Old Jul 09, 2011, 07:58 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Well it worked ok...but it's very skittish, on a Thunder Power 1300mA 2S battery, Its difficult to get it to track "hands off" with a mix of different throttle settings
The sealant on the hull seams appears to be coming adrift already..Any Idea what sealant would work with Polypropylene..
dekan is offline Find More Posts by dekan
Old Jul 18, 2011, 12:44 PM
niterdr is offline
Find More Posts by niterdr
niterdr's Avatar
Canada, ON, Port Colborne
Joined Mar 2005
I am sure that a good silicone sealant will work, you don't want a permanent filler in case you need to get inside. Did anyone receive instructions with their swamp dog? I don't know where the electronics are supposed to go!
Alex
niterdr is offline Find More Posts by niterdr
Old Jul 18, 2011, 03:48 PM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
I used silicone sealant in the end...No instructions..
I'm replacing the prop and driver hopefully that should sort out the vibration
Old Jul 21, 2011, 06:29 PM
hotrodder is offline
Find More Posts by hotrodder
hotrodder's Avatar
United States, CT, Manchester
Joined Jan 2007
I have been having a blast with my swamp dawg... I remounted the servo to the back deck and put in a 35a seaking water cooled esc.. Going out tomorrow to see how it runs...
Joe
hotrodder is offline Find More Posts by hotrodder
Old Jul 21, 2011, 06:39 PM
hotrodder's Avatar
Joined Jan 2007
Joe
Old Nov 07, 2011, 06:02 AM
rustyho is offline
Find More Posts by rustyho
Joined Nov 2011
As an absolute nube, I'm flummoxed by the lack of instructions with the Swamp Dawg esp the electronics!
I'd really appreciate advice regarding
1. there are three wires into the motor (red/blue/black) and three black wires out of the ESC labelled A/B/C. Which goes with which?
2.which socket does the steering servo plug go into on the receiver (HK-GT2R)
3. which socket does the red/white/black leads from the ESC (HK20A) go into on the receiver?
Any advice would be greatly appreciated!!!
Cheers
rustyho is offline Find More Posts by rustyho
Old Nov 13, 2011, 06:23 PM
nioa is online now
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Build Log at my Blog
Hi, here is another HobbyKing Swamp Dawg Air Boat. Please see my blog for the build.
nioa is online now Find More Posts by nioa
Old Nov 13, 2011, 07:09 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
I've been looking at maybe purchasing on of these little airboats, I think there pretty cool looking and a nice price. I wanna slap a edf on mine though. I have 50mm fan/motor setup and a 64mm fan/motor setup just laying around. Could be interesting to say the least lol.
Diesel6401 is offline Find More Posts by Diesel6401
Old Nov 15, 2011, 07:42 PM
skymaster62 is offline
Find More Posts by skymaster62
skymaster62's Avatar
USA, OR, Portland
Joined Jul 2009
Is anyone looking to part out on of these yet? Mine was shipped the other day with 2 of the same motor mount brackets. 3 hole X 2 hole. Can make one from ply, but would like the stock part. Not sure left or right as there are no instructions. Haven't taken the time to check. Will buy both and cover shipping PM me please.
skymaster62 is offline Find More Posts by skymaster62
Old Dec 09, 2011, 05:00 PM
jer291113 is offline
Find More Posts by jer291113
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
Originally Posted by Skyking213 View Post
BTW, I'm using HK's HK-310 Radio and a Turnigy 1/18th Car ESC so I have reverse if needed.
Cheers,
ScottB
Hi Scott,
I have a FlySky 3 channel Tx which is similar to your HK-310 and just received the Turnigy 1/18th car esc today.
I'm having trouble setting up the ESC, it works fine in reverse but in forward throttle position it's running slow and almost seems like it wants to reverse mid-stream so to speak. I got the programming card and tried various settings but can't get it to run properly.
FYI, I'm using the stock motor which worked fine when I was using a plane 25A esc except with no reverse.
Any ideas or could you point me in the right direction?
Thanks for your help!
jer291113 is offline Find More Posts by jer291113
Old Dec 10, 2011, 10:22 AM
OwlPic is offline
Find More Posts by OwlPic
OwlPic's Avatar
United States, MA, Tyngsborough
Joined Jun 2010
Motor Mount, ESC, Horn ...
1) The official HK photos show the motor mount incorrect, backwards. The motor-mount set-screws will only engage the motor's mounting-collar if these screws are closes to the motor, not the way the picture shows.
2) Used a car ESC, because reverse seems important to a boat that can get into weeds and low branches. Put the controls on right stick Elevator = throttle (fwd/rev). Ailerons = rudder.
Used the HobbyKing.com, Turnigy TrackStar 18A 1/18th Scale Brushless Car ESC, (TTS-18A).
It also gives you an ON/OFF switch so you don't have to open the cover to disconnect the battery when not using.
3) Used the $3, HobbyKing.com "Discover Buzzer" as a boat "air horn", plugged into a spare channel. PRODUCT ID: D-Buzzer
4) Added the $2, 6 LED HobbyKing.com, PRODUCT ID: 6LED-WH as a night-running lights.
5) Added a HobbyKing.com aircraft red/green/white LEDs as navigtion lights.
6) Would be nice to put an FVP (live video, transmitted back to goggles) camera and underwater video camera on some day.
OwlPic is offline Find More Posts by OwlPic
Old Dec 11, 2011, 12:34 PM
OwlPic is offline
OwlPic's Avatar
Joined Jun 2010
Things I have learned ...
1) Makes a good winter boat: Run indoor on the carpet, outside on wet grass, snow and frozen pond.
2) Route the motor wires on the outside of the uprights, need all the prop clearance you can get.
3) Lock tight EVERYTHING. Even prop to shaft and motor to mount.
4) Put receiver below black deck and ESC above, but spaced up so water can't get to it.
5) Bottom to side seal came off, right away, used silcon-caulking.
6) Used http://www.corrosionx.com on the engine.
7) The "rudder" ball-connectors are tight when new, ran a rolled-up sandpaper on the inside of the rings to loosen it up.
Old Dec 11, 2011, 12:40 PM
OwlPic is offline
OwlPic's Avatar
Joined Jun 2010
Turnigy 1/18th ESC
Ran it on my "Elevator" right-for/back stick.
As Turnigy 1/18th ESC instructions say: hold full foward throttle and turn boat's power on, after the ESC beeps calm down, hold full reverse throttle until ESC beeps calm down.
Green light on ESC for forward, red for reverse and yellow for stopped.
Reverse is a lot slower than forward, as you expect for a car.
Set my "throws" in my DX6i to +/- 125%.
Old Dec 11, 2011, 01:09 PM
Heli and E-Plane
Joined Nov 2010
It turned out that it wasn't the new ESC but one of the winding wires had broken. I was able to re-solder it. Ran a couple of batteries thru her, had a lot of fun for such a inexpensive boat!!!
Old Dec 11, 2011, 01:10 PM
Heli and E-Plane
Joined Nov 2010
Did you folks need to add any weight to the front of the boat?
Thanks!
Sold New Imex 2.2 All-T Dawg (4) jeepcrawler08 Cars - Trucks and Parts (FS/W) 2 Jun 04, 2011 06:02 PM
For Sale cox nitro cat , or cox gator rc boat swamp buggy rcrick10 Boats (FS/W) 2 Mar 16, 2011 10:59 PM
Help! Help with swamp boat Sune Nielsen Dock Talk 4 Mar 16, 2011 01:27 PM
