Espritmodel.com Heli Air
Old Mar 26, 2012, 08:50 PM
Joined Mar 2012
LED lights
The design of the Y6 is slick and I can see the need for the LED deck to help orient the craft for the operator. Has anyone mounted the LED deck below the Y6 for greater visibility? If the Y6 is over 50 feet I can see problems see the lights for direction.
Steve
jesusita1918 is offline Find More Posts by jesusita1918
Old Mar 27, 2012, 04:20 AM
Joined Feb 2011
This castle is situated almost in the middle of Slovenia.
CrazyJ, I was flying without FPV or any other gear on the Scarab. So the weight was as low as possible.
quadslo is offline Find More Posts by quadslo
Old Mar 27, 2012, 10:21 AM
Shikra's Avatar
Siluria, EU
Joined Jun 2009
Nice vid Nejc. Well put together and some great angles. Your castles are very different to here too!
You looked real close to the wall at times - especially with R3 mode !! Brave... did you break any props?
I'm just too timid to fly close.
Shikra is offline Find More Posts by Shikra
Old Mar 27, 2012, 10:31 AM
Joined Feb 2011
Thanks, some were really close calls
No crashes for a couple of months now
Old Mar 27, 2012, 10:40 AM
Shikra's Avatar
Siluria, EU
Joined Jun 2009
Done... !
Originally Posted by quadslo View Post
Can you post your videos also on the Scarab camera discussion topic : http://www.rcgroups.com/forums/showt...1545638&page=9
Did anyone already try to fly Scarabs with the DJI?
Old Mar 27, 2012, 10:45 AM
Photograper
Bonson's Avatar
Sweden, Älmhult
Joined Mar 2012
Hi, I'm pretty new to this, and I have a question about Paris (Triikopta) and Multiplex Cockpit SX.
It seems not possible to get as low as 1095 on the throttle stick, maybe wrong thread but I try...
Bonson is offline Find More Posts by Bonson
Old Mar 27, 2012, 11:27 AM
PubUltraStar's Avatar
United States, WI, Paddock Lake
Joined Dec 2011
Anyone have a US supplier of GWS 9050 propellers? Looks like everything I find online comes from China and the reviews are not great for these suppliers, or they take like 4 weeks to arrive. Also, the shipping charge from the MultiWiiCopter site is really high to the US, so I was hoping to find something stateside.
PubUltraStar is offline Find More Posts by PubUltraStar
Old Mar 27, 2012, 11:48 AM
United States, CA, Vista
Joined Dec 2010
Inov8tive Designs has props for multicopters.
www.innov8tivedesigns.com
Edkirk is offline Find More Posts by Edkirk
Old Mar 27, 2012, 12:35 PM
Joined Dec 2011
Thanks. I ordered a few of each and they were processed and already shipped the same day. Very much appreciated!
Update: Received 2 days later. Excellent turn around time.
Last edited by PubUltraStar; Mar 29, 2012 at 09:58 PM. Reason: Update to purchase at Inov8tive Designs
Old Mar 27, 2012, 12:45 PM
Joined Mar 2012
3M Hex nuts
Anyone who needs 3M hex nuts, 3M 5X5 and 5X10 pan head slot Nylon hardware I have a hundred of each. I only needed a few but the nearby supplier only sold in hundred counts. If the count you need is covered by a couple of USPS stamps I will send them to you just for the asking.
Steve
Old Mar 27, 2012, 01:04 PM
Joined Dec 2011
Case?
Just thought I'd ask to see what others are using to transport/protect their MultiWiiCopters? Considering that these multi-copters don't really fit into standard cases, I decided I would build my own. I found a site called Reliable Hardware in the US that sells the parts necessary to custom build a protective case. If anyone is interested, I can post build pictures. Otherwise, I'd be interested in knowing what other store their copters in.
I think that I'll be able to customize the foam inside to also house my transmitter, batteries, etc. Although it's a bit pricey, I figured that I already spent a bunch on all of the equipment, might as well keep it safe/secure.
Old Mar 27, 2012, 01:12 PM
Joined Feb 2011
I have a large wooden box to transport it in my car. It is quite bulky, but at least copter sits tight in the trunk
Old Mar 27, 2012, 02:11 PM
Shikra's Avatar
Siluria, EU
Joined Jun 2009
I could tell!!
I had 2 within a couple of days. Unlucky with some duff batteries - bad connections came apart inside.
Real lucky on the copter - just dropped straight down onto the carriage. Minor damage. Replaced one boom which cracked. I
Old Mar 27, 2012, 02:16 PM
Shikra's Avatar
Siluria, EU
Joined Jun 2009
If GUI confirms that, increase this to 5 higher than your lowest.
#define MINCHECK 1100 in the main file - not config
Should also reduce MAXCHECK by same amount
Old Mar 27, 2012, 02:49 PM
Photograper
Bonson's Avatar
Sweden, Älmhult
Joined Mar 2012
But - if I set down the trim 5 steps I reach 1095, is that ok not to have the trim in neutral?
I'm not sure about what you mean I should change?
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 556 May 07, 2013 02:23 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 181 Oct 08, 2012 09:43 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob Video Piloting (FPV/RPV) 2 May 01, 2011 04:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 07:45 AM
