That one is the bare foam airframe KIT no electronics, if you want the ARF with motor/servos is also back in stock here: http://www.hobbyking.com/hobbyking/s...arehouse_.html BTW, if you get the ARF version, all you need to add is an ESC, so drop one of these in your cart: http://www.hobbyking.com/hobbyking/s...to_39_Amp.html |
Liverpool, UK
Joined Jul 2006
guys im a beginner (so go easy on me...please
)i recently received my bixler an i'm desperate to get her up in the air, in my rush i have purchased a zippy 2200 2c 7.4v lipo will that be sufficient? i thought they were 11.1v? its untouched still in all of its wrappers etc as it arrived, i'm guessing - remove washers from nose, shove the lipo as far forwards as i can an see how she balances out. i'm going to reinforce the wings with cf rod inside the original tube too. i need the wings to be removable ive only ever flown 3chl planes before thanks |
United Kingdom, England, Ripon
Joined Dec 2011
2S is just fine for these EZ style models, but you should change the prop to get more thrust out of the power system, I run all of my EZ style models on 2S and the appropriate prop, and they climb out easily at 60-70 degrees, I use an APC 6x5.5e on the stock Bixler motor, which provides plenty of thrust/speed. |
Joined Dec 2011
I put the same Zoom motor in my Bix., and have the same lawn dart problem. What did you do to fix the darting ??????????? Byron......... b.b.4 |
United States, CA, Sebastopol
Joined Dec 2010
I launch mine at about 1/2 throttle with the stock motor and it does fine. When flying, full throttle will make it nose-over some, so I can see if you launch at full throttle with a more powerful motor you'd have some trouble. You don't need much power to launch. Big wings get the job done.
| Thread Tools | |
| Discussion Hobby King Ryan STA EPO | Coenraad | Scale Electric Planes | 217 | Yesterday 02:15 AM |
| Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" | trees | Pusher Prop Jet Models | 252 | Oct 21, 2012 09:10 PM |
| Discussion Hobby King Pearl EPO Glider Thread | tomcor | Foamies (Kits) | 14 | Aug 19, 2012 07:39 AM |
| New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO | Cheetah401 | Micro RTF | 9 | Apr 18, 2011 04:11 PM |
| New Product Hobby King 2.3M EPO EP Ventus PNF | Doubletap | Electric Sailplanes | 1 | Apr 05, 2011 10:00 PM |
