Old Jun 05, 2011, 11:43 AM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Just put my first lights on
I built a fairly big AP bird this winter, and I find myself often flying it late in the evening getting sunset shots, and because late in the evening is usually also good for wind conditions. I'm also new at this RC flying, and often find myself having trouble with orientation etc. and this bird has such light wing loading I find the wind can turn it in a hearbeat. One evening I lost orientation and was fighting a breeze and when I finally was losing sight of it more than I was seeing it and cut the throttle and I ended up walking almost 3 kms looking for a white plane on a frozen lake (with a brand new GoPro on it).
My next flight I just put on a cheap dollar store 3-LED headlamp on the plane, which worked pretty good actually. You can see it on the plane in this video here. (inset at 1:40)
Sunset on the ice (4 min 2 sec)
I've since put FPV on it, which helps me a LOT with orientation when flying it a long ways away, as well as being far better for framing shots & videos etc, but since I do a lot of flying in the evening, decided to put some lights on it. I started out with this set, and put the strobe on the front with the green and red LED's on the correct port/starboard sides. Actually I don't think it's so much a strobe as it's just a flashing LED. I did buy this strobe from flytron as well, which I think will be a lot better in daylight and long distances, but danged if I can remember where I set it I see now they have the green and red, and depending on how well the lumifly ones work at distance I may replace them with the flytron. The lumifly set looks pretty good at night anyway, but I have not yet flown with them.
Anyway, I notice when I turn them on with a switch I assigned to channel 5, the servos (HXT 9000) glitch once or twice sometimes, just a tiny bit. Is this something to be concerned about? I more worried about suddenly losing servo control at a long distance out. I have also noticed that on some occasions the fpv gear can also cause these to glitch a bit. I have these servos on order because they are supposed to be a lot less "glitchy", with the fpv gear anyway.
I also bought some of these glow wires with the lumifly 2 port glow controller. I put the glow wires on the wing last night with packing tape, and taped the 2 port controller to the side of the plane. There is no instructions with the driver, but from the comments I see the jumper on it is for different voltages, 4 6 or 8. I am running 3s on this plane, and the glow wires are on all the time when I press the switch on the driver, either flashing or on. I was hoping to be able to turn them on with my radio, but apparently these can't. Is there a way to do this? Is the 3s too much voltage for these? Should I get a small 1 or 2s battery and wire them direct?
I also bought these, but haven't put them on yet, I may put them along the bottom of the fuse, once I get comfortable with the ones I have on already.
Also, how does one wire the lights to run off a different battery, but still have them controllable from the ground, is it doable?
Glenstr is offline Find More Posts by Glenstr
Old Jun 05, 2011, 09:32 PM
Sir Dumb Thumb is offline
Find More Posts by Sir Dumb Thumb
Old Prop Buster
Sir Dumb Thumb's Avatar
United States, CA, Grass Valley
Joined Dec 2009
Bec
I would be concerned about the servos glitching. Are you using a separate BEC? If you are not read this.
http://www.headsuprc.com/servlet/the...r-5-Amp/Detail
Oh yeah Go Canucks!
Sir Dumb Thumb is offline Find More Posts by Sir Dumb Thumb
Old Jun 12, 2011, 02:43 AM
aa78 is offline
Find More Posts by aa78
Fast and low...
aa78's Avatar
Joined Apr 2009
A switching current limiter or voltage regulator might spew out noise causing the servo to glitch.
I am in the process of making my own lighting system circuit and am using only linear limiters/regulators to prevent such noise from occurring. I will be putting it in my Skywalker FPV plane eventually.
I will be updating the linked thread with details when I get done with it:
http://www.rcpak.com/index.php/forum...ighting-system
aa78 is offline Find More Posts by aa78
Discussion Have a set up laying around...just need something to put it on!! flynfunny Power Systems 1 Apr 18, 2011 11:30 PM
Help! need advice on which 72 mhz rx to put in my heli newtohelis Mini Helis 6 Apr 06, 2011 03:39 AM
Help! the retracts on my blitzrc a10 burnt at first power up! rob737 Banana Hobby 8 Mar 24, 2011 04:09 PM
Discussion Just put my Bonnie 20 on Floats HavingFun2002 Waterplanes 3 Jun 17, 2006 08:23 PM
Yippee! Just put my CP2 on my JR xcr600 Micro Helis 8 May 28, 2006 08:37 AM
