Old Jan 02, 2012, 10:06 PM
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Originally Posted by jimfc View Post
Sorry - that was my error - I meant to state that mine are 12mm/11mm - 11mm inside diameter! The 10mm ID are the thicker wall versions. The ones I have were intended for a 450 helicopter.
Jim
Here you go! 11mm is .433". You could put a strip of this vertically inside with some epoxy. It would be stronger than the 12/10 arms and cheap. 48" for $3.70.
http://www.dragonplate.com/ecart/pro...pID=919&cID=45
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Jan 02, 2012, 11:24 PM
disenfranchised...
AP_OZ's Avatar
Joined May 2010
Hey John - Thanks! No - I plan to use this with a GoPro and FPV, so I don't plan to fly it too hard (gonna have to build another for that! - yeah - I'm addicted). One more thing - is the 230mm the measured length of the arm, or the length that extends from the base? I'm using the Scarab 150mm base with the custom red aluminum mounts.
Thanks for all the help, mate!!
Jim
No probs. it's total length of the boom.
AP_OZ is offline Find More Posts by AP_OZ
Old Jan 02, 2012, 11:36 PM
Joined Dec 2011
Originally Posted by glambert View Post
Why did I wait so long to upgrade to 4S and triples. Nice and smooth video and all the gello gone!...
What is "4S and triples"? Thanks.
-Joel G.
jdg239 is offline Find More Posts by jdg239
Old Jan 03, 2012, 12:03 AM
Multi Rotor Maniac
Stunt Double's Avatar
Joined Oct 2007
4 cell lipo running on 3 bladed GWS 9x5 props.
Thats the setup im using at the moment too and it works well.
Stunt Double is offline Find More Posts by Stunt Double
Old Jan 03, 2012, 06:46 AM
drmgcm's Avatar
Cayman Islands, Grand Cayman, Patricks Island
Joined Nov 2005
Just to note, this is the prefered setup, less vibrations when you balance your props correctly, and more power at less amps, thus giving you better flight times.
Also your ESC's and motors perform more efficiently on this setup.
All the best
Danny
drmgcm is offline Find More Posts by drmgcm
Old Jan 03, 2012, 08:09 AM
So I have a head on my butt.
jimfc's Avatar
United States, FL, Palm Harbor
Joined Dec 2010
Thanks again!
Jim
jimfc is offline Find More Posts by jimfc
Old Jan 03, 2012, 10:36 AM
United States, SC, Charleston
Joined Nov 2011
When balancing the 9x5 props, I've gone through a full sheet of the holographic balancing tape for just 3 props. I'm putting sometimes two strips consisting of 3 layers of tape on a blade to get it to balance with the "heavy" blade.
Is this typical?
nathasm is offline Find More Posts by nathasm
Old Jan 03, 2012, 11:04 AM
Quad beginner
Sverige, Stockholms Län, Österåker
Joined Oct 2011
Is this typical?
Sounds like very much tape or is it thin and light? I normally use 1,5 cm tape going around the leading edge on each blade opposite the heaviest. I use electrical tape, what is "holographic balancing tape"?
Dynamicc is offline Find More Posts by Dynamicc
Old Jan 03, 2012, 11:06 AM
drmgcm's Avatar
Joined Nov 2005
Is this typical?
Definately doesn't sound right to me, i use very little tape on my blades and only one layer.
What you should see is that once you balance one 3 bladed prop, the rest will balance in exactly the same way with tape in the same areas on the other sets of props.
Danny
PS it could be the type of tape, i use heavy tape as in the pictures bellow, so if your using light tape that could be why.
Old Jan 03, 2012, 11:07 AM
jimfc's Avatar
Joined Dec 2010
Is this typical?
I just balanced my 9x5 triple props and this is the first time I've used these GWS triples, but I had to use 2+ layers of scotch tape on the lightest blade to balance them. I put my props on a magnetic balancer, then marked the heaviest, middle and lightest blades. I then balanced the lightest blade to the heaviest and finally added tape to the middle blade to complete the balance.
Jim
Old Jan 03, 2012, 11:52 AM
Joined Nov 2011
The holographic balancing tape is the tape that comes with the MWC kits. It seems pretty light so that may be why it's taking so much tape.
I guess others are using electrical tape?
Old Jan 03, 2012, 04:26 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i have some red balancing tape i got at my LHS
Adidas4275 is offline Find More Posts by Adidas4275
Old Jan 03, 2012, 05:21 PM
jimfc's Avatar
Joined Dec 2010
Not a bad idea - thanks!!
Jim
Old Jan 03, 2012, 05:38 PM
Creator of the 1st 6S HT-Flip!
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
does anybody know when the multiwii avatar tricopter will be released? i think it looks awesome and i would like one
flohio117 is offline Find More Posts by flohio117
Old Jan 03, 2012, 06:00 PM
Multi Rotor Maniac
Joined Oct 2007
I dont agree with that. The 3 blade props seem to be just like 2's, they are all a little bit different and you find that out once you put them onto a balancing rig. Ive had some props that need just a tiny bit of tape on one blade, others that need quite a lot on 2 blades.
Havent tried electrical tape yet. Ive been using fibre reinforced strapping tape but im still looking around for something better.
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 558 Today 11:14 AM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 181 Oct 08, 2012 09:43 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob Video Piloting (FPV/RPV) 2 May 01, 2011 04:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 07:45 AM
