Australia, WA, Perth
Joined Feb 2012
Hi, I have ordered a RTF Bixler and have been extensively reading all the related posts on this forum. Since reading madly for the last three days I will be ordering pretty much every recommended upgrade. I will be using the 2200 mAh battery with a 6x4 APC prop. I understand that I need to upgrade the ESC (am i right?) but the recommended one is on back order. Will this one suffice (TowerPro W30A Brushless Speed Controller) ? http://www.hobbyking.com/hobbycity/s...?idProduct=658.
What Rx/Tx upgrade would you recommend? Thank you in advance, I have the bug bad! This will be my first RC plane. |
I've been flying the bixler on a cheap HK 6Ch Tx but have got the 9X on backorder. If you are keen on getting into planks, get your self a computer radio. |
Joined Feb 2012
CPMBOY because I'm so keen to work on the plane I'll be strengthening the empennage and upgrading the wings with carbon fibre tubes and rods, replacing the servos and control linkages (horns and clevises (is that a word?) and loctite on the threads ), reinforcing with weave tape, upgrading the ESC to 30A, possibly adding some vents for cooling, running a 6x4 APC prop, balancing the aircraft for 2200 mAh 3S 20c batteries (removing nose washers), making stable platforms for the battery and some electronics out of balsa and a velcro strap, adding a small amount of spongy foam to the interior of the nose to cushion the battery in any impact, using the hook and rubber band method to secure the wings, checking any area that came glued from the factory and re-gluing if neccesary, installing gyros for the ailerons and elevators just for fun, flexing and possibly removing the ailerons and elevators and adding hinges and tape, flexing the rudder to free it up a bit and finally securing the cockpit with a rubber band as I've read you can lose it in flight sometimes. Because I'm keen to experiment with foamies and DIY designs I'll be looking at upgrading the Tx/Rx which will also allow me to play with the gyros and mix in rudder with aileron for playing around. Any suggestions for around a hundred dollars? |
| Thread Tools | |
| Discussion Hobby King Ryan STA EPO | Coenraad | Scale Electric Planes | 217 | Today 02:15 AM |
| Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" | trees | Pusher Prop Jet Models | 252 | Oct 21, 2012 09:10 PM |
| Discussion Hobby King Pearl EPO Glider Thread | tomcor | Foamies (Kits) | 14 | Aug 19, 2012 07:39 AM |
| New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO | Cheetah401 | Micro RTF | 9 | Apr 18, 2011 04:11 PM |
| New Product Hobby King 2.3M EPO EP Ventus PNF | Doubletap | Electric Sailplanes | 1 | Apr 05, 2011 10:00 PM |
