Old Aug 25, 2003, 10:01 PM
ReikiMaster is offline
Find More Posts by ReikiMaster
Unicorn Pilot
ReikiMaster's Avatar
Niagara Falls Int, New York, United States
Joined Aug 2003
Got my new stuff... checking in...
OK... please pardon the downright newbie questions, but I want to make sure I'm not screwing anything up.
Got my new Dymond Super Turbo. It's hooked up to a nice regulated power supply.
I have 2 different packs. I have a couple packs that are 1400mah and 1 that is 1650mah. (all packs are NiMh, 8cell, AAcells)
for the 1400mah pack I set up a battery memory that will charge at 200ma and safety shutoff at 1500mah peak detect. I also have a battery memory set for auto detect and will maybe change that to 1.4amps after the battery has been cycled a few timees
for the 1650mah pack I have a memory slot that'll charge at 200ma and safety shutoff at 1750mah peak detect. Also an auto detect memory that I'll change later to a more agressive charge rate.
My questions are:
On these new packs, what discharge rate would I choose in order to cycle them? (do you choose a slower discharge rate while new and up the rate after they're broken in?)
For the 1650mah pack... I can't set charger to "1.65A"... so would I set it to 1.7 or 1.6?
If anyone has this charger and would care to run through a sample setup for normal charging and maybe a charge-discharge of one of my packs I'm sure I could figure out the setup on the other from the example.
Thanks!
ReikiMaster is offline Find More Posts by ReikiMaster
Old Aug 26, 2003, 08:50 AM
evan is offline
Find More Posts by evan
Rochester, MN
Joined Nov 2002
I dont have a Dymond but your programming is okay (if you are doing the C/10 initial charge). If I were you, i'll discharge the batteries using the plane or whatever equipment you plan to use it in and then recharge anywhere between .5-1C (depending on your time constraints and even higher if you think your cells will take it). You'll find that the performance improvement after a few cycles.
evan is offline Find More Posts by evan
Whoops! Got my new RX in!!! Jimbolaya30 Coaxial Helicopters 0 Jul 02, 2007 04:37 PM
I just got my new br, and it is in good shape, flying! bambino BladeRunner Heli 4 Dec 17, 2005 09:44 PM
Vote my new aerobatic plane in... kepople Electric Plane Talk 11 Jul 30, 2001 04:24 AM
got my new rocket wing Jim Brown Foamies (Kits) 2 Jul 28, 2001 12:54 AM
