This thread is privately moderated by Spidious, who may elect to delete unwanted replies.
Old Jun 04, 2011, 01:54 PM
Spidious is offline
Find More Posts by Spidious
Trader Rating: 55
Bush Pilots Bounce Higher
Spidious's Avatar
USA, IL, Champaign
Joined Dec 2006
Trader Rating: 55
Sold
EMAX 60 amp Electronic Speed Control
This is a Emax ESC speed controller. I have a Ice75 and no longer need this one.
Will sell for $35 shipped USPS w/tracking number PayPal USA only..
The EMAX 60 amp Electronic Speed Control with switch-mode BEC works with most brushless motors and comes pre-set for use with 2 to 6 cell Lipo batteries. The built-in 5 volt, 3 amp switch-mode Battery Elimination Circuit (BEC) will power up to 7 analog or 6 digital standard size servos, eliminating the need for a separate BEC or receiver battery pack.
Several programming options can be set with your transmitter or a program card, but no programming is needed for most applications.
Here is a list of the programming options:
1. Motor brake on or off. Comes pre-set with the brake turned off, so the propeller will spin freely when the plane is gliding (transmitter throttle off).
2. Selection of battery type: Lipo or NiMh/NiCD. Comes pre-set for use with Lipo batteries, and it auto-detects the number of Lipo cells.
3. Low voltage protection: low (2.6v per cell), medium (2.85v per cell) and high (3.1v per cell). Comes pre-set for medium Lipo battery protection.
4. Type of motor cut-off: sudden or gradual. Comes pre-set for gradual motor shutdown.
5. Start-up mode: fast, soft or very soft. Comes pre-set for fast startup.
6. Throttle curve: curve1, curve2 and curve3. Comes pre-set for curve1 (standard throttle response)
7. Motor timing: low, medium or high. Comes pre-set for medium timing (outrunner motors with 6 poles or more)
8. Motor rotation: normal or reverse Comes pre-set for normal rotation
9. Governer Mode: Off, low or high. Comes pre-set with governer off. The program card necessary to turn on governer mode.
Spidious is offline Find More Posts by Spidious
Old Jun 05, 2011, 06:20 AM
foxtrot25foxtr is offline
Find More Posts by foxtrot25foxtr
Trader Rating: 83
United States, IN, Harrison
Trader Rating: 83
foxtrot25foxtr
PM sent
foxtrot25foxtr is offline Find More Posts by foxtrot25foxtr
Old Jun 05, 2011, 08:23 AM
Spidious is offline
Trader Rating: 55
Spidious's Avatar
USA, IL, Champaign
Joined Dec 2006
Trader Rating: 55
Sold to foxtrot25foxtr
Found Kontronik Electronic Speed Controller 80 amp AlexanderCSD Aircraft - Electric - Power Systems (FS/W) 0 Mar 08, 2011 10:58 PM
Sold Castle Creations 80 Amp Esc Speed Control djdaveq Aircraft - Electric - Power Systems (FS/W) 5 Mar 04, 2011 03:23 PM
Alert Value Hobby Lipo Battery & Electronic Speed Control SALE! mtdoramike Hot Online Deals 3 Nov 08, 2010 06:21 PM
For Sale Zagi-35 Amp Electronic Speed Control - for Brushed Motors jbachman Aircraft - Electric - Power Systems (FS/W) 1 Jan 08, 2007 09:04 AM
Ebay: GWS Electronic Speed Control 5/8 Amp Maximum Allan_A Aircraft - Electric - Airplanes (FS/W) 0 Aug 04, 2004 12:30 PM
