick into the T-28 and used this brick for the Bipe project, since it doesn't need an aileron port (rudder and elevator controlled only).
So I just want to control the rudder with the aileron stick. Pretty simple and no major issues. No sense buying a new brick or bothering HH for this, I broke the port off when I cut too deep.
Everything works fine BTW...just would rather switch the control...
Old Jun 07, 2011, 03:04 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Why don't you just do an aileron to rudder mix on the DX6i?
Daedalus66 is offline Find More Posts by Daedalus66
Old Jun 07, 2011, 04:11 PM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
I'd send the receiver into horizon and see what they do. Otherwise:
disable rudder stick (optional):
MIX1 rudder -> rudder up -100% down -100%
Enable rudder control using aileron stick.:
MIX2 aileron -> rudder up 100% down 100%
I haven't tested this, but it should work.
creapyd is offline Find More Posts by creapyd
Old Jun 07, 2011, 05:20 PM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
You can reprogram the AR6400 to use the remaining port as a dual aileron. Then only use one port for the ailerons as before.
The AR6400 manual has a section on how to activate the unused port.
Regards,
Eric H.
Eric Henderson is offline Find More Posts by Eric Henderson
Old Jun 07, 2011, 09:00 PM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Ontario, Canada
Joined Apr 2010
I have an AR6400 in a scratchbuilt SE5a bipe. I used the method creapyd described to get the rudder servo to operate on via the aileron channel (RH stick).
Bottom line: You cannot change the channel assignment of the on-board linear servo's (elevator or rudder). Mixing via the radio is the only way to accomplish it.
philipa_240sx is offline Find More Posts by philipa_240sx
Old Jun 07, 2011, 10:04 PM
Tim B is offline
Pro Bro ozzy
Tim B's Avatar
Joined Aug 2004
Cool, I misunderstood.
Tim
Old May 27, 2012, 06:18 PM
jbrownskunk is offline
Find More Posts by jbrownskunk
Joined Feb 2012
ok i want to switch a 3 channel plane to use rudder on left stick instead of elevater rudder on right stick
jbrownskunk is offline Find More Posts by jbrownskunk
Old May 27, 2012, 06:42 PM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Move the servo wires on the receiver.
freechip is offline Find More Posts by freechip
Old May 27, 2012, 06:43 PM
freechip is offline
freechip's Avatar
Joined Aug 2008
Or create a mix aileron to rudder.
Old May 27, 2012, 06:59 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Unless you fly Mode 3 normally, the primary turn control should always be on the right stick. Rudder only goes on the left if turning is done primarily with ailerons. Otherwise, you learn bad habits that get in the way of flying a 4-channel model.
Old Jul 21, 2013, 02:09 AM
Raindrop is offline
Find More Posts by Raindrop
Joined Apr 2013
Thanks for helping me.
you guys are freaking geniuses. I was also looking for similar solution for my DX6i and Ember 2 and you solution sir; worked perfectly.
Raindrop is offline Find More Posts by Raindrop
Help! Spectrum DX6i aileron/rudder swap edi Radios 6 Dec 26, 2014 04:36 PM
Poll Spektrum DX8 | Rudder and/or Aileron Channel Centering Poll boltor Radios 133 Mar 09, 2012 02:06 PM
Discussion How are spoilers normally setup?: on a switch or on a stick/slider cmanley_nl Sailplane Talk 15 Mar 11, 2011 03:34 AM
Discussion 9303 mix-switch differing aileron-rudder coupling atjurhs Thermal 6 Apr 28, 2010 07:46 PM
Discussion Moving rudder control from left stick to right stick via radio switch churlock Radios 3 Nov 14, 2007 03:21 PM
