Closed Thread
This thread is privately moderated by ibcinyourc.com, who may elect to delete unwanted replies.
Old Jun 03, 2011, 08:45 AM
ibcinyourc.com's Avatar
United States, MO, St Louis
Joined Jul 2010
Trader Rating: 6
NGH GT17cc gas engine NIB
NEW! Intoducing the brand new NGH GT17cc gas engine.
Will fit most .90-1.40 models.
Complete with muffler, rcexl ignition and spark plug. 1/4 32
Specifications:
For 0.60-0.90 Airplanes!
Specifications:
Engine Type - Gasoline Two-stroke, Air Cooled, Rotary Valve
Cylinder Type - Precision Steel Sleeve
Cylinders - Single
Crank Type - Forged Dual Ball Bearing Support
Mounting Type - Beam or Rail Mount
Carburetor Type - Walbro WT Series
Carburetor Mounting - Front
Crankshaft Threads - 5/16" X 24 TPI
Mounting Dimensions - Owners Manual or Website
Spark Plug Type - 1/4" X 32 TPI
Displacement -1.02 cu in.(16.91cc)
Bore - 1.14 in. (29mm)
Stroke - 1.01 in (25.6mm)
Engine+ Muffler+ Ignition (Total Weight) = 1 lb. 14 oz. (850g)
Prop Range - 14x8,15x8,16x8
RPM Range - 2100-9000
Fuel - Unleaded Gasoline With High-Quality Two-Cycle Oil, Pre- Mixed
Compression ratio - 10
Pre-Mix Oil Ratio and Type - Synthetic Break-in with 20:1, General 25:1, For Air Cooled Engines
Performance :
Prop RPM
JXF 14x8 9000
JXF 15x8 8000
JXF 16x8 7000
The engine comes complete with everything shown in the picture; engine, muffler, CDI ignition, and a one year USA warranty. Our engines have individualized serial numbers from the factory.
$245 shipped and insured
Pay-pal prefered
ibcinyourc.com is offline Find More Posts by ibcinyourc.com
Old Jun 03, 2011, 01:23 PM
ProBro, 3D
gregory.da's Avatar
United States, IN, Lawrenceburg
Joined Jul 2008
Trader Rating: 157
Specifications:
I'm assuming you mean .90-1.4 four strokes and .60-.90 two strokes, correct? Looks interesting especially with the weight and upgraded RxCel ignition.
gregory.da is offline Find More Posts by gregory.da
Last edited by gregory.da; Jun 03, 2011 at 01:36 PM. Reason: deleted distributor question after seeing that you are in the USA.
Old Jun 03, 2011, 01:44 PM
Joined Jul 2010
Trader Rating: 6
Yes that is correct, I mean .90-1.4 four strokes and .60-.90 two.
Old Jun 23, 2011, 08:03 AM
South Africa, WC, Cape Town
Joined Dec 2009
Trader Rating: 0
dimensions?
TimBle is offline Find More Posts by TimBle
Old Jun 30, 2011, 10:35 AM
Joined Jul 2010
Trader Rating: 6
Originally Posted by TimBle View Post
dimensions?
you can go to www.ibcinyourc.com
Under engines NGH and find dimensions for the 17cc
Sorry for late reply.
Thanks Mike
Closed Thread
Wanted Fast Electric boat, have 50cc gas engine to trade tlh101 Boats (FS/W) 1 Sep 05, 2011 08:00 PM
Sold "NIB" Evolution GT26 Gas Engine w/ pitts style muffler prototype3a Aircraft - Fuel - Engines and Accessories (FS/W) 14 Jun 24, 2011 09:38 PM
Discussion Jc 100 gas engine olmanbruce Engines 0 Mar 10, 2011 09:58 PM
Discussion Installing an electric motor in place of a gas engine tenspeed Glow to Electric Conversions 7 Mar 08, 2011 07:32 PM
Sold Evolution 26GX Gas Engine old_dan Aircraft - Fuel - Engines and Accessories (FS/W) 8 Mar 07, 2011 08:07 PM
