prop & adapter
I bought this two props for my Bixler but it doesnt fit well with the stock adapter. Whats the suitable adapter for this two?...
1. http://www.hobbyking.com/hobbyking/s...idProduct=7936 2. http://www.hobbyking.com/hobbyking/s...idProduct=9873 |
Guys I got my bixler ARF yesterday but one of its wing tip is bend a lot due to other stuff hk put inside my bixler package..!!
https://lh4.googleusercontent.com/-c...2/DSC06656.JPG https://lh3.googleusercontent.com/-D...2/DSC06673.JPG What should i do ?? anyone can suggest something please . thanks ZR |
United States, CA, Sebastopol
Joined Dec 2010
Joined Jan 2011
I took my new bixler up for the first time today. What a fun machine! It was pretty windy so I managed some zero ground speed and backwards flight. I bought an ARF and did some modifications before flying...
25A turnigy plush esc 2.6Ah 3s lipo replaced elevator and rudder control horns and clevises with dubro horns and e/z connectors... the stock horns felt thin and brittle 3mm spar down the belly and up the vertical stabilizer... there were cutouts for them so it seemed like a good idea removed washers in the nose trimmed some foam out of the inside of the motor mount that was touching the motor trimmed some foam out of the rudder to allow full elevator travel taped wings on... I have a feeling I will need to do the sticky-hook-and-rubber-band thing down the road I got 12 minutes of full throttle for about 55 minutes of flight... really a cool toy. I could not get it to sustain a stall or spin, and could not get it to do an aileron roll but perfect loops were really easy. Climbs above 50 degrees... very fast to height, and that is with the stock prop |
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Wing retainer hooked over the 3M hook, with rubber band to lock it on to the hook. Marks and numbers for CoG. - |
Joined Jan 2011
Joined Oct 2011
Not rolling - not enough power on? Half or more power (depends where your power/speed setting is), slight nose up, stick hard left or right... |
Joined Oct 2011
Wiggle the stick to make the ailerons wiggle. Presuming we're talking about a beginner flyer (otherwise they wouldn't need to read this), the plane should "jiggle" (for want of a better word) and the pilot can get the feel of the reversed controls, reversed because we are now inverted.
Also most important, those ailerons hinges need to be totally free moving otherwise the plane's reaction to control input is so slow. |
Joined Dec 2010
| Thread Tools | |
| Discussion Hobby King Ryan STA EPO | Coenraad | Scale Electric Planes | 223 | Yesterday 03:51 AM |
| Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" | trees | Pusher Prop Jet Models | 252 | Oct 21, 2012 09:10 PM |
| Discussion Hobby King Pearl EPO Glider Thread | tomcor | Foamies (Kits) | 14 | Aug 19, 2012 07:39 AM |
| New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO | Cheetah401 | Micro RTF | 9 | Apr 18, 2011 04:11 PM |
| New Product Hobby King 2.3M EPO EP Ventus PNF | Doubletap | Electric Sailplanes | 1 | Apr 05, 2011 10:00 PM |
