Old Jun 18, 2011, 07:06 PM
hotrodder is offline
Find More Posts by hotrodder
hotrodder's Avatar
United States, CT, Manchester
Joined Jan 2007
Looking good there... I just ordered one today at HK, can't wait to get it I have 2c 1050mah lipo batterys and some 3c thunder power lipos that will fit right in..
Joe
hotrodder is offline Find More Posts by hotrodder
Old Jun 26, 2011, 11:57 PM
CaptRevs is offline
Find More Posts by CaptRevs
Joined Jun 2011
I am not into electronics so I don't know if its motor could hold 3s lipos and what ESC amperes do a 3s lipos need. Anyone pls.
CaptRevs is offline Find More Posts by CaptRevs
Old Jun 27, 2011, 09:18 AM
Skyking213 is offline
Find More Posts by Skyking213
out of the western sky...
Skyking213's Avatar
Harbor City, CA
Joined Jul 2003
Well Capt,
While I have not put a watt meter on it I have run it with 3S 850mAh Nanotech Lipos (that's all I use now) many many times (25+) in hot Arizona conditions over 100 degrees F.
Motor comes back warm, not too hot to hold.
I'm using a 1/18th scale car ESC so I also have reverse and I'm using a car radio with a wheel for better control.
The four things that need to be done are;
  1. Balance the stock prop. Mine was close.
  2. Use a screw to hold the hatch down in the rear hole behind the seat. It would be great if they supplied two of the thumb screws instead of one!
  3. Make sure you get both male and female bullet connectors for the motor (it didn't come with them)
  4. Be sure to put a dab of blue loctite on all your screws! Mine have not come loose but some people have reported some looening! I suspect it has to do with the prop balance, or lack of it! ;-)
But so far so good!
Cheers!
ScottB
Skyking213 is offline Find More Posts by Skyking213
Old Jun 27, 2011, 10:07 PM
hotrodder's Avatar
Joined Jan 2007
20amp esc that comes with the swamp dog will handle 3s ....
Old Jun 27, 2011, 11:00 PM
Skyking213's Avatar
Harbor City, CA
Joined Jul 2003
Mine didn't come with an ESC...
The website says "You will require a 20amp ESC, 1000mAh 2S 7.4v Lipoly battery and your own Tansmitter and receiver (Tx/Rx) to complete this model."
Hmmmmm.....
Old Jun 28, 2011, 08:17 PM
hotrodder's Avatar
Joined Jan 2007
I thought I edited my post last nite... No it does not come with the esc... If you look at the one HK recommends it will do 3s lipo...
Old Jun 28, 2011, 08:22 PM
hotrodder's Avatar
Joined Jan 2007
H-KING 20A Fixed Wing Brushless Speed Controller....
Thats the one I picked up $7.63 ... I already have a spektrum DX6i radio and I always keep there acouple orange spektrum recievers.. I have a bunch of servo's .... Just waiting for my swamp boat to arrive....
Old Jun 30, 2011, 05:54 AM
7up is offline
7up
Find More Posts by 7up
7up
,ɯǝ ʇoƃ ɐʎ ɟı ,ɯǝ ǝʞoɯs
7up's Avatar
USA, KY, West Liberty
Joined Jun 2001
Just stumbled upon this thread. I am usually a plane guy, but had an itch for a boat. I've been working on my own version I designed for electric and foam and maybe a 26cc version. It is very similar to the Swamp Dawg. The build log, "in progress" is in my blog if anyone would like to check it out.
-Buk
7up is offline Find More Posts by 7up
Old Jul 01, 2011, 12:33 AM
CaptRevs is offline
Joined Jun 2011
Originally Posted by Skyking213 View Post
Well Capt,
But so far so good!
Cheers!
ScottB
I appreciate your quote, skyking. Those points that you wrote will definitely help us to properly set up our Swamp Dawq. I will have mine in 3 days. It is now 35,000 feet above the pacific. Cheers!
Old Jul 05, 2011, 01:13 AM
cloudy brian is offline
Find More Posts by cloudy brian
Australia, New South Wales, Charmhaven
Joined Oct 2009
got my swampie today and the motor sleeve doesnt fit into the motor mount so now i got to get it reamed out damn it, shouldnt have to do stuff like that, if only HK would get there measurements right
cloudy brian is offline Find More Posts by cloudy brian
Old Jul 05, 2011, 06:25 AM
Joined Oct 2009
motor/ESC/battery setup
ScottB, can you post a photo of your motor/ESC/battery setup?
Just wondering how to lay the wires neatly including positioning the stuff in the compartment below the seats.
Thanks Brian
Old Jul 05, 2011, 09:56 PM
hotrodder's Avatar
Joined Jan 2007
Thanks for the tips on the lid and the loctite... I always go over all my screws on my trucks and cars... Never thought of using it on my boats...
Still waiting for my swamp bug to get here...
Old Jul 08, 2011, 10:58 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
My prop is was very out of balance and does not spin true ..it,s not the shaft
I'm going to have to replace it,as the vibration is very high! I have loctited all the screws.. Anybody know what the shaft diameter is ?
dekan is offline Find More Posts by dekan
Old Jul 08, 2011, 11:22 PM
hotrodder's Avatar
Joined Jan 2007
The shaft is a .2mm ....... Mine has no vibrations check your grub screws on the prop make sure they are tight...
I fried my esc tonite at the local pond... I put a TP 3s I had for my mini truck and I think with it weight of the battery 120 grams made it nose heavy and was a handful to turn, I got two 2s 1050 that weight in at 70grams and will balance it alot better..
going to throw in a quark 20a esc that I have for one of my mini trucks...
Old Jul 09, 2011, 02:08 AM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
Do you mean 2.0mm?...The screws are tight...I guess some of props are better than others.
Sold New Imex 2.2 All-T Dawg (4) jeepcrawler08 Cars - Trucks and Parts (FS/W) 2 Jun 04, 2011 06:02 PM
For Sale cox nitro cat , or cox gator rc boat swamp buggy rcrick10 Boats (FS/W) 2 Mar 16, 2011 10:59 PM
Help! Help with swamp boat Sune Nielsen Dock Talk 4 Mar 16, 2011 01:27 PM
