| Channels: | 6 |
| Version as Reviewed: | 1.2 |
| Frequencies: | 2.403 2.480GHz |
| Modulation: | FHSS Spread Spectrum |
| Input Power: | 4 AA Alkaline, NiCd or NiMH cells(3.8-8.0V) |
| Output Power: | <0.1W |
| Power Indicators: | LED, with low voltage alarm |
| Reversing Switches: | Slide type four channels |
| Trims: | Analog Throttle, Digital Aileron, elevator and rudder |
| Antenna: | Built-in non-removable |
| Charge Jack: | Built-in (Futaba compatible for use with optional NiCd or MiMH |
| Optional Mixes: | Elevon V-Tail |
| Dual Rate: | 100/60% for aileron, elevator and rudder |
| Channel 5: | Non-proportional on/off |
| Channel 6: | Proportional with dial |
| Trainer Function: | Tactic 2.4 GHz radios only |
| Weight: | 1lb 5.2oz /602g with batteries |
| Receiver: | Tactic TR624 Rx |
| Manual PDF: | Tactic TTX Manual |
| Available from: | Hobbico |
| Retail: | $99.98 |
Following on the footsteps of the TTX 404 4-channel radios, the TTX 600 is a 6-channel radio made with sport flying performance in mind. The TTX 600 includes a 5th channel for retractable gear, a 6th channel for flaps, and a dual rate for ailerons, rudder and elevator. Consistent with the TTX 404 are a wireless trainer system, ball-bearing gimbals, elevon and V-tail mixing, digital trims for elevator, aileron and rudder, servo reverse switches, audible low battery alarm, programmable fail-safe, a charging jack, 6-channel receiver, and Tactic's Secure Link Technology (FHSS spread spectrum). The TTX 600 is both CE and FCC approved and is available in Mode 1 only at this time. For anyone wanting to enter into a high quality sport radio for either electric or fuel, with 2.4 GHz technology, the TTX 600 is an excellent choice at $99.00.
The TTX 600 comes compete with:
To use the TTX 600 one needs:
For a 2.4 GHz radio, the TTX 600 offers more than just a few useable features. It is perfect as a one-model radio, but can bind to additional TR624 receivers for more planes. While it will bind to any Tactic Secure Link receiver, each setup will be specific to one plane at a time. The TTX 600 does not have any aircraft memory functions. Overall, the feel of the radio is good. It is lightweight, but looks and feels durable and well made. The finish is high quality. Stick movement is easy, and the stick length is adjustable, but nothing in the manual indicates the stick pressures are adjustable. The throttle does not have a detent click, but is smooth throughout the movement. Channel 6s dial is clear and easy to access, and channel 5 is close in the upper left corner of the transmitter. The dual rate switch is in the upper right corner of the transmitter. Servo reversing switches are recessed to avoid any accidental movement and are on the lower right front of the radio.
Binding is straightforward with no need for a binding plug. To bind, turn on the transmitter, power up the receiver, and if the receiver LED flashes once and stays on, it is bound. If not, push the bind button on the receiver until the LED lights red, and release the bind button. The LED should stay lit. I was bound right out of the box.
The receiver is excellent and uses single, short, antennae. I was unable to determine the range of the TTX 600. The receiver has no placement limitations outside the norm for receivers.
There are several nice options with the TTX 600 including the audible low battery alarm. This option will alert the user by flashing the LED and beeping. Of course it cannot discern if the plane is in the air, but should a low battery alarm occur the plane must be landed immediately. I cannot provide how long one has between the first alarm and complete failure, but the TTX does include a fail-safe mode, and as long as the plane still has power the receiver will do two things: First it will drop the throttle (factory pre-set or it is adjustable and assuming the ESC does not have a signal loss feature) and second, it will leave the controls in the last position. Should a radio alarm occur, it might be wise to simply let go of the sticks, manually drop the throttle, and using very slight stick movement, get the plane on the ground. Using this method even if a power loss occurs and the fail-safe kicks in, the plane will still be under some control and in a stable glide.
The Tactic TTX 600 can also use the optional Tactic TACP1000 rechargeable NiMH batteries and wall charger. A plug is provided. Just remember to turn off the transmitter when charging.
Channel 5 is non-proportional and will operate the servo from stop to stop. This is typical of retract servo operations or in some cases it could move a figure, open an canopy, or open bomb doors or pull or push a bomb drop release. The feature is also reversible with a few simple transmitter on/off and rudder stick movements. These worked very easily, and I could reverse the servo per the instructions with no problems.
Channel 6 is proportional and operates a servo throughout its range of motion. Typically, this is for flaps, but could be incorporated into a camera for movement, flap doors, or perhaps realistic elements added for fun. This channel also has reverse and uses the slightly modified method for reversing Channel 5.
This switch is pre-set and allows you to reduce the travel of the elevator, rudder and aileron servos simultaneously from 100% to 60%. This is a great feature for someone learning to fly as a simple flip and the servo movement is reduced for take-offs and landings. At 100% aerobatics are possible.
This feature is intriguing and seems to simplify the aspect of using a second Tactic (only) 2.4 GHz radio for training purposes. As is the case with most trainer setups, the trims must be consistent on both radios. The setup radio is the trainer radio and a secondary radio is the student radio. Place the two radios within 1-meter of each other, set the throttle sticks to zero and power up the student radio. Hold the trainer switch on the trainer radio and turn on that radio. The LED on the trainer radio will flash three times indicating the two radios have linked. Once the trainer switch is released the receiver can be powered on. To return to normal operation, power off the plane and place both transmitters within 1-meter of each other and power both transmitters off. This breaks the link.
This is an outstanding feature of the TTX 600 that provides the radio with much more functionality than many entry level radios. While you do not have model memory, you can purchase additional receivers for about $30 each and re-bind to each plane.
Setting the elevon and V-tail mixes require you to bury the sticks into the lower right and left corners of rudder and elevator respectively. It is a little sensitive to making sure these are exactly in the corners. If you get it wrong just do it again and listen for the beeps.
Fail-safe mode can be modified but only for the throttle position. The last known position of the control surfaces are engaged, but you can set the throttle easily. The only limitation is when using a signal loss ESC that will drop the throttle and therefore render the failsafe throttle setting unnecessary. The factory default is 0% in the event of a power loss.
There is no specific function for range checking outside the normal distance procedure. It is suggested that you have someone hold the model and then move the transmitter 100-feet away and while pointing the transmitter directly at the model check for accurate control surface movement.
The TTX 600 is certainly for those wanting to venture into 2.4 GHZ, but with perhaps only one or two planes in their hangar. It has great functionality, and while I did not take it to the field, I have no reason to believe it will not work well. I already have plans for the installation of this radio in a small electric. The programming was easy to understand and works perfectly, the low battery alarm and fail-safe are excellent components, and when you add in channels 5 and 6 plus elevon and V-tail mixes you have a really nice radio.
Tactic electronic equipment continues to meet the demand of hobby flyers. I can assure you the product is well designed, and comes with a full one year warranty that begins on the date of purchase. I bench tested mine with micro through full size servos and in an ESC and glow battery configuration with nothing but success. The extras like a neck strap and battery switch, plus programming options are well worth the purchase price.
Plus
Minus
| Thread Tools |
Nice looking system at a very reasonable price point. Thanks for a very thorough review of this new 6-channel TX.
Your pictures show a Mode 2 system (throttle on the left stick) but your introduction mentions that the radio is only available in Mode 1 (throttle on the right stick). Tower site also shows a Mode 2 system. Since most USA flyers use Mode 2, I'm guessing you meant to say the system was only available in Mode 2 at this time. McD |
Latest blog entry: LEDs on my T-28
"at 99 these are no deal. id say you would be better off taking a turnigy 9ch radio with rx for much less
also im sure the rx units will be hard to find within a few months like most other flash in the pan 2.4 radios at least we know that the turnigy will be around for a while due to the fact that manufacture is also retailer and hence in the money" I would have to agree , makes me think its a simple "private lable version of a less value Turnegy with a double markup --factory +Hobbyco to consumer |
Latest blog entry: The Ultimate Hobby shop "Orange...
Joined Aug 2010
Hi all,
For a beginner what cheaper alternative would you recommend and are you guys talking about Hobby King the place to purchase the TURNIGY's? My set up will be in the near future skywalker with dual cameras one with pan and tilt not to mention GPS and hopefully autopilot with the 1.3 800MW or under |
| Thread Tools | |
| For Sale 2.4GHz 6 channel skyttech radio TS6i | sonicboom24 | Aircraft - General - Radio Equipment (FS/W) | 8 | Apr 28, 2011 09:29 AM |
| Sold Tactic TTX404 4-Channel 2.4GHz Spread Spectrum Radio System | MERLIN V16 | Aircraft - General - Radio Equipment (FS/W) | 3 | Apr 17, 2011 06:26 PM |
| Sold Tactic 2.4ghz 4 channel radio (Mint) | Gst22479 | Aircraft - General - Radio Equipment (FS/W) | 0 | Apr 04, 2011 10:54 PM |
| Sold Tactic TTX404 Transmitter & 2 6 channel Recievers 2.4ghz Wireles Buddy box Radio | boatdoc | Aircraft - General - Radio Equipment (FS/W) | 3 | Nov 05, 2010 03:35 PM |
