Old May 31, 2011, 06:39 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Question
A Motor for the Bixler from HK ???!! Please help
Hi ...
I really need to get a Motor for the Bixler from Hobbyking ..
I don't know if I should get an inrunner or an outrunner ... I myself prefer the outrunner ... I think it runs cooler .. I've never owned an inrunner ...
Can someone please recommend a Motor(Outrunner)/Prop combo from hobbyking.com that can be used with the Bixler here
http://www.hobbyking.com/hobbyking/s...dProduct=16545
Thanks a lot for your input
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old May 31, 2011, 07:48 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
I think you must forget HK for the motor, nothing to suit your needs, they are either bk, either not good parameters.
I recommend you from rctimer, my favourite motor suplier, the following motors, with 6*4 or 7*5, depends what is prop clearance:
http://www.rctimer.com/index.php?gOo...1&productname=
http://www.rctimer.com/index.php?gOo...7&productname=
Get 3 blades prop for even more punch:
http://www.hobbyking.com/hobbyking/s...idProduct=8091
http://www.hobbyking.com/hobbyking/s...idProduct=9670
renatoa is offline Find More Posts by renatoa
Old May 31, 2011, 07:52 AM
jsxx is offline
Find More Posts by jsxx
jsxx's Avatar
Wielka Brytania, Anglia, Derbyshire
Joined Jan 2011
2212 2200kv prop 6x4
will go vertical
2200mah lipo 25-30min light (non fpv)
jsxx is offline Find More Posts by jsxx
Old May 31, 2011, 08:48 AM
renatoa is offline
Joined Sep 2007
Show me a 2212 or 2200kv in stock at HK
Old May 31, 2011, 08:54 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
If you want a motor for the Bixler, then just look at what people are using for the Multiplex Easystar. I do love the hobbyking prices, but it is a bit annoying to see them just copying other designs and not coming up with something original.
lovegroove is offline Find More Posts by lovegroove
Old May 31, 2011, 09:00 AM
renatoa is offline
Joined Sep 2007
NTM line of motors is original.
The others are not even copied, are rebranded stuff of other mfr.
Old May 31, 2011, 09:15 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I was talking about the Bixler, which is a blatant rip-off of the EZ*
Old May 31, 2011, 04:07 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
Get your facts straight. It's not a balatant rip-ff of the easy star.
It's a cheaper Bananna Hobby Sky Surfer, of another plane that is ripping off the easy star...
Toysrme is offline Find More Posts by Toysrme
Old May 31, 2011, 05:31 PM
Joined Nov 2006
Hi ..
How about these motors ... ??
http://www.slickzero.com/page/SRHP/P...t/2212-06-A-BP
http://www.bphobbies.com/view.asp?id...7&pid=B2632603
And this is the correct pusher prop I should get .... APC 6X4E pusher prop
http://www.bphobbies.com/view.asp?id...7&pid=A3918191
Is this a good combo for the EZ* clone ??
I really appreciate your input
Khaled
Old May 31, 2011, 06:34 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
I've got a Turnigy 2835 2200kv inrunner with a 6x4 APC on it in mine. Here is it flying with 4000mah 3s onboard.
2.6 miles on stock TX antenna with 300mW using my groundplane at the base (16 min 48 sec)
Po73 is offline Find More Posts by Po73
Old Jun 01, 2011, 06:42 AM
Joined Nov 2006
Wow ... That's some nice solid FPV flying
Khaled
Old Jun 01, 2011, 07:10 AM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Originally Posted by khaled_abobakr View Post
Hi ..
Khaled
I use these motors on my twinstar. You can put a 6x4 on them but you will need a 30 amp esc. In my tests I get about 26amp for power on a 6x4 with a s3 battery.
I get mine from http://www.giantcod.co.uk/221206-220...-p-402397.html
whakahere is offline Find More Posts by whakahere
Old Jun 01, 2011, 08:15 AM
Joined Nov 2006
Thanks whakahere
Khaled
Old Jun 01, 2011, 09:59 AM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Yup. Awesome plane the sky surfer.
I don't think this is a copy. Probably comes from the same factory but re-badged and sold cheap by HK.
I paid 3 times more for my sky surfer. It came with a crap motor to boot.
borneobear is offline Find More Posts by borneobear
Discussion Please help me bind my HK-8X Rx to my HK-7X Tx LanceMc Radios 8 Dec 31, 2013 01:01 PM
Discussion poly combat from france help please iawnski Vendor Talk 0 May 17, 2011 05:01 AM
Wanted PLEASE GUYS HELP ME-NEEDED Retracts for my Pattern Plane, PLEASE HELP mechengineer03 Aircraft - General - Miscellaneous (FS/W) 9 Apr 14, 2011 08:53 AM
Discussion Wire length between ESC/Battery...ESC/Motor...Please help !! SydneyFlyer Power Systems 4 Mar 15, 2011 04:56 PM
Discussion Please help me with my quadcopter's propeller and motor selection shadow511 Electric Motor Design and Construction 2 Mar 10, 2011 09:49 PM
