Old Jul 04, 2012, 05:09 PM
b.b.4 is offline
Find More Posts by b.b.4
b.b.4
b.b.4's Avatar
United States, IL, Hoopeston
Joined Jan 2012
Originally Posted by Doubletap View Post
I setup all of my planes with dual rates on both Ailerons and Elevator, but it's really only so I can safely hand the controller to someone else. also, I use lots of negative expo on ailerons on both low and high rate, which works great to decrease sensitivity and increase precision near center stick, but still allows aggressive control response when wanted by simply banging the stick to the stops. Particularly on ailerons, I like all of my models regardless of type to roll axially as if they are chucked up in a drill motor!
Individual settings are just that, it depends on your personal mechanical setup and your personal abilities, so it's really difficult to suggest computer radio settings for rates and exp, what works for one person could be a fatal crash for someone else.
Thanks Doubletap, that helps a lot.... What COG are you and OTHERS using with a 2200 battery and no washers ???
b.b.4 is offline Find More Posts by b.b.4
Old Jul 04, 2012, 06:16 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
I use several different 2200 mah 2S but use mostly these 2:
http://www.hobbyking.com/hobbyking/s...dproduct=16778
http://www.hobbyking.com/hobbyking/s...dproduct=14972
I also use a HobbyWing 30 ESC, and my bixler without washers, balances right around the middle of the wing rod covers, and it flies just wonderfully at that CG.
Doubletap is offline Find More Posts by Doubletap
Old Jul 07, 2012, 09:28 AM
DragonFly711 is online now
Find More Posts by DragonFly711
Will try to fly anything.
DragonFly711's Avatar
United States, TX, Athens
Joined Dec 2011
Hey guys,
Took the Bixler out flying on the 4th of July. Camera clipped to side of my cap.
bixler july 4th (30 min 1 sec)
bixler july 4th 2 (20 min 6 sec)
Pretty boring to watch but it was fun flying. Over 30 flights now with no problems or crashes, knock on wood.
Donnie
DragonFly711 is online now Find More Posts by DragonFly711
Old Jul 22, 2012, 07:53 AM
underbird is offline
Find More Posts by underbird
underbird's Avatar
United States, WI, Pewaukee
Joined May 2011
Flew the bixler with a gopro over water
HK Bixler Over the Bay (4 min 4 sec)
underbird is offline Find More Posts by underbird
Old Aug 03, 2012, 09:00 PM
MaladroitFL is offline
Find More Posts by MaladroitFL
Flyin' low & slow T-28s!
MaladroitFL's Avatar
United States, FL, Vero Beach
Joined Feb 2011
Bix 2?
HobbyKing Super Daily - HK Bixler 2 (6 min 35 sec)
MaladroitFL is offline Find More Posts by MaladroitFL
Old Aug 03, 2012, 11:20 PM
Doubletap's Avatar
Joined Jul 2005
Originally Posted by MaladroitFL View Post
Bix 2?
Yes, that is the newly released larger and enhanced Bixler 2, here is the thread:
http://www.rcgroups.com/forums/showthread.php?t=1703262
Old Aug 08, 2012, 12:19 AM
b.b.4 is offline
b.b.4
b.b.4's Avatar
Joined Jan 2012
motor help...
Can someone tell me WHY the motor shaft in the Bixler came loose inside the motor.? The shaft slid back into the motor and is free spinning. I can pull it back out and the motor will run, but the shaft slowly slids back inside and won't spin the prop. Is there an E-clip inside the motor that came off or broke ? The plane did not crash, it just came loose doing while flying ?????????
Old Aug 08, 2012, 02:58 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
If I recall mine did the same. There was no clip on the end, of if there was it must have come off.
I dumped the motor and replaced it with a 1400kv that I had in stock.
Flypoppa is offline Find More Posts by Flypoppa
Old Aug 10, 2012, 02:03 PM
Doubletap's Avatar
Joined Jul 2005
Stumbled on this new source of Sky Surfer/ Bixler, good price also for USA seller. Toysonics has the Sky Surfer w/ brushless motor for $49.99:
http://toysonics.com/sky-surfer-4ch-...ess-motor.html
Old Aug 13, 2012, 12:52 AM
b.b.4 is offline
b.b.4
b.b.4's Avatar
Joined Jan 2012
YES, I did the same thing. I put in a POWER ZOOM 400. Much more aerobatic. Thx for the suggestion. I used the same [original] motor mount. Did not need any trim !!!
Old Aug 13, 2012, 08:34 PM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
sunset
Belcarra sunset with Hobbyking Bixler gopro2 (3 min 47 sec)
Westwood is offline Find More Posts by Westwood
Old Aug 18, 2012, 06:31 AM
Joined Feb 2011
Same here. The Power Zoom 400 from HeadsUpRC is the perfect motor for the Bix. It fits the existing mount and supplies much more power and reliability.
Old Aug 21, 2012, 01:34 AM
yakav is offline
Find More Posts by yakav
Russian Federation, St Petersburg
Joined Jul 2012
Привет ребята, бикслер продолжает летать без мотора.
Bixler на Планерной горке тоже летает (4 min 5 sec)
Bixler slope soaring (2 min 12 sec)
Cut the engine and fly on the slope, Bixler very good glider.
BIXLER slope (2 min 45 sec)
yakav is offline Find More Posts by yakav
Old Aug 21, 2012, 11:04 AM
Doubletap's Avatar
Joined Jul 2005
Bixler 1 ARF back In stock at USA Warehouse! Get them while still available!
http://www.hobbyking.com/hobbyking/s...dproduct=18083
Old Aug 22, 2012, 07:35 PM
king1522 is offline
Find More Posts by king1522
Duncanville, TX
Joined Sep 2010
Bixler as three channel?
I know this question has been asked before but I can't find the answer. Can the Bixler be configured as a three channel. I.e. only rudder and elevator? If so, does it fly ok?
Don
king1522 is offline Find More Posts by king1522
Discussion Hobby King Ryan STA EPO Coenraad Scale ARF/RTF 244 Feb 16, 2015 10:10 PM
Discussion Hobby King Pearl EPO Glider Thread tomcor Foamies (Kits) 34 Aug 29, 2013 10:51 PM
Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" trees Pusher Prop Jet Models 252 Oct 21, 2012 09:10 PM
New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO Cheetah401 Micro Ready-to-Fly 9 Apr 18, 2011 04:11 PM
New Product Hobby King 2.3M EPO EP Ventus PNF Doubletap Electric Sailplanes 1 Apr 05, 2011 10:00 PM
