Michigan
Joined Jun 2007
Great to hear from you all.
I also did use blenderm on all of the hinges after flexing them quite a bit. It seems to work well. I did also get some pin hinges for when the foam breaks apart. I'm ready to test fly but the weather stinks - a blizzard now and 15 degrees out. I'm glad I'm not the only old one out there still trying to fly. I started with a 450 heli and decided that my reflexes aren't that good anymore so I wanted to get the airplane down first in the hope that it will strengthen my heli skills too. |
Bixler v1.1
This 74 year young'in has a ?????
I flew my Bix with a pwr zoom 400 mtr., into a fog bank last week , full pwr. 80+ mph-? You guessed it, could'nt find all the pieces. I have a Bix v1.1 on the way. My ? is, are you doing most of the MODS on the v1.1 that you did on the original Bix. I understand it has good servos and horns. Does the v1.1 use the same mtr. as orig. ? Any advise is WELCOME... b.b.4 |
Michigan
Joined Jun 2007
B - 1.1
I made the mods to my new 1.1 that I described in this forum. I never had the 1.0 so I can't say what the difference might be. I think the stock motor appears to be good enough for my learning purposes.
I did find that the motor mount when slipped into the foam fuse, allowed the motor to move out of alignment with the fuse. The motor shaft would get maybe 2-3 degrees off of the center line of the fuse and move back and forth. I held it straight and hot glued the motor mount to the foam to hold it straight. The new servos and the horns are solid so far. But, I'm waiting for the weather to calm down so i can test fly it. |
New Zealand, Canterbury, Rolleston
Joined Oct 2011
My V1.1 kit replacement arrived a day ago. I'm fitting hinges at present. I see the rudder is bigger than on the V1. Also the motor bay has a top cap meaning I will assemble the halves and then glue the motor mount in gluing it to both halves this time. The top cap will be held on some how but still be removable. Valve grind or replace pistons? WHAT? All electric, well I never...
![]() There is no cap over the wing spar but a groove for the servo wires. Another solder job possibly to lengthen the wires to the new servos. Though I didn't have any problems, new servos seems a sensible idea - they are cheap enough. The V1.1 also comes with an anti-crash device - a pilot ![]() The old Bixler's wing is still usable so will have to design and build something interesting to use it on. |
United Kingdom, England, Consett
Joined Feb 2012
What about the Bixler 2 wings? Can anyone see if they fit in the Bixler 1's ?
I was thinking that if I wanted to replace the wings I could maybe grab the Bixler 2 wings rather than buy a whole new Bixler as they sell the Bixler 2 wings individually. |
Michigan
Joined Jun 2007
For the heads up crowd:
I was going to put air ducts on my new Bixler V1.1 like those suggested in the Pogo blog (though that build was for the V1.0). The in-coming duct was to go on the top of the fuse just in front of the pilot, and the exhaust duct on top of the fuse just after the motor (like the pictures in the Pogo blog). I was about to cut the holes and then realized that there is a big difference between the V1.1 and the V1.0, because of where the 1.1 now has placed the two servos for the tail. There is now a reinforcement partition that blocks any air flow through the fuse after the servos and right under the motor mount. No air would get to the duct on top and behind the motor. The whole fuse tail area, from the motor mount to the tail, can't get any air flow. I could put exhaust ducts on the right and left of the fuse under the wings, but I don't care to go to the trouble right now. I'm going to see how hot the ESC gets after a few flights before I go the the trouble of putting air ducts in. |
Michigan
Joined Jun 2007
The problem is however, the 1.1 doesn't have space on the top like in the YouTube idea for the 2.0, as the two screw holes to hold the wings on are up there and I don't want to weaken the foam around that area. I'd have to put the ESC on the outside and under the wing someplace and probably without any cutout to fit it into (to cut down on air resistance). I'll see how hot the ESC gets before I go that route. Any other recommendations? Thanks. |
Michigan
Joined Jun 2007
Here is a motor thrust line question for the Bixler V1.1.
Should the motor shaft be in line with the fuse center line from nose to tail? Or, should the motor be offset right or left (looking from the rear)? I got to thinking that perhaps that is why they have allowed so much side to side movement of the motor in the slot - to allow for thrust line adjustment if necessary. |
| Thread Tools | |
| Discussion Hobby King Ryan STA EPO | Coenraad | Scale Electric Planes | 217 | Today 02:15 AM |
| Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" | trees | Pusher Prop Jet Models | 252 | Oct 21, 2012 09:10 PM |
| Discussion Hobby King Pearl EPO Glider Thread | tomcor | Foamies (Kits) | 14 | Aug 19, 2012 07:39 AM |
| New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO | Cheetah401 | Micro RTF | 9 | Apr 18, 2011 04:11 PM |
| New Product Hobby King 2.3M EPO EP Ventus PNF | Doubletap | Electric Sailplanes | 1 | Apr 05, 2011 10:00 PM |
