Old Feb 28, 2012, 05:56 PM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
Originally Posted by ihor14448 View Post
best glue im my opinion is epoxy, you can use gorilla glue if you are careful and dont let it foam a lot.
Your tail section should be glued, the control horns need to be replaced or modded so they go inside the foam (dont glue then because they will fail)
wings can be held together with 3m hooks and rubber bands.
velcro just the electronics
glue the CF rod to one of the wings only
tape the cover strips on the wings ( the ones that cover the CF rod and the aileron servo wires)
Im sure I missed a lot of stuff tho
The gorilla glue has 2 ver...the original and epoxy...both can be use with foams. o ya...sorry for my nobbyness...what a 3M hooks?...
CPMBOY is offline Find More Posts by CPMBOY
Old Feb 28, 2012, 06:58 PM
ihor14448 is offline
Find More Posts by ihor14448
ihor14448's Avatar
Strongsville, OH
Joined May 2007
I was talking about the brown gorilla glue. Gorilla epoxy is the same thing as regular epoxy so you are good to go both ways.
3m is just a company, you can glue any hooks to the wings, hooks like these
http://www.filtersfast.com/blog/wp-c...mand-Hooks.jpg
I find them good since you can take the wing on an off everytime and during flight these will keep your wings together and from flying off.
its better to get them from a dollar store, 9pcs for 1$ compared to 3m hooks which are like 3$ for 4 or 6pcs.
Let us know how it goes
ihor14448 is offline Find More Posts by ihor14448
Old Feb 28, 2012, 07:03 PM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
sure will......thx
Old Feb 28, 2012, 09:35 PM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
Propellers
now...shopping for propellars......will these be ok...
1. http://www.rcgroups.com/forums/showthread.php?t=1548027
2. http://www.hobbyking.com/hobbyking/s...idProduct=8009
3. http://www.hobbyking.com/hobbyking/s...idProduct=7936
4. http://www.hobbyking.com/hobbyking/s...idProduct=6384
Old Feb 28, 2012, 11:09 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
What motor are you using? do you have a link?
Actually I think the best prop is 6X5.5, since it has the most potetial to move air at lower rpms while fitting onto the plane.
But those should work as long as they are not meant for nitro models
Old Feb 29, 2012, 12:15 AM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
atm its the stock motor........will upgrade it soon.....
Old Feb 29, 2012, 06:50 AM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
The TGS 6x4 (link # 3.) is the pick of the HK props for the stock bixler but for even better performance try an APC 6x4.
I tried a 6x5 with the stock motor and found it got hot pretty fast and didn't notice alot of difference in regards to performance (maybe a little more thrust at low rpms) but it did make more noise. I haven't bothered trying it with the 2826 as the 6x4 (APC) is plenty fast enough. Dont want to rip the wings off her yet.
nogas is offline Find More Posts by nogas
Old Feb 29, 2012, 07:16 AM
jpolsonb is offline
Find More Posts by jpolsonb
Australia, WA, Perth
Joined Feb 2012
i wish HK would get the 2826 back in stock
jpolsonb is offline Find More Posts by jpolsonb
Old Feb 29, 2012, 08:59 AM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
Yea I dont know anything about the stock motor since I got it as a kit.
Nogas I went against everyting I said before, I got a 2000kv with 6x5.5 that pushes jets around 85mph, Ill just be light on the throttle lol
Old Feb 29, 2012, 08:14 PM
nogas is offline
nogas's Avatar
Joined Feb 2011
Dont be in a hurry, the stock motor is great with the 6x4 APC. I only replaced it because i had another project that the bixler motor suited better.
Old Feb 29, 2012, 08:17 PM
nogas is offline
nogas's Avatar
Joined Feb 2011
Your not alone there. I wouldn't be surprised to see the next shipment go to backorders. RC timers sell them as well. (2212 - 6) I think they are around $11.
What motor is it? Have you flown it yet?
Old Feb 29, 2012, 08:20 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
its an eflite 6 series inrunner, 2000kv.
Im waiting for my dx7 to come in, then I will maiden it.
I calculated the power draw, and with my setup (eflite inrunner, 40A esc and 2200mah battery) my flight time is 4 minutes if I open throttle the while time.
Old Feb 29, 2012, 10:38 PM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
no worries on that...Im a very patient hobbyist........
Old Mar 01, 2012, 01:01 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
WOW, thats a hell of a motor. Its basically the same specs as a 2836 Turnigy by the looks of it. I would suggest getting yourself a lower pitch prop, you will rip the wings clean off the bixler with that bad boy and 6 x 5.5. but if you do try it, make sure you video it This thing is gonna fly.
Also, you will most likely need to add some weight to the nose to get the CG right with that motor, unless you are kiting it up with FPV gear straight up.??
Old Mar 01, 2012, 01:02 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
You'll need to be when ordering from HK
Discussion Hobby King Ryan STA EPO Coenraad Scale ARF/RTF 244 Feb 16, 2015 10:10 PM
Discussion Hobby King Pearl EPO Glider Thread tomcor Foamies (Kits) 34 Aug 29, 2013 10:51 PM
Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" trees Pusher Prop Jet Models 252 Oct 21, 2012 09:10 PM
New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO Cheetah401 Micro Ready-to-Fly 9 Apr 18, 2011 04:11 PM
New Product Hobby King 2.3M EPO EP Ventus PNF Doubletap Electric Sailplanes 1 Apr 05, 2011 10:00 PM
