Old Feb 17, 2013, 04:18 PM
warp45 is offline
Find More Posts by warp45
warp
Michigan
Joined Jun 2007
Spoilerons
Thank you all for your comments and help. I am beginning to understand the difference between the flaps (going down) and spoilerons (going up), and I will take my time to learn how the Bix flies first.
Just for coureosity, can flaps and spoilerons be programed at the same time? I'm thinking that perhaps using spoilerons to get down faster, then flaps for a slower landing. Would that work or is it overkill?
warp45 is offline Find More Posts by warp45
Old Feb 17, 2013, 04:50 PM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Depending on your transmitter, it is possible and straight forward to program both. But I doubt if you'll really need it. If you don't load your Bixler with a very heavy battery pack, it will fly nice and slow. Bring it into the wind nose first when landing, flare it out, and landing speed will be very slow.
Getting the approach just right (height, speed, direction) is much more important than the ability to apply spoilers or flaps
I find spoilerons more useful than flaps, as I often fly from areas with very restricted space, and I need to bring the plane down in a steep angle.
But if you like experimenting, go ahead and try it. That is also an aspect of our hobby that many people (my self included) enjoy almost as much as the actual flying. I have tried many well working mods only once or twice before they had to give way for another mod
happy landings
mike_o is offline Find More Posts by mike_o
Old Feb 18, 2013, 01:39 AM
Mac50L is online now
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
You don't have to use a programmable the Tx for flaperons. A mixer running off the Rx would allow you to use two channels, ailerons as usual and dropping (or raising) both ailerons together on the other channel.
Adding flaps or spoilers to the V1.1 could be done with these inboard of the ailerons and simply taped on acting like split flaps. Tape the servos on too. Doesn't work? Rip the tape off and go back to standard.
NOTE - with this system and usually the servos lying in opposite directions you will need to rewire one servo to reverse it.
Another job to do, prove it does or doesn't work....
Mac50L is online now Find More Posts by Mac50L
Old Feb 18, 2013, 04:49 AM
mike_o is offline
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Originally Posted by Mac50L View Post
...Tape the servos on too. Doesn't work? Rip the tape off and go back to standard.
NOTE - with this system and usually the servos lying in opposite directions you will need to rewire one servo to reverse it...
Well, if you are taping the servos in place, why not put them in the same orientation? Then you can skip the soldering/re-wiring job.
If the mod turns out to be a must have, you can cut recess holes in the wing foam for the servos, either in the same orientation or symmetrical and re-wire the servo.
When I add aileron servos to my stock (non-aileron) EasyStar wings, I embed the servos vertically, protruding on the top side of the wing (out of harms way) and I can invert the direction by rotating servo arm to the opposite side:
Note/edit: In the picture, the servo arm is off-set by app 30 degrees CW to provide mechanical, differential aileron throw (more up than down to prevent adverse yaw). For a flaperon function, no mechanical offset, but rather a mixed/programmed off-set should be used
Old Feb 18, 2013, 03:57 PM
chodebomber is offline
Find More Posts by chodebomber
United States, AZ, Phoenix
Joined Feb 2012
I just ordered the bixler 1.1 kit! My question is what length servo y splitter is needed for the wing servos?
chodebomber is offline Find More Posts by chodebomber
Old Feb 18, 2013, 04:47 PM
Joined Oct 2011
Originally Posted by chodebomber View Post
I just ordered the Bixler 1.1 kit! My question is what length servo Y splitter is needed for the wing servos?
Very long if you don't put extenders on the servo leads. The kit comes with (as far as I remember) a short Y. So, if you haven't ordered extender wires you have choices. Order extender or order longest Y possible or find suitable wire and splice that in to extend the servo leads. I did the later as I had suitable wire handy and used the short Y provided.
Sometimes old (really old?) TVs have bundles of thin wire. An old computer using the ATA disk ribbons and split off in bundles of 3. They should peel apart easily. Do order a good range of heatshrink tubing and a 25 watt soldering iron with not too fine a tip. Use lead solder, forget this "organic", clean planet rubbish, LEAD solders easily and does a good join - and I'm still alive after years of using lead (60:40) solder!!!!
Laying the servos the same way for flaps, yes, I did say the option was to rewire ("and usually the servos lying in opposite directions"). However, especially as the suggested was just for trial, lay them the same way as Mike_O said.
Old Feb 18, 2013, 05:07 PM
Joined Feb 2012
I'll go get some extenders then! Thanks!
Old Feb 19, 2013, 12:32 AM
Joined Oct 2011
Just checked, with a servo lying on the wing, 30 cm is a good length. Get 4, 2 for the rudder and elevator servos too. It makes connecting them to the Rx so much easier.
Also get a plug for the ESC (XT60) and pins (3.5mm), male and female to connect the motor to the ESC. Also you will need to extend the wires from ESC to motor unless you mount the ESC up near the motor in which case you need to extend the leads to the battery and Rx (servo type lead).
Nothing is quite straight forward with the ARF or kit - but then that's the fun of it...
Old Feb 19, 2013, 12:48 AM
b.b.4 is offline
Find More Posts by b.b.4
b.b.4
b.b.4's Avatar
United States, IL, Hoopeston
Joined Jan 2012
It is 13.5 in. from edge of servo box, to the center of the fuse. Just solder the extra length you need to your servo wires. Easy and neat, with or w/o a Y lead. Use al'rn. and aux. channels for flaperons.............
b.b.4
b.b.4 is offline Find More Posts by b.b.4
Old Feb 19, 2013, 06:48 AM
rclab1 is online now
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
is the Original (OEM) motor that comes with the v1.1 (1900kv) sufficient for extra FPV weight?....no GoPro use, just basic FPV gear.....
I have plenty of APCe 6x4 on hand for only modification....
rclab1 is online now Find More Posts by rclab1
Old Feb 20, 2013, 12:40 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
hey guys started my 1.1 FPV build 2 nights ago.
Bixler v1.1 FPV build (5 min 43 sec)
After having the servos installed in the provided slots, it was brought to my attention i should move them back to tha tail to help with the forward cg.
So when doing so, i was cutting the Z bends so i could pull the rod out the end.and snipped my Dragon link antenna... whlie i was working out the second servo, i felt something hit my foot, looked down and JAW DROPED//plus a few choice words. lol... i see a 5'' peice of calbe/heat shrink..i was hoping it was heat shrink untill i see the nice gold SMA at the end... It was 3:30am and i was tired. Good thing i won 2 DL RX's resently and they should be on the way. So i have a 30'' and a 36'' one da way...
Plus Mike(jet pilot )gave me a new V2(lastest upgraded) RF board to toss in my case..how cool is that...
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Feb 21, 2013, 11:15 AM
USA
Joined May 2010
corrected....
Old Feb 21, 2013, 11:26 AM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
how much of the video did you watch? If none, just watch the first 1:30sec's
Old Feb 21, 2013, 08:39 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Originally Posted by rclab1 View Post
corrected....
haha yea im going to go with the 2826 and a 6x4 prop should Haul with this set up.
Old Feb 21, 2013, 08:55 PM
USA
Joined May 2010
I just saw this with that motor you mentioned!
I LIKE!!!!!
Fast Bixler 1400mm (2 min 44 sec)
Discussion Hobby King Ryan STA EPO Coenraad Scale ARF/RTF 244 Feb 16, 2015 10:10 PM
Discussion Hobby King Pearl EPO Glider Thread tomcor Foamies (Kits) 34 Aug 29, 2013 10:51 PM
Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" trees Pusher Prop Jet Models 252 Oct 21, 2012 09:10 PM
New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO Cheetah401 Micro Ready-to-Fly 9 Apr 18, 2011 04:11 PM
New Product Hobby King 2.3M EPO EP Ventus PNF Doubletap Electric Sailplanes 1 Apr 05, 2011 10:00 PM
