Old Aug 25, 2003, 01:20 AM
KasperE is offline
Find More Posts by KasperE
Crash frequency declining
KasperE's Avatar
Copenhagen, Denmark
Joined Jul 2003
How durable are carbon blades?
Hello All,
I have been thinking of buying som carbon blades for my Pic Pro. However, I'm still learning to fly the thing so its taking some abuse
So, how durable are carbon blades? Do they crack? Can they be repaired?
-Kasper
KasperE is offline Find More Posts by KasperE
Old Aug 25, 2003, 02:42 AM
AtomHeartMother is offline
Find More Posts by AtomHeartMother
Shine On !
AtomHeartMother's Avatar
Northern Ohio
Joined Feb 2003
They're very tough. I've never seen one snap or crack like a plastic blade.
Most of the time, you'll see small chips on the tips or leading edges of the CF blades-depending what you hit. But it does take a pretty hard thump against a pretty hard object, even to get them to do that.
Just remember, they're hard...and if you're flying in the house, CF blades will do alot more damage to whatever you come in contact with. The weak point with any blades is where they bolt on. The pivot point and hole doesn't usually have much material around it. I have some Hornet CF blades on my hummingbird. They're awesome blades, but they'll break readily right where they bolt on. Hopefully, in your case the Pic CF blades have more material there. Might be something worth looking into. Also, in SOME cases you may need to re-gear slightly to handle the CF blades. The undercamber in them doesn't give like plastic. Sometimes a motor needs more grunt to swing them like it did with the plastic blades. Most of the time going down one tooth on the pinion is enough to do it. Whew...man is this response getting windy..anyway..good luck !
AtomHeartMother is offline Find More Posts by AtomHeartMother
Discussion How heavy are your blades ??? Or can they be ? Cooker Micro Helis 2 Jan 09, 2007 09:26 AM
Discussion How are Carbon Fiber Blades? Pipercub18 Micro Helis 9 May 12, 2006 08:50 AM
Blades...And how sensitive are they to weight imbalance? smste2 Micro Helis 5 Aug 22, 2004 03:51 PM
ESCs: Just how durable are the parkflyer ones? shazi Parkflyers 4 May 15, 2002 03:27 PM
Are the carbon hornet blades THAT much better than the stock blades? Spaulding Electric Heli Talk 10 Apr 04, 2002 07:29 PM
