Old May 31, 2011, 08:55 AM
Narwhal is offline
Find More Posts by Narwhal
Joined Jan 2011
3.8 -> 4.8 kg of thrust needed
I need a power system that produces 3.8 -> 4.8 kg of thrust with a propeller no larger than 60cm. Does anyone know what kind of motors I should be looking at?
Narwhal is offline Find More Posts by Narwhal
Old May 31, 2011, 03:10 PM
Doug Bartley is online now
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
I have several Scorpion 40 series motors that can all do 4.8kg thrust without effort. Props from 18'' on down depending on KV, all on 6S for me!
Go to Innov8tive Designs.com , download the latest calculator (free), then you see for yourself the individual specs.
I tested a 4020-16 with a 18/10 Apc e, pulled 1500 watts, at 70 or so amps, produces about 14 lbs thrust (6.36 kg). just a sample.
The Scorpion calc is quite accurate when using props they tested, usually within 1-2%. FWIW Doug B
Doug Bartley is online now Find More Posts by Doug Bartley
Old May 31, 2011, 10:01 PM
Narwhal is offline
Joined Jan 2011
Thanks, that was exactly what I needed.
Question 4.5kg/10lb thrust turbine jofro Jet Turbines 1 Mar 13, 2011 06:48 PM
Discussion How many thrust that you able to get from GWS EDF75? 1.7+Kg GWS4CEO Power Systems 13 Feb 10, 2011 12:21 PM
Discussion Help Kalt KG-22 engine part needed alabama sam Engines 0 Mar 19, 2007 01:01 PM
Question Thrust for 1-2.5 Kg planes Going Brushless or going LIPO? ags Power Systems 1 Jul 29, 2005 03:01 PM
Is 0.8 kg/cm (12oz/in) enough to drive the rudder on a GWS size warbird? Spiteful Parkflyers 4 Nov 17, 2003 03:37 AM
