Old Jun 02, 2011, 05:25 PM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Aluminum covering.. yes or no....
Hi I am in the middle of a project. I like to know where can I get aluminum foil to cover the craft instead of Monokote. I want to have that metallic look. The craft is made out of balsa...Any idea?
I found aplace in Florida but they wont ship to Canada or accept PayPal from Canada.
bcollydas is offline Find More Posts by bcollydas
Old Jun 02, 2011, 06:02 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Aluminum foil would be far too fragile. It will also add more weight than ou want or need. Ultracote makes a Chrome polyester shrink covering that will suit you needs fine:
http://www.hangar-9.com/Products/Def...ProdID=HANU886
They also make a silver for a more matte/metallic look if you don't want a mirror finish.
Fly Wheel is offline Find More Posts by Fly Wheel
Old Jun 02, 2011, 09:29 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Art Johnson years ago discussed in RCM his aluminum covered Seversky P-35 which was entered in Top Gun. It was thin sticky backed sheet. While aluminum foil is fragile... I'm pretty sure it's much lighter than the iron coverings of the same dimensions.
Thermalin is offline Find More Posts by Thermalin
Old Jun 03, 2011, 07:07 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Maybe this guy will ship to Canada. http://www.flitemetal.com/
Don't construe this to be a recommendation for this company. It is known for slow shipping and "lost" orders. It may be your best shot, unless you know somebody in the States that can order from Meister, and then send it to you.
Be aware that when using either product, the model must be glassed first. The surface needs to be perfect, just as if you were going to paint.
TomCrump is offline Find More Posts by TomCrump
Old Jun 03, 2011, 07:41 AM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
I've read about someone who covers models with foil. Sprays first with 3m77, then rubs the foil down. I don't think foil would weigh too much, I reakon it would weigh similar to monokote etc
discostu956 is offline Find More Posts by discostu956
Old Jun 03, 2011, 09:57 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
Chrome Monokote, skuffed up with a Scotchbrite pad, and applied in panels.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Jun 03, 2011, 06:20 PM
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Thanks for all your input guys. I found what I was looking for. Aluminum foil with adhesive backing. Cool stuff.
www.flitemetal.com
Cheers
Old Jun 08, 2011, 01:40 AM
Haole is offline
Find More Posts by Haole
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
Les
Oh wow, that's looking very impressive. What a great technique!
Carl
Haole is offline Find More Posts by Haole
Old Jun 08, 2011, 12:14 PM
magillag is offline
Find More Posts by magillag
United States, MA, Swampscott
Joined Apr 2008
Has anyone tried using 3M 77 to hold actual aluminum foil onto their plane? Wouldn't it be just like the Flitemetal concept?
magillag is offline Find More Posts by magillag
Old Jun 08, 2011, 12:16 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Glue adhesion can be a problem.
Try it, and set your sample in the hot sun, for a few hours. If it works, fine. If not, you haven't ruined a model.
Old Jun 08, 2011, 12:51 PM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
"Haole "
From another Haole. Thanks. Graduated Kaimuki Hi on Oahu, and attended UH for a short while before my tour in the Marines.
Les
Old Jun 08, 2011, 01:16 PM
magillag is offline
Joined Apr 2008
So is it the glue that's the problem? Is there something else that would be easier to apply and stick better? Or, is it the weight of the aluminum foil that is the problem?
Old Jun 08, 2011, 01:39 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Glue CAN be a problem. So can the durability of the foil.
Old Jun 12, 2011, 11:49 AM
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Looking good Les. How much did you overlap the panels?
Did you use fine line tape to mark the panels?
Any input appreciated.
Cheers
Old Jun 13, 2011, 09:52 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
"How much did you overlap the panels?"
Long time ago, but as I recall, about 1/8 inch. Just enough to ensure no gap between panels.
"Did you use fine line tape to mark the panels?"
No. That was the purpose of the opposing skuffing, to emphasize panel seperation.
Les
Poll I Buy From United Hobbies (UH) or HobbyCity, HobbyKing? -Yes or No Murocflyer Vendor Talk 334 Oct 28, 2009 07:01 AM
Discussion Spektrum AR6100 or AR6300 Rx in an SWII Kevlar Pod - Yes or No? donglass Hand Launch 6 Mar 05, 2008 12:54 PM
Corona Canopy Doublers - YES or NO? 02ViperTwin Electric Heli Talk 12 May 15, 2004 02:34 PM
E3D + GD-600. Yes or no? KatManDEW Sport Planes 14 Jun 01, 2002 12:16 PM
10 cell Twinjet, yes or no?!! Peter W Foamies (Kits) 44 Jan 15, 2002 07:03 PM
