Yeah I did, actually just a few hours ago. I brought it to work with me today and we went to Pt. Fermin for lunch. I was pretty nerves as I haven’t maidened a non EPP plane in forever and that slope is ridiculously hard to retrieve a downed plane from let alone have a controlled mayday landing if somethings not right. Anyways, she came in at 338g with a CG of 76mm. I used the settings in the manual to a T including the two throw rates and differential. While I never needed to jump up to the higher rates for the elevator the ailerons seemed a bit sluggish at the lower rates and so I ended up kicking those to the higher throws.
In a dive she pulled up only slightly which seemed correct, however rolls were slightly less axial than I had anticipated and required down input when inverted. Maybe I need to pull the CG back a tiny bit more, but I’m really a novice at that kind of thing and will need to get some friendly input. Has the manual been updated now, or are you in the middle of it as we chat? Let me know when it’s done and I’ll give it a read. If you’re interested here’s a couple links to build post I made in another thread. http://www.rcgroups.com/forums/showp...&postcount=952 http://www.rcgroups.com/forums/showp...&postcount=980 http://www.rcgroups.com/forums/showp...&postcount=989 |
USA, CA, Fort Bragg
Joined Oct 2009
Heres how I installed the aileron servos. There are much simpler ways....This is a much better thread to get help on btw... http://www.rcgroups.com/forums/showthread.php?t=610030 I didn't have any more than the original manual when I got the kit. I saw online that some people were hot gluing servos in place. Having never used hot glue, it sounded risky. After much thought, I decided to hard mount them. This did NOT make it easier. I cut off the covering as you can see, then measured what size balsa pieces I needed and CA'ed the short blocks to the long ones. Then I installed the servo to both pieces on either side. Next, I CA'ed the whole assembly in place on the wing. I used Airtronics 94803 servos. As you can see in the pic, the balsa rail is too tall. So, I carefully sanded that down. I checked the fit periodically with a piece of MonoKote held down tightly over it to see any wrinkles being made from it being too high. On the second servo, I did the trimming BEFORE I CA'ed it in place! (live n learn) I used some transparent blue I had laying around to cover the holes I had cut in the covering earlier. Hope this helps. Douglas Buzby |
![]() Oh and if you've read all 138+ pages on the other thread, I'm sure you've come across the many links to this thread pointing people to the great unofficial manual. -Jonathan |
The elevator rates on the front page stood out as being quite high to me. I have been using 2mm on low rates and 4mm on high for years. I do have a very rearward CG. I very strongly disagree with the CG locations on the front page. 65 mm for a novice is not wise. The plane will not track straight in a dive and you are at risk of stalling the tail surface in either a hard pull or slow flight. I have had my CG between 78-80mm for years. It is not twitchy at all. It flies pretty much hands off. I never did get to the point of neutral stability. More nose weight does not make for an easier to control plane for a novice. It actually makes it harder. The control throws must be appropriate, but a properly tuned plane between 75-80mm will be easier to fly than a more nose heavy plane. If you start at 75mm with control throws at 3mm on low and 6mm on high and then progressively work the CG back on successive flights while at the same time reducing the rates, you will not have problems. As far as the elevator control linkage clearance, I used a Z-bend, so there was no clearance issue. |
USA, CA, Pismo Beach
Joined Oct 2007
Hi Jonathan. I thought about moving the horiz stab back but worried about the loss of gluing surface. Probably not a big issue.
We're getting some really wild winds here today and I expect you are as well. Bummer about your "free range" ballast. There's just not too many mounting options in the tight fuselage space. My current plan is to put the Rx under the wing which doesn't leave much room for ballast. I hope to slide the Rx up under the front wing screw for a little more ballast room. Are you using 72MHz in your installation? I'm waiting for a new Minima rx to do the final fitting. Thanks for the inputs on throw from everyone. My gut feeling was that the recommended seemed kind of large. |
| Thread Tools | |
| Help! instruction manual | kiter32 | Radios | 1 | May 14, 2011 07:00 PM |
| Free pz p51 instruction manual | EDFPILOT | Free Items | 2 | Apr 04, 2011 01:44 PM |
| Wanted: Instruction Manual for SR Cutie | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 2 | Jul 23, 2002 09:39 AM |
| needed: Instruction manual for FMS Supernova 250S | Keitha | Aircraft - Electric - Airplanes (FS/W) | 3 | Jun 18, 2002 07:11 PM |
| bandit instruction manual | tqpham | Electric Sailplanes | 3 | Mar 27, 2002 06:24 PM |
