Old Jun 07, 2011, 06:18 AM
hypstar is offline
Find More Posts by hypstar
hypstar's Avatar
Sweden
Joined Sep 2008
Need Help! Futaba 10CG 2,4
Using my R617FS I`ll need help how to program...Mix and flaps and assigning a swith and so on,reading manual,but got stuck...I have 2 servo(ail)and 2 servo(flap)in my wing....exactly how?....I know!..But I`m New to this....
Thank`s...
hypstar is offline Find More Posts by hypstar
Old Jun 07, 2011, 06:30 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I think want you may need is to visit your LHS and or a club or location where flyers get together for you to get hands on experience.
Everytime my wife calls me from her work asking how to do something on the computer I always explain to her it easier and faster if I just go over and show her.
From the brief description of your setup of a 2 servo aileron wing with 2 servo flaps. That just seems like a normal wing with nothing to fancy about it.
Enable dual aileron wing type in your radio that will enable you to use differential wing and also enable flaps.
You should be able to navigate the manual knowing you need to look at the section reffering to dual aileron or anything reffering to differential and check out the section for flaps, it should tell you how to enable/program for it.
freechip is offline Find More Posts by freechip
Old Jun 07, 2011, 07:04 AM
hypstar is offline
hypstar's Avatar
Sweden
Joined Sep 2008
No LHS here,I know nothing fancy,but I`m new to this with flaps,witch switch is generaly use for flaps?
Tx.
Old Jun 07, 2011, 08:13 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Mine is labeled Flap switch but if your manufacturer does not label them as such then mine is located on the face of the radio above throttle stick where 2 switches are located and it's the one on the right.
Old Jun 07, 2011, 08:19 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Read your manual, on page 11 it shows the layout of the radio. Switch C is label for flap mixing. Most of your question you posted in the first post are covered in the manual and easily found.
Old Jun 07, 2011, 09:22 AM
DougV is online now
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
You can also check here: http://www.futaba-rc.com/faq/faq-10c-2_4ghz.html
Futaba does not label there switches because you can chose whatever switch you want, they are not hard coded like some JR radios.
Doug.
DougV is online now Find More Posts by DougV
Old Jun 07, 2011, 09:24 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Yes I should or said Futaba manual identifies switch C as Flap mixing but since you can assign the switch on that radio you can pretty much chose wich one you want to do what I guess.
Old Jun 07, 2011, 10:13 AM
hypstar is offline
hypstar's Avatar
Sweden
Joined Sep 2008
Thank`s guyes...
For Sale NIB Futaba 10CG 2.4GHz, FASST Radio Brand New flywmoi Aircraft - General - Radio Equipment (FS/W) 2 Mar 25, 2011 05:46 PM
Discussion Need help to figuere out what is video,ground and 4.2 v power. Voguna FPV Talk 5 Mar 13, 2011 12:00 PM
Sold New Futaba 10CG 2.4 Radio with CAMPAC and Warranty $379 cbcalhoun Aircraft - General - Radio Equipment (FS/W) 6 Jan 30, 2010 01:58 PM
Sold Like New Futaba 10CG 2.4 Radio with 128k CAMPAC and Warranty $374 cbcalhoun Aircraft - General - Radio Equipment (FS/W) 2 Jan 23, 2010 08:06 PM
Sold Brand New Futaba 10CG Dedicated 2.4 Ghz with R6014HS 14 Channel Rx $530 Shipped cbcalhoun Aircraft - General - Radio Equipment (FS/W) 6 Jun 10, 2009 06:37 AM
