Old Jun 15, 2011, 07:33 AM
khaled_abobakr is online now
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Originally Posted by porcia83 View Post
I got a manual with my plane but it doesn't say anything about the cog. I always tuck my battery as far forward as possible when using an 1800, and maybe about an inch or inch and a half back from the front when using a 2200.
Thanks a lot for the reply ... I really appreciate it ... actually the 72 mm from leading edge was mentioned somewhere in other thread so I took not of it ...
BTW... Could you please post your list of mods you have done to your Bixler ..??
Thanks again
Khaled
khaled_abobakr is online now Find More Posts by khaled_abobakr
Old Jun 15, 2011, 12:30 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
I did notice it's a touch smaller than the Sky Surfer, a bit "leaner".
How is it smaller or "leaner"? What dimensions exactly?
jrjr is offline Find More Posts by jrjr
Old Jun 15, 2011, 04:10 PM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by Colonel Blink View Post
I think I just changed my mind!
If you get the KIT version and use your own servos and other bits You could put it together OK. I must say that the stock Motor and the 6X4 prop I put on makes it go well. Verticle at full throttle.
Flypoppa is offline Find More Posts by Flypoppa
Old Jun 16, 2011, 07:04 AM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
I'm just thinking that a spare of wings for my EasyStar and a couple of servos would be cheaper and less to carry up onto the Moor....
Colonel Blink is online now Find More Posts by Colonel Blink
Old Jun 16, 2011, 09:33 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I expect you are correct. I had to get one of these Bixy thingys just to see what the fuss was all about.
I think we have both said, " You get what you pay for"
I have just changed the control horns as the original are brittle. I have already changed the aileron servos and had to order some more today (Giant cod) so I can replace the others.
Well it gives me something to do, as I am recovering from a nasty prop bite. Left hand across the nuckles down to the bone.
How did it happen? ask my mate Jeff aka Upup.
Well I launched too late, and he opened the throttle too early.
Old Jun 16, 2011, 10:56 AM
porcia83 is offline
Find More Posts by porcia83
United States, CT, Hartford
Joined Jun 2009
Leaner in that it's just a touch thinner (at least at the nose) than the Easy Star or Sky Surfer.
I had a quick first flight to trim her out running on a 1000 mah battery all the way forward. Second flight did not go well. Launched her into the wind at 80% throttle and it went straight up, the right back down. Luckily it was in tall grass but still went straight in and split the nose in two and dented the battery. These ARE tough little planes. What happened was the elevator control horn cracked and I had no control. So yes, they really should be changed because they are pure crap. I put thicker ones on that came from my T-28 Trojan carcass.
3rd flight today went well, except when it crashed. Had about 6 minutes of nice flight, just taking it through some paces. I did want more throw on the ailerons, didn't feel like I had enough. Coming through a gentle turn at about 75% throttle the wings came out of their sockets and started to flap. I was about 100 feet up, and it was drifting down nicely. then the wing came out and it nosed in again. I was at a different field with even taller grass so that saved it. just a piece of foam came out by the wing. I guess I'll have to glue or blenderm tape the wings in moving forward.
Overall, it's still an excellent little all around plane to fly. On the 1000 mah battery with no engine it floated very nicely and will most assuredly thermal in the right wind.
porcia83 is offline Find More Posts by porcia83
Reply With Quote  (Disabled)
Old Jun 16, 2011, 01:52 PM
porcia83 is offline
Joined Jun 2009
fixed the issues, glued the spar into the wing and reglued the vert and hor stabs. put it back in the air with a 1300 and got almost 15 minutes with mininal throttle.
Old Jun 16, 2011, 01:57 PM
Joined Nov 2006
Hi ..
Please forgive the newbie questions here .. it's my 1st foamy after all
1-Should I use foam safe CA or epoxy to assemble the plane ?
2-How do I fix the motor in the motor compartment.. (BL inrunner )?
Thanks a lot
Khaled
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
You should check out the first page of this thread. There are several methods of securing the wings to prevent that from happening. I have my own design in mind and will post that when I get my kit if it works out good.
http://www.rcgroups.com/forums/showthread.php?t=1231310
Old Jun 18, 2011, 01:25 PM
heymak is offline
Find More Posts by heymak
Long time newbie
USA, TX, Katy
Joined Nov 2006
I got my Bixler today.....
The connectors on the motor leads were too small, as I do not have the female ones of that size. But I have loads of the next size up. How do I remove them as the wire is so short?
I had to cut the foam at the join from the top of the wing saddle to the cockpit and lifted the wires out. Removed the connectors and replaced them with others from stock. I replaced the wires and re-glued the foam.
Flypoppa, since you've cut into your bixler can you tell how they mounted the outrunner inside the nacelles? Inquiring minds want to know..
heymak is offline Find More Posts by heymak
Old Jun 18, 2011, 03:30 PM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I did not cut as far as the motor. But I believe that there is a plastic mount that the motor is attached to. I also believe that there are some pictures of it on this thread.
Old Jun 18, 2011, 05:41 PM
dssaction is offline
Find More Posts by dssaction
Dssaction
dssaction's Avatar
Canada, QC, Laval
Joined May 2009
i realy dont like the lenght of the cabel moter so i will add he few inch!!!
can some one tell me what cande of conecter i nead to conect the moter to my esc?
also i add he pic of the moter mount.it is made of wood glue inside.ther is 2 screw to secure the moter.
dssaction is offline Find More Posts by dssaction
Old Jun 21, 2011, 12:27 PM
porcia83 is offline
Joined Jun 2009
3.5mm should work for that.
Old Jun 23, 2011, 12:52 AM
heidan is offline
Find More Posts by heidan
Holmegaard, Denmark
Joined Jul 2007
Weight of stock motor
Hi.
Does anybody know the weight of
the stock motor?
Regards
Dan.
heidan is offline Find More Posts by heidan
Old Jun 23, 2011, 01:31 AM
garymcc is offline
Find More Posts by garymcc
West Texas USA
Joined Mar 2008
Originally Posted by heidan View Post
Hi.
the stock motor?
Regards
Dan.
FWIW the weights of the components of the V2 Sky Surfer are listed here. I assume they are using the same brushless motor in the Bixler.
My Sky Surfer brushless weighs about 45g.
garymcc is offline Find More Posts by garymcc
Discussion Hobby King Ryan STA EPO Coenraad Scale ARF/RTF 244 Feb 16, 2015 10:10 PM
Discussion Hobby King Pearl EPO Glider Thread tomcor Foamies (Kits) 34 Aug 29, 2013 10:51 PM
Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" trees Pusher Prop Jet Models 252 Oct 21, 2012 09:10 PM
New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO Cheetah401 Micro Ready-to-Fly 9 Apr 18, 2011 04:11 PM
New Product Hobby King 2.3M EPO EP Ventus PNF Doubletap Electric Sailplanes 1 Apr 05, 2011 10:00 PM
