Australia, WA, Perth
Joined May 2007
Ah right, the iron that holds the magnets in place, rather than between the windings, gotchya!
And I've seen the difference 5% efficiency makes when talking 80 v 85%. I can pump 30% more power into it, for the same temp rise. Large difference there! |
Latest blog entry: A tiny diesel engine AE 0.1CC
Joined Nov 2007
Heat is only one thing that limits a motors power. According to your analysis a 99% motor would make twice the power of a 98% motor or weight half as much. In the real world the difference would be about nothing. And would you believe either rating? |
Steve Neu |
Munich Bawaria
Joined Jan 2003
Hi Friends,
in my opinion the best efficancy bldc motor is the flywheel motor/alternator from Prof.Dr.Richard Post , http://worldwide.espacenet.com/publi...396186B1&KC=B1 . Only two pole for low switching frequenz,no iron flux carry parts only the magnets and the magnets can be laminated for low eddy current,for highest magnetic flux they use a Halbach array sending all flux inside the rotating ring,vacuum to get no aerodynamic loss and 2 two phase coil made from lize wire also to keep eddy current so low as possible. This wining combination can reach astonishing 99,6 -99,8 % efficancy. I am with Steve,the Tango has very high possible efficancy but the low copper fill will limit this to the lower amp side.Also in the switching mode at part throttle there are lots of eddy current induced in the rotating solide back iron.It has to be made from laminated silicon steel or ferrite for high eff. . For highest power to weight and efficancy we build motors with every flux seeing part from laminated material. Mean laminated magnets 1mm sheet ,laminated magnet back from 0,2mm or better 0,07mm cobalt iron ,lize wire and very good flux design for low loss. Steve Neu and Hans Lehner produce the highest efficancy model electric bldc motors in the 95% region. You must only drive them in the high eff.window. |
| Thread Tools | |
| Question 7"-10" LCD/LED Highest Quality Monitors???? | LexusFPV | Video Piloting (FPV/RPV) | 3 | Jun 09, 2011 06:57 AM |
| Question Difference between BLDC motor & PMSM | amith123 | Electric Motor Design and Construction | 2 | May 10, 2011 06:11 PM |
| Discussion Maximum efficiency/flight time question. | boingk | Power Systems | 11 | Mar 19, 2011 07:29 PM |
| Discussion 2 BLDC motors on one shaft with the same drive? | Raag90 | Power Systems | 2 | Mar 10, 2011 01:38 PM |
| Discussion 5 Phase Unipolar BLDC Motor | INewton | Electric Motor Design and Construction | 40 | Jan 20, 2006 09:31 PM |
