Old Jan 17, 2012, 09:58 PM
jer291113 is offline
Find More Posts by jer291113
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
Originally Posted by deadaim57 View Post
Well I didn't really want to order from HK,take's to long.Is there anywhere to get one here in the usa?
Do you have to use a car esc to have reverse?
Tom
Yes.
You might want to check eBay for a domestic seller that has something similar.
jer291113 is offline Find More Posts by jer291113
Old Jan 17, 2012, 10:03 PM
deadaim57 is offline
Find More Posts by deadaim57
deadaim57's Avatar
United States, LA, Winnfield
Joined Jul 2011
ok thanks for the help.
Tom
deadaim57 is offline Find More Posts by deadaim57
Old Jan 17, 2012, 10:10 PM
Heli and E-Plane
Joined Nov 2010
Tom
I used a 30A airplane esc until I got my Turnigy from HK.
I got my SD from the USA warehouse.
Sometimes I don't understand why HK USA warehouse has the kits but doesn't have the supporting parts which forces you to order from China.
Old Jan 18, 2012, 11:55 AM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Originally Posted by jer291113 View Post
....Sometimes I don't understand why HK USA warehouse has the kits but doesn't have the supporting parts which forces you to order from China.
Because everything that HK ships from China to the USA costs them money until they sell it. Buying direct from HK International costs you money.
nioa is offline Find More Posts by nioa
Old Jan 18, 2012, 02:15 PM
Heli and E-Plane
Joined Nov 2010
Makes sense but highly inconvenient...
Old Jan 18, 2012, 10:01 PM
deadaim57's Avatar
Joined Jul 2011
Where is the CG on this dawg?
Tom
Old Mar 24, 2012, 03:57 PM
OwlPic is offline
Find More Posts by OwlPic
OwlPic's Avatar
United States, MA, Tyngsborough
Joined Jun 2010
CG and ESC
The CG is a very good question. I just got back from rescuing my Swamp-Dawg because it flipped upside down. Wasn't going that fast and wasn't very choppy. It is easy to turn too fast though with those big rudders right in the prop wash. ~Might add some expo to my transmitter.
~Need to look at getting the battery into the Pit and putting everything else under the seats.
Front-to-back CG is an interesting question too, but not an easy adjustment with just the battery.
There is not a lot of gunnel depth, so I wouldn't add any dead weight.
Look at this video, he is on the verge of tipping over. You don't see it until you look for it. He is careful and making gentle turns:
Hobby King Swamp Dawg Air Boat (ARR) (9 min 9 sec)
The car ESC is not a good solution. It only gives maybe 10-25% reverse; barely enough to back you up in open water. (HK-CAR30A can be programmed to 100% reverse)
If you want to get out of the grass or off the bank ... Much better to use two ESC and put them on different channels. Then you can dial in how much reverse you want (or maybe need or maybe need extra in a pinch).
(Using a Spectrum 6XDi transmitter, everything on one stick)
OwlPic is offline Find More Posts by OwlPic
Old May 18, 2012, 04:44 PM
TlM is offline
TlM
Find More Posts by TlM
TlM
TlM's Avatar
Firth, Nebraska
Joined Aug 2007
Does anybody know for sure what size the motor shaft is?
People have posted 2.00mm and 2.3mm.
I have plenty of props that will fit it, but would like to put an order in for one before I go home to measure it.
TlM is offline Find More Posts by TlM
Old May 19, 2012, 08:00 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Not trying to be harsh, but if you want convenience buy everything from your LHS. I believe most parts (other than motor/esc/motor mount) is the same as the mini alligator tours made by aquacraft?
wparsons is offline Find More Posts by wparsons
Old May 19, 2012, 12:06 PM
nioa is offline
nioa's Avatar
Phoenix, AZ
No, the Swamp-Dawg and the Mini Alligator are both different. The motor cage for example, is different, though they look similar. I have both, and I have compared, they are not inter-changeable for parts.
Nick
Old Jul 04, 2012, 04:55 PM
Neil_M is offline
Find More Posts by Neil_M
Neil_M's Avatar
Joined Feb 2010
Can a 3C 3000 20c Lipo be used with the "Turnigy TrackStar 18A 1/18th Scale Brushless Car ESC" ?
I want to use my batteries i already have.
Thanks!
Neil_M is offline Find More Posts by Neil_M
Old Jul 04, 2012, 05:31 PM
Foamaholic is online now
Find More Posts by Foamaholic
Electric since 1990
Foamaholic's Avatar
East Central Ohio, United States
Joined Jun 2004
Hobbywing Seaking esc's can be programmed to have reverse. At least the 60 amp one can.
Foamaholic is online now Find More Posts by Foamaholic
Old Jul 09, 2012, 08:04 AM
roberto76 is offline
Find More Posts by roberto76
Joined Nov 2011
HI!
Swamp Dawg Stock motor broken......and trying to find a replacement.
Something like this?
http://www.giantshark.co.uk/221206-2...-p-402397.html
Any suggestion please?
Roberto
roberto76 is offline Find More Posts by roberto76
Old Jul 10, 2012, 01:10 AM
gargalesis is offline
Find More Posts by gargalesis
Australia, VIC, Preston
Joined Mar 2008
Originally Posted by roberto76 View Post
HI!
Roberto
I found this one fits perfectly and works great on 3s with 5.5 x 4.5 prop http://www.hobbyking.com/hobbyking/s...dproduct=18198
gargalesis is offline Find More Posts by gargalesis
Old Jul 10, 2012, 02:48 AM
Joined Nov 2011
thanks...do you mean it fits perfectly on the stock motor mount? sorry for my newbieness...what comes with the motor? connectors? prop adapter? what is needed to install on the SD?
also trying to find the right prop but...real newbie....can you help me telling which damned props can fit on it???
these can fit?
http://www.hobbyking.com/hobbyking/s...propeller.html
http://www.hobbyking.com/hobbyking/s...idProduct=8006
http://www.hobbyking.com/hobbyking/s...dProduct=10034
http://www.hobbyking.com/hobbyking/s...idProduct=9873
real nooob.....thanks
Sold New Imex 2.2 All-T Dawg (4) jeepcrawler08 Cars - Trucks and Parts (FS/W) 2 Jun 04, 2011 07:02 PM
For Sale cox nitro cat , or cox gator rc boat swamp buggy rcrick10 Boats (FS/W) 2 Mar 16, 2011 11:59 PM
Help! Help with swamp boat Sune Nielsen Dock Talk 4 Mar 16, 2011 02:27 PM
