Old Jun 03, 2011, 10:33 PM
JamaicanRC is offline
Find More Posts by JamaicanRC
Joined Jun 2011
Help!
Skyartec Cessna 182 Transmitter Problem!
Greetings!
i recently purchased a Skyartec Cessna 182. After charging the battery and installing 8 AA batteries into the transmitter i powered everything up and tested all the servo functions and everything worked GREAT.
i decided to try out the FMS simulator that comes with the plane, Connected the USB cable to the TX and the computer and drivers were installed GREAT.
loaded the SKYARTEC CD and installed the FMS fine no problems.
Run the software, powered up the TX went to the control panel and selected "joystick Interface" as directed by the manual. Did the Mapping/Calibration and everything was GREAT.
Came out the Control Panel and loaded a model (Skyhawk 182) and started. The simulator started flashing so i turned the TEXTURES off (not a big deal).
Started flying TX responds perfectly with the simulator, plane flys perfect - NO ISSUES.
I power down the TX, disconnect the USB from the PC and the TX and went back to the RC. Powered on the TX and connected the battery to the RX (buzz buzz) goes the plane. Time to run a control test.
NOW the RC does not respond to the TX at all. I dont know what to do. Please Help
JamaicanRC is offline Find More Posts by JamaicanRC
Old Jun 04, 2011, 12:48 AM
Parkflying is offline
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
Originally Posted by JamaicanRC View Post
Greetings!
As THE Factory Authorized USA Distributor we see many issues that need some service or advice. I don't recall a problem like this one. I would suggest you contact your dealer for a service call or return to them to have them check it out. There is something definitely wrong with the setup
Sorry we couldn't give you a "fast fix"
Max
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old Jun 04, 2011, 07:42 PM
Joined Jun 2011
Max
MAX, i am not in the USA, nor is there a dealer here. surely you can do some research or come up with some troubleshooting steps?
Old Jun 05, 2011, 04:58 AM
Joined Dec 2008
No research necessary. We have bench tested literally thousands of these units. There is something broken in your radio system. Without the units on our bench we can't tell you what is wrong. You found a dealer to buy it from and you should be able to find them again to return the unit for replacement or repair as this is what is necessary
Max
Site Sponsor
Old Sep 07, 2011, 04:20 AM
scrubmonkey is offline
Find More Posts by scrubmonkey
Australia, QLD, Booyal
Joined Aug 2011
hi. I had the same prob. I just re-bound the tx.(is that correct??). here is a step by step if you don't know.
1)turn tx off and un-plug battery
2)plug battery into plane.
3)press the little black button on the rx. the red light should flash for a couple of seconds
4) while the red light is flashing turn on the tx. the tx lights should flash then go solid. Your tx and rx are now bound.
scrubmonkey is offline Find More Posts by scrubmonkey
Old Sep 08, 2011, 03:47 AM
Joined Dec 2008
Turn on Transmitter FIRST. Push the Rx black button in for a moment and RELEASE. Light on Rx will flash a few times then it will go solid red light. This is the proper procedure to rebind the Tx to the Rx.
Site Sponsor
Old Sep 08, 2011, 03:51 AM
Joined Dec 2008
Try to reconnect the Tx to the computer and start the software program. Click the open Game Button like you would to use the Flight Simulator. When you are finished using the Flight Simulator always click the game button to turn OFF the Game port. Prehaps the Transmitter, was still in Game Port Mode when you tried to use it with the Actual Airplane Rx.
Also try my steps to rebind the transmitter if this does not work
Hope that helps
Max
Site Sponsor
Discussion SkyArTec Cessna 182 Review and Notes Lobo Parkflyers 2915 May 18, 2015 11:27 AM
Video Skyartec Cessna 182 - AMAZING PERFORMANCE FOR UNDER $100 trickers Electric Plane Talk 11 Sep 07, 2009 10:09 PM
Question Cessna 182 Skyartec good or bad? Galern Foamies (Kits) 9 May 10, 2009 09:35 PM
Help! skyartec cessna 182 rideflyjam Foamies (Kits) 2 Sep 18, 2008 08:45 AM
Question SkyArtec Cessna 182 1530kv motor psvpilot59 Parkflyers 2 Jul 30, 2008 08:15 PM
