Old Jun 03, 2011, 04:30 PM
Kenta78 is online now
Find More Posts by Kenta78
Kenta78's Avatar
Sweden
Joined Sep 2008
Help!
Thrust tube repair?
Got some cracks in my thrust tube today, and IŽm thinking of how to repair it.
Will the easiest way be getting a new one?, which means I probably have to cut up the plane.. and also trying to find a new tube somewhere.
But I thought that maybe some ordinary A4 paper would do the trick? , IŽll leave the old tube in place, acting as a guide for the paper tube, and somehow glue this new tube into place.
Would this work?? or should I try to do it another way?
Thanks in advance!
Kenta78 is online now Find More Posts by Kenta78
Old Jun 05, 2011, 04:06 AM
Rookie_Gerhard is offline
Find More Posts by Rookie_Gerhard
Austria
Joined Jun 2009
Use an overhead foil and put it inside. Be careful not to leave a gap at the front end next to the impeller, so that no leak air can pass between the old and the new tube. This could damage the inner tube again. I would put some glue between the two tubes also.
Rookie_Gerhard is offline Find More Posts by Rookie_Gerhard
Old Jun 05, 2011, 06:56 AM
Kenta78's Avatar
Sweden
Joined Sep 2008
Thanks! =)
IŽve found some similar plastic foil which is comparable to overhead-film in thickness.
IŽll already installed it , but instead of gluing I used some scotch-tape so no air can pass between the tubes. But IŽll replace it with some glue instead before I change motor.
Many thanks again!
Cool repair Aluminum tail tube by yourself!(for TREX) iceman33 Mini Helis 9 Nov 05, 2006 08:46 PM
Discussion Molded D-tube repair ShredAir Slope 46 Sep 28, 2006 06:56 PM
Unicorn Motor Tube Repair? 60ndown Foamies (Kits) 2 Feb 21, 2005 08:28 PM
CF Tube Fuselage Repair ranger1442 The Builders Workshop 1 Jan 12, 2004 10:52 AM
Slow Stik tube repair cfischer505 Parkflyers 11 Aug 19, 2003 03:51 PM
