Old Jan 03, 2012, 07:31 PM
Artie in Aus is offline
Find More Posts by Artie in Aus
Australia, NSW, Batemans Bay
Joined Feb 2011
Originally Posted by Stunt Double View Post
I dont agree with that. The 3 blade props seem to be just like 2's, they are all a little bit different and you find that out once you put them onto a balancing rig. Ive had some props that need just a tiny bit of tape on one blade, others that need quite a lot on 2 blades.
Havent tried electrical tape yet. Ive been using fibre reinforced strapping tape but im still looking around for something better.
+1 I sand my heavy blades, takes longer than tape but I 'trust' a sanded blade more than a piece of tape which can (and does) fly off. It doesnt take much but I also agree, no 2 props are alike, some only need atention to one blade most need two sanded.
Artie in Aus is offline Find More Posts by Artie in Aus
Old Jan 04, 2012, 05:20 AM
AP_OZ is offline
Find More Posts by AP_OZ
disenfranchised...
AP_OZ's Avatar
Joined May 2010
Originally Posted by flohio117 View Post
does anybody know when the multiwii avatar tricopter will be released? i think it looks awesome and i would like one
Won't be too far off. I'd say within the month. MWC has shut down for holidays until next week and once back the avatar and some other exciting things will start to be finalized and released.
AP_OZ is offline Find More Posts by AP_OZ
Old Jan 04, 2012, 10:03 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
thanks for the info
flohio117 is offline Find More Posts by flohio117
Old Jan 04, 2012, 03:17 PM
drmgcm is offline
Find More Posts by drmgcm
drmgcm's Avatar
Cayman Islands, Grand Cayman, Patricks Island
Joined Nov 2005
Please note "Tape only flies off if you only put it on top of the blade, if you wrap it around the leading edge so half is on top and half is on the bottom, and because you are using it on the leading edge which moves into the airflow, it will never fly off."
We use this same principal with Kevlar tape on Full size Eurocopter EC135 main blades, as dictated by Eurocopter engineers.
Lets face it, you don't take material off a heavy blade in the fullsize world, so why do it in the RC world.
What works on fullsize helicopter blades and aircraft props, will always work on RC models.
Danny
drmgcm is offline Find More Posts by drmgcm
Old Jan 04, 2012, 05:02 PM
mgabor is offline
Find More Posts by mgabor
www.fx-creative.com
Joined Dec 2011
hello Guys!
i've received my first Scarab. this small one: http://www.multiwiicopter.com/produc...th-quad-copter
i have assembled it, calibrated my radio, connected with usb, started to try it without propellors.
i found only 3 (of 4) ports working on the main board.
the motor connected to the bad port, only keeps beeping, doesn't spin up
the voltages are:
in the good ports:
2.5V
2.5V
5V
in the bad one (port 'e3'):
3.3V
1.7V
5V
i tried to swap the the cables, 100% sure that the mainboard/port is the wrong. in the other ports any of the 4 motors works well
if i connect with usb, and check it's software, it seem everything works well.
i see the 4 engines, they react well if i tilt the copter or move the sticks on the radio
http://www.multiwiicopter.com/produc...uinton-v19.jpg
any ideas? what should i do?
thx/gabor
mgabor is offline Find More Posts by mgabor
Old Jan 04, 2012, 08:22 PM
AP_OZ is offline
disenfranchised...
AP_OZ's Avatar
Joined May 2010
Originally Posted by mgabor View Post
hello Guys!
the voltages are:
in the good ports:
2.5V
2.5V
5V
3.3V
1.7V
5V
thx/gabor
Is it now working in the gui? Try reloading the code..
Old Jan 04, 2012, 08:23 PM
AP_OZ is offline
disenfranchised...
AP_OZ's Avatar
Joined May 2010
Just finished upgrading my stealth to the big engines... This is going to be fun!!
Old Jan 04, 2012, 08:27 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
No FPV gear on that little beast?
Stunt Double is offline Find More Posts by Stunt Double
Old Jan 04, 2012, 08:29 PM
Joined Oct 2007
mgabor, did you calibrate the escs and set the correct throttle range? Also have you tried swapping things around to test if its the pin or the motor/esc
Old Jan 04, 2012, 08:43 PM
AP_OZ is offline
disenfranchised...
AP_OZ's Avatar
Joined May 2010
No, haven't put in on yet. Intend on using a 5.8ghz 200mw unit that's currently sitting on another airframe.
Old Jan 04, 2012, 08:51 PM
Joined Oct 2007
Do those aluminium engine locks stop all slop between the arms and mount? Are they worth the $38.50? Thinking about getting some. I thought id solved my slop issues but after a heavy knock I can see a bit of movement again and it shows in my latest video
Old Jan 04, 2012, 09:27 PM
Joined Feb 2011
Danny
Because it suits me to do so...
Old Jan 04, 2012, 09:29 PM
AP_OZ is offline
disenfranchised...
AP_OZ's Avatar
Joined May 2010
Yeah mate, took me a while to start using them but now id never look back. The other good thing is you can twist the mount rather than having to undo the 8 screws on the boom holder. The new boom holders are also really good. Youve prob got them on your stealth so I won't harp on about them.
Old Jan 04, 2012, 10:05 PM
Joined Feb 2011
+1, never again be without them.....
Old Jan 05, 2012, 05:59 AM
mgabor is offline
www.fx-creative.com
Joined Dec 2011
hello
yes. in GUI everythings seems ok:
i have tried reloading code, swapping things, etc
help..
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 09:06 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 08:55 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 04:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 07:45 AM
