Old Mar 12, 2012, 01:02 PM
ihor14448 is offline
Find More Posts by ihor14448
ihor14448's Avatar
Strongsville, OH
Joined May 2007
Ok I will try that next time I fly.
I flopped the plane on the ground pretty hard, the wings detached, so theres no sure way of confirming that the battery came out.
ihor14448 is offline Find More Posts by ihor14448
Old Mar 12, 2012, 04:13 PM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
I do about the same; 30 paces and check that the flappy bits wiggle and the motor whizzes when I ask it to. As I am on 35MHz, I do it with Tx antenna retracted, and I point the antenna directly at the model (thereby putting the model in the Tx weak spot). I then turn my back on the model and recheck. Then when I get back to the model, I check the sense of the controls (ie L for L, up for up etc).
Only takes a minute of one person's time.
Colonel Blink is online now Find More Posts by Colonel Blink
Old Mar 13, 2012, 06:43 AM
MaladroitFL is offline
Find More Posts by MaladroitFL
Flyin' low & slow T-28s!
MaladroitFL's Avatar
United States, FL, Vero Beach
Joined Feb 2011
Originally Posted by olthump View Post
I'm still slowly getting mine built.
Greg (ex Akron boy)
"S L O W L Y" ?
Stop understating things, Greg.
MaladroitFL is offline Find More Posts by MaladroitFL
Old Mar 15, 2012, 01:17 PM
Simon2504 is offline
Find More Posts by Simon2504
United Kingdom, England, Ripon
Joined Dec 2011
Latest flight vid with my new homemade anti vibration mount
HobbyKing BIxler, Ripon Racecourse (11 min 7 sec)
Simon2504 is offline Find More Posts by Simon2504
Old Mar 15, 2012, 07:05 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
Nice Video!
After mine crash landed, the mount came loose, didnt bother to fix it. In process to converting it to twin puller
Old Mar 15, 2012, 11:35 PM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Originally Posted by ihor14448 View Post
Nice Video!
Changing it to a twin tractor isn't going to solve the problem.???
Why dont you just re glue the mount, work out what went wrong, fix it and get it back in the air. There is nothing wrong with the fundamental design of the plane (in fact its a proven design) but there are a few things that can go wrong with the cheap hardware.
Did you replace all the stock horns and aileron pushrods? It could be that one of the control horns has come loose??? have you checked the servos? Have you done a range check?
Before you go modifying it i would just make sure everything else is right, these things fly great in the standard set up.
nogas is offline Find More Posts by nogas
Old Mar 16, 2012, 12:24 AM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
No the battery falling out is the reason im pretty sure.
I just always wanted a twin If it does not work its not a big deal I will just fill in the holes and put the motor back in.
All the servos move nice and the control horns are good I epoxied then but I did get one with screws for the elevator because if that fails im screwed.
Lol the reason I made it a twin is cause I wanted a twin not cause I dont like how it flies
Old Mar 17, 2012, 11:43 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
With stock motor ARF:
stock ARF prop 140w 12Amp 435g thrust.
5x5 prop 154w 14Amp 330g thrust.
6x5 prop 180w 16Amp 635g thrust.
With 2826/6 2200kv motor:
6x5 prop 240w 20Amp 780g thrust.
6x4 prop 250w 23Amp 640g thrust.
Conclusion: 6x5 prop is best for both motors.
octane81 is offline Find More Posts by octane81
Old Mar 24, 2012, 12:59 AM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
Flying at school yard after work
Hobbyking bixler EPO ARF flying at school Yard (5 min 36 sec)
westwood"s channel www.youtube.com/user/9westwood9
Westwood is offline Find More Posts by Westwood
Old Mar 24, 2012, 08:02 AM
olthump is offline
Find More Posts by olthump
Occupying RCG
olthump's Avatar
United States, MS, Ocean Springs
Joined Sep 2009
Westwood,
I'm not a big video fan, but your's was marvelous.
Your son's enthusiasm and camera skills were very evident throughout, and your flying skills are well honed. You fly that Bixler like I fly my Champ!
Thanks to both of you for my Saturday morning smile.
On the Champ thread, we award "Kornys" for excellence. You get the top score.
olthump is offline Find More Posts by olthump
Old Mar 27, 2012, 09:15 PM
Westwood is offline
Canada, BC, Burnaby
Joined Oct 2010
my bixler over the water with GoPro Hero
Porteau Cove Vancouver BC Hobbyking Bixler & Gopro Hero HD (8 min 0 sec)
Old Mar 28, 2012, 12:37 AM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
ESC setting
sorry for asking this maybe-already-been-asked question. What is the ESC setting for the Bixler with stock motor, 2200 mah batt. Im using EMAX 40a ESC with programming card....TQ
CPMBOY is offline Find More Posts by CPMBOY
Old Mar 28, 2012, 12:43 AM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
What setting do you need to know? That is a big ESC for the bixler.
evltoy is offline Find More Posts by evltoy
Old Mar 28, 2012, 01:00 AM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
yup..its big alright...I bought it to cater for future upgrades like motor and batt. Ok..the settings are:
1. brake type: Off/soft/hard
2. timming mode: low/mid/hi
3. cut off mode: soft cut/cut off
4. start mode: fast/soft/very soft
5. gov mode: OFF/gov-low/gov-hi
6. Li-XX cells: auto/2 cells/3cells/XX cells
7. cut off voltage: low/mid/hi
Old Mar 28, 2012, 04:52 AM
Johnnick is offline
Find More Posts by Johnnick
Joined Feb 2012
Originally Posted by Westwood View Post
Fantastic!
Inviato dal mio HTC Desire usando Tapatalk
Johnnick is offline Find More Posts by Johnnick
Discussion Hobby King Ryan STA EPO Coenraad Scale ARF/RTF 244 Feb 16, 2015 10:10 PM
Discussion Hobby King Pearl EPO Glider Thread tomcor Foamies (Kits) 34 Aug 29, 2013 10:51 PM
Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" trees Pusher Prop Jet Models 252 Oct 21, 2012 09:10 PM
New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO Cheetah401 Micro Ready-to-Fly 9 Apr 18, 2011 04:11 PM
New Product Hobby King 2.3M EPO EP Ventus PNF Doubletap Electric Sailplanes 1 Apr 05, 2011 10:00 PM
